Panasonic TC-P55ST50
  • rjr19146
    • Oct 2016
    • 13
    Im hoping to get some help diagnosing and hopefully fixing an issue I am having with my Plasma TV.
    The TV for a while was having ghost menus where the mus would pop up randomly and then just go through the menus randomly. I had someone look at the TV and they said it was possibly the mainboard
    This stopped on its own so I figured it was interference or something.
    Then the TV just stopped working. There is a clicking noise that comes from the Power Board and the TV just goes from Standby to off to standby to off and never turns on.
    Holding the power button on the tv stops the clicking cycle.
    I saw a similar issue with the TC-PT55ST30 where it seemed like it was the mainboard (A Board)
    So I have two questions - How can I determine for cerrtian if it is the mainboard? I tried using a multimeter but wasnt 100% sure what to look for
    so any help confirming that the issue is the mainboard would be great.
    The other question / issue is that there do not seem to be any of these mainboard anywhere! the # on the board is TNPH0989 1A
    I saw a board TNPH0989 2A for a TC-P60ST50 and was wondering if this board would work. Are there any issues swapping a 1A for a 2A? They look the same..
    If this board is not compatible does any know where I could find the board and /or where I can have my board repaired?
    I appreciate any help or advice.
    Russ
  • Moreno83
    • Jun 2014
    • 2008
    • The Netherlands
    Re: Panasonic TC-P55ST50
    Ghosting menu's is definately a board problem. Might be a overheating problem.
    Ill look for a mainboard when i get home
    • tw2005
      • Oct 2011
      • 6458
      TXN/A1REUUS (TNPH0989UB) is what you should be looking for. 1A 2A is not important.
      Board Number : Revision Suffix. The suffix is what determines what model it is for
      http://www.ptselectronicsinc.com/txn...-a-tnph0989ub/
      • rjr19146
        • Oct 2016
        • 13
        Thanks for the information.
        Should I worry that the Overheating is being caused by something other than a faulty board?
        Or should replacing the board fix the issue?
        • tw2005
          • Oct 2011
          • 6458
          well unless you can mod it by adding a cooling fan over the heatsink? Some guys have done some interesting things but I've never tried. The A-board can get pretty hot on some of those chips for sure and the BGA solders fracture. My 2010 runs that hot I'm amazed it has not failed too. Very hot to touch.
          I'd expect it to work fine after repair but how long before next failure, no idea.
          maybe one of the other may have some ideas.
          • rjr19146
            • Oct 2016
            • 13
            Thanks! Its definitely worth a shot.
            • rjr19146
              • Oct 2016
              • 13
              I sent in the mainboard to PTS and they are saying the board tested fine, no issues. Any ideas what else could cause this issue? Otherwise I will need to purchase a new tv....
              The power supply board was replaced so it has to be somewhere else.
              Thanks in advance
              • Hombre
                • Jul 2013
                • 231
                • Croatia
                If it was going through menus randomly i would suspect maybe on this side buttons, tried to disconnect it from a-board? But i am not at all familiar with this model so it may not be the problem.
                • Neelix
                  • Oct 2013
                  • 145
                  • South Africa
                  Re: Panasonic TC-P55ST50 - Not powering on
                  So the LED shows red, then nothing, then red again, then nothing again and continues doing that?
                  • Neelix
                    • Oct 2013
                    • 145
                    • South Africa
                    Service manual:
                    • rjr19146
                      • Oct 2016
                      • 13
                      That's exactly what happens. Never any picture on the screen just red light click off - red light click off. I noticed if I hold the power button on the side it just does nothing but as soon as i release it goes through this cycle
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        as above post have you tried disconecting the button board? they can play up in odd ways as we have saw a few times on the forum.
                        • rjr19146
                          • Oct 2016
                          • 13
                          I will try to disconnect the button board once I receive the Mainboard back from PTS
                          thanks for the advice
                          • rjr19146
                            • Oct 2016
                            • 13
                            I received the main board back and reconnected and then disconnected the button board but the TV still has the same issue
                            Any other suggestions or troubleshooting tips?
                            Is it possible it's something as simple as the cord being bad?
                            Thanks again
                            • Alastair E
                              Chief Womble
                              • Mar 2013
                              • 1963
                              • U.K.
                              Have you checked for shorts on the SC and the V-SUS line??
                              First thing I do on a 'dead'/stby Plasma--of Any make...
                              What made you think it would be Mainboard--Without any testing!!
                              TELEFIX
                              • rjr19146
                                • Oct 2016
                                • 13
                                I had Someone look at it when it was doing the ghost menus and they said it was the Mainboard so I assumed since it wasn't the power supply...
                                I Will try and test the SC and V-SUS line - Will look at the manual to see where these are. Should I just be looking to see if they are getting powered? Or any specific test I should do? (Im sort of new to TV testing/repair, although I have been successful in the past repairing our furnace and Washing machine )
                                • Alastair E
                                  Chief Womble
                                  • Mar 2013
                                  • 1963
                                  • U.K.
                                  Aye--That was THEN, NOW you have virtually 'dead' set with blinking LED....
                                  --How many Blinks....??
                                  TELEFIX
                                  • rjr19146
                                    • Oct 2016
                                    • 13
                                    There are no blinks. That's why this is difficult to isolate
                                    I was troubleshooting and saw that when the removed power to the main board the clicking stopped. I removed all the connections from the main board and then slowly tested each one and the clicking stops if I remove the ribbon that goes from the mainboard to the center data driver board - not sure if this actually solves the problem....
                                    • Alastair E
                                      Chief Womble
                                      • Mar 2013
                                      • 1963
                                      • U.K.
                                      Well, It would do wouldnt it!
                                      No mainboard connected to PSU--Therefore Nothing to tell PSU to turn on--Hence, No Clicks!
                                      Be Extremely Careful about removing ANY ribbons to/from the Control-Board and the COF Chips along the screen, especially any wires from the COF to the SC/SS or PSU.
                                      Doing so can Trash a panel COF, and total the set if plugged back while there's still residual power in the source by destroying the chips (COF) that are made as part of the glass PDP...
                                      TELEFIX
                                      • rjr19146
                                        • Oct 2016
                                        • 13
                                        Thanks. I actually reconnected the power to the mainboard and tested each connection separately to see what connection was causing the clicking. I waited 3-5 minutes between unplugging and replugging
                                        All the other connections except for the Ribbon connection to the data driver did not have the clicking but when I connected the Ribbon to the data driver the clicking started.
                                        Again i'm not sure this solves anything but is it possible this Data Driver board is causing the issue? Is there a way to confirm this is the cause?
                                        Im sort of at a loss since I cant seem to identify the issue. I may look to see if there are any professional repair shops in the area before committing to buying a new tv
