Samsung UN50H6201AFXZA - Has backlight but no pic or OSD
  • kevinm34232
    • May 2012
    • 1884
    First off I don't have a scope unfortunately..
    No obvious problems on t-con.. So I ordered a new main and t-con board thinking it was one of them.. When removing the main board I saw it seemed like the main CPU had heated up pretty good and the board underneath had signs of excess heat..
    But same problem with new parts.. I'm thinking now it's the panel unless I happened to get another bad part..
    Anyone familiar with this set? When I first put the new main board in, it seemed like the main CPU got pretty warm right away..
  • Nick's Tvs
    • Jan 2014
    • 621
    Re: Samsung UN50H6201AFXZA - Has backlight but no pic or OSD
    That chip has a heat sink because it does get very hot. This is normal and happens on all sets. It seems like you are able to get 12 volts to the T-con board since the blue led's on the T-con seem to light up. You possibly have a bad panel and or bad T-con. Have you tried disconnecting the ribbons one at a time between the T-con and panel, and see if half of the screen starts to work? If not, I would highly suggest doing so. If half the screen starts working then you have a bad panel.
    • kevinm34232
      • May 2012
      • 1884
      Good call! Disconnecting the one side shown and the other half of screen displays normally. Anything that it can possibly be on this tab bond board, or is it toast inside the panel?
      • Nick's Tvs
        • Jan 2014
        • 621
        From my experience it is due to a shorted IC within the ribbons between the screen and the buffer boards. Nothing I know how to fix without replacing the screen.
        • anmol
          • Mar 2012
          • 73
          • India
          check all capacitor and all other parts on panel pcb for short circuit.
          Regards.
          • kevinm34232
            • May 2012
            • 1884
            No obvious shorts on any components, but there is a 15V line and 3V line coming from T-Con to each side of the panel, on the bad side, the 3V is fine, the 15V gets pulled down to about 1.1V when connected to the panel.
            • CapLeaker
              Leaking Member
              • 8325
              Now that sux. Shorted driver ic on the panel / ribbon.
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                See if any of the ceramic caps on the driver board are short.
                • kevinm34232
                  • May 2012
                  • 1884
                  I did, didn't find any..
                  • lawrence_jeff
                    • Mar 2017
                    @kevinm34232 I know this is an old thread - but any chance you figured out anything with this? I have the same TV with the same symptoms, replaced the boards with no change but if I disconnect one of the ribbons I do get half the picture (other half white), tried swapping out the ribbon cables and the other side still doesn't work
                    • dskall
                      • Oct 2016
                      • 2905
                      • usa
                      Read and perform the tests as above. Check for shorted components on panel pcb board. If no problem then you have bad panel.
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        Maybe worth trying some freeze spary on the faulty side of the panel pcb it may show what part is short circuit if its getting hot.
                        • rickou
                          • Apr 2015
                          • 30
                          • luxembourg
                          Do you have a external power supply to put 15V and limit the current too then you can see if some cap goes hot.
                          • robertkyu
                            • Jun 2018
                            I'm having the same problem as kevinm34232 with my UN50H6201AFXZA. Is it possible to replace the buffer board to fix this?
                            Or this is a problem with the panel and not repairable?
                            • attainteddragon
                              • Apr 2013
                              • 764
                              • australia
                              the panel driver board is attached to the ribbon cables which attaches to the panel and the cof chip is embedded about half way along this ribbon cable. all of these parts are not changeable. your only chance is if you have a component on the driver board that is shorting the bad side out.
                              WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
                              • budwich
                                • Jul 2015
                                • 3097
                                the thread is old BUT if you have checked for shorted smd components on the driver boards at the bottom and didn't find any, then it is possibly a problem with one of the tabs. Look at them closely for "heating issues". Further, since the start of this thread, people have found some ways around issues with these types of sets by using a "tape cutoff" method by placing small piece of tape on the tcon to panel connector / cable and / or removing tabs on the side of the set (the "bad side") depending on how the set is designed (some sets have side tabs, others don't). check the side if there are side tabs (note you can only see them from the front of the set with the bezel removed). IF you post a picture of the display with the "half picture" (ie. one cable disconnected), the forum may be able to give further guidance.
                                • oxonater
                                  • Oct 2012
                                  • 77
                                  Hi guys sorry to hijack this thread but I have a similar problem with my UE49K6300 Samsung Curve.
                                  Replaced T-con and Mainboard still no video but has audio
                                  All voltages are present and within spec
                                  Thing is I have disconnected both sides of the ribbons attached to tcon board an panel one by one and no display on either side.
                                  Now does this mean my panel is completely faulty (dead) or is it an IC problem on the buffer boards (IF THATS WHAT THERE CALLED).
                                  This problem occurred only recently when the tv tripped my RCD one day, was working fine before hand. On closer inspection of plug socket it was apparent there was a problem with socket which electrician had to repair.
                                  My question is could this have blown something on the panel side hence why TV tripped thanks guys
                                  • C152Heavy
                                    by C152Heavy
                                    Summary for TL-DR readers:
                                    • VCC pin (18) of PFC...
                                    01-11-2023, 02:53 PM
                                  • ygorsan
                                    by ygorsan
                                    🧩 Problem Summary:
                                    • I
                                    07-28-2025, 08:34 AM
                                  • Lee M.
                                    Samsung UN75RU8000FXZA bad main board?
                                    by Lee M.
                                    When plugged in it will click and cycle the BL on and off, no pic and does not respond to remote. When I disconnect the cable from the PS board to the main board and then plug it in the BL will come on and stay on. There are only two boards in this set, the LVDS cables from the panel driver boards connect directly to the main board. Since the BL comes on and stays on I'm thinking the PS board is ok and the problem is on the main board. Should I order another main board or do I need to do more testing? thanks, Lee
                                    11-08-2023, 07:46 PM
                                  • howardc64
                                    Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                                    by howardc64
                                    • Prior owner tried a replacement main board. No difference.
                                    • Samsung 2x red blinking standby LED = panel fault
                                    • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                                    • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                                    • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                                    07-19-2025, 10:54 PM
                                  • JDC
                                    (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
                                    by JDC
                                    ONN 100012588
                                    Issue: No Power, Then Rebooting After Main Board Change
                                    Short answer: replace main board and power board
                                    Technical answer: replace main board and Q306 & Q307 on power board.
                                    Long answer:
                                    TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
                                    07-15-2022, 07:39 AM
