Vestel 17PW16-2 troubleshooting
  • vitasik
    • Oct 2016
    • 30
    Hi Guys
    Today I am playing with a funny behaving power supply board.
    Somebody recapped it before, but by the looks of things couldn't get it going as it was popping the fuse. Q803 was to blame. So replaced it with something I had with similar data. Good news - it doesn't pop the fuse, has stand by 3.3v and 5v. But nothing more. Did look at the manual for it and it appears that when its in stand by it gets 3.3 v back from main board. When in full power it should get 0 at the stand-by pin? Am I wrong? tried unplugging main board and bridging controls to see if 24v for inverters would go up. Answer is - NO. Whatever I did with the control pin ( both grounding it and pulling to 3.3v) PSU wouldn't give +24,+12,+5 and +3.3 v (later 2 not the stand by ones).
    Does anyone have experience with this junk and if so what are the common problems. I will find the problem eventually, but wanted to see if someone could help out to cut the time a bit.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Vestel 17PW16-2 troubleshooting
    God I hate these when they blow up, what is Q803 part of ? Also did you check things like the controller for it and other related parts ?
    • vitasik
      • Oct 2016
      • 30
      Q803 is a switching power MOSFET for some sort of active PFC. On the Schematic diagram its noted as RESONANT PFC. Its driving part looks ok with no short circus to the driver. Besides this part is OK as all other parts are taking power supply from here. If this was gone I would think that stand by would be gone as well.
      See the attached file. The only control from mainboard is to pin 6 of the PL803 connector. This gets from main board +3.3v. I presume this is in OFF state due to the arrangement ( see the attachment).
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        The 3.3v & 5V standby are derived from a different circuit. IC806 & TR807.
        Do you have 400v dc cross C819?
        Edit.
        Use a 1K resistor between 5Vstby and st_by with main board disconnected and then check for 400 across C819.
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          You dont need to bridge ps on to get these to run just unplug the Mb completely and plug supply into mains. You should bave 400v across the cap.
          • vitasik
            • Oct 2016
            • 30
            Hm... its 324v.... weird.
            EDIT: R830 is gone. Well at least I think so. Its the only one fitted there ( there should be R829 as well, but its not here from factory). its 2 reds and a silver strip, which should be 0.22 Ohms???? Nope - multimeter wont even register it.
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Yeah thats deffo a problem, replace it and let us know.
              • vitasik
                • Oct 2016
                • 30
                Hm
                It did absolutely nothing, same voltage. Initially I thought that maybe it has popped again, but no. It was not even warm, so not overloaded. So I am facing 2 options in my opinion - IC802 or... my choice of the Mosfet
                It had P9NK50ZFP, but I had 15N65C3. Both N - channel power FETS
                Old vs New
                V ds 500 650
                I ds 7.2 15
                R ds (ON) .72 0.28
                For full datasheet see attachments
                Any bright Ideas???
                • dick_barton
                  • Aug 2015
                  • 6643
                  • Wales
                  Can you check what voltage you have at D807 (VF_Main).
                  VF_Main feeds IC828 to provide VCC1.
                  VCC1 feeds R953 & C881 which feeds VCC2.
                  VCC2 feeds IC802 pin8.
                  Can you check what voltage you have for VF_Main, VCC1 & VCC2
                  • vitasik
                    • Oct 2016
                    • 30
                    Yes - all of the voltages are present as follows:
                    Vf_main - 14.7v
                    VCC1 - 12.98v
                    Vcc2-12.8v
                    EDIT:
                    Been messing around with it. R823 that is between IC802 and the Q803- Mosfet I changed before was blown. After replacing it (had 11 ohms instead of 15) Mosfet blew again as well as the fuse.
                    • dick_barton
                      • Aug 2015
                      • 6643
                      • Wales
                      The mosfets are not interchangeable. The original mosfet STP9NK50Z has zener diode voltage limiting gate drive protection which the substitute mosfet does not have.
                      • dick_barton
                        • Aug 2015
                        • 6643
                        • Wales
                        Vf_main - 14.7v
                        VCC1 - 12.98v
                        Vcc2-12.8v
                        EDIT:
                        Those voltages appear fine and is supplying the voltage (VCC2) for IC802 to run that chip.
                        I would also check that c920 and other components around that circuit have not been damaged due to the mosfets blowing.
                        • vitasik
                          • Oct 2016
                          • 30
                          Have already checked most elements in a IC802 and mosfet's circuit. Didnt check c920 though. Will do when get the original mosfet. The whole repair is put on hold until than.
                          • llonen
                            • Sep 2014
                            • 495
                            • hampshire
                            I spent ages working on one of those, the 24volt was unstable - intermittent would work for weeks on test and then fail, I ended up having two sets with those supplies come in, one with batch of bad capacitors and the other the screen was broken so one set was repaired and the other supply went into the first one. If you need any values measured for replacement parts I probably still have one of these in the workshop that works.
                            • dick_barton
                              • Aug 2015
                              • 6643
                              • Wales
                              Let us know how it goes.
                              • vitasik
                                • Oct 2016
                                • 30
                                Hey guys
                                Time for an update - been busy with other junk - too many projects ( biggest is a recovery truck).
                                Now replaced mosfet with the correct one and checked c920 - according to my multimeter its 200pF which is off but not enough to be doing this shit. Bare in mind my multimeter is not a pro so could be within speck or even more out of spec. Result- same in 2 secs after switching on fuse blows and mosfet has shorted again. Really puzzled.
                                Good thing I have 4 more mosfets.
                                Bad thing i am running out of ideas.
                                EDIT: brainstorming - IC802(fan7529) doesn't have shorts on any pins, but what would happen if it was either keep mosfet always on or always off?
                                • vitasik
                                  • Oct 2016
                                  • 30
                                  anyone?
                                  • dick_barton
                                    • Aug 2015
                                    • 6643
                                    • Wales
                                    Transformers work by switching on and off a voltage on one of their windings generally the primary which then produce other voltages on the other windings (secondarys).
                                    This is carried out by switching the mosfet on and off to produce the changing voltage across the primary of the transformer.
                                    No switching of the voltage on the primary results in no secondary voltages.
                                    • dick_barton
                                      • Aug 2015
                                      • 6643
                                      • Wales
                                      If you lift out your mosfet Q803 and power on
                                      Does the fuse remain intact
                                      What voltage do you have across C819 pins
                                      • vitasik
                                        • Oct 2016
                                        • 30
                                        Right -
                                        I have around 324v on c819, if I lift Mosfet fuse does not blow.
                                        As to the transformer explanation - this is not your most common transformer, but its a single coil(choke) like in boost converter -this "transformer" has only one winding, no secondaries.
                                        • Adenitz
                                          Troubleshooting Vestel TV, has standby, but cannot turn ON
                                          by Adenitz
                                          I need advice in troubleshooting Telefunken TV (it is actually Vestel). There is red Standby light but TV cannot be turned on either by remote control (which is good and tested on another TV) or by actual on/off switch at the back of the TV.
                                          Power board is Vestel 17IPS71 and I'm not sure about the mainboard, it seems like 17MB82S
                                          Both boards are shown in the attached photos.
                                          What is normally first that is checked in this case. I have removed power board, make sure it has no dangerous voltage on the big caps and check many components (transistors and diodes)...
                                          12-27-2023, 03:43 AM
                                        • France_53
                                          Vestel tv, how to flip the image?
                                          by France_53
                                          Hello everyone from Italy, I'm here to ask for help on a Vestel TV, I've had a Vestel TV branded "XD" with a broken screen for years, but now I've found a Telefunken (still Vestel but older) and I've mounted the panel on the "XD" TV, it works, but the screen is upside down, given that Vestel does not allow you to rotate the image from the service menu, does anyone know how to solve the problem? the original panel is marked ves315WNDS-2D-N12 while the main board 17mb110, the panel I mounted instead in the tv (from the telefunken) is a ves315WNDA-02. ... It is not worth repairing...
                                          05-12-2024, 05:22 AM
                                        • FriedFred
                                          Schenker VIA 15 PRO, PF 4NU1F V1.0, P/N: MBPPF4NU18-F310 - 36mA in stand-by
                                          by FriedFred
                                          Hello, everyone!
                                          I have here a Schenker VIA 15 PRO, with this numbers on the board: PF 4NU1F V1.0 and P/N: MBPPF4NU18-F310 .
                                          I took out the memory and the battery and the SSD.
                                          So, in stand-by, only the board, takes 36mA. No power-button pressed at all, I can measure 1.8V, 3.3V, 5V. All coils present voltages except the two power rails for the CPU. The CPU is a AMD Ryzen 5 4600H.
                                          After pressing the power-button, the current raises to 500mA and the two power rails for the CPU show up with 0.8V.
                                          After several seconds, the fans switch-off and the board keeps powered...
                                          03-08-2025, 04:45 AM
                                        • Titus6
                                          LG OLE65C1 Stand-By issue
                                          by Titus6
                                          I bought an OLED65C1 refurbished TV back in 2022 from a shop. The TV is awesome, this is my first OLED and I really love it.
                                          However I have an issue with the TV since the end of last year. I noticed when my TV is in Stand-By, sometimes the LED goes off then comes back on. When do so it seem periodical. It only goes away for 1-2 seconds, than comes back on. The TV NEVER turnes off, while it's on, so it's not overheating issue or electrical power issue.
                                          I bought a service remote (MKJ39170828) and checked the menu 3. Power On/Off Status. I took...
                                          01-31-2025, 04:01 PM
                                        • blues_spirit
                                          practical courses for troubleshooting pc motherboards
                                          by blues_spirit
                                          Hello from France,
                                          mon2 kindly advised me to post a thread to ask the question(s) I'm concerned about. I'm new to the forum and I'm looking for practical courses for troubleshooting pc motherboards especially laptops in Europe, if possible in France. I have been a computer network system administrator and a corrector of administration modules for automated programs under Unix. But I really miss the practical "ops" side of troubleshooting. So I would like to start from the beginning: 1.8V, 3.3V, 5V and 19V tests for example, etc...
                                          Do you think this is feasible for me? I...
                                          12-18-2022, 12:56 PM
