LG 47LD690 stuck on LG boot logo, standby light flashing.
  • jczarniak
    • Oct 2015
    • 179
    I've got LG 47LD690 which not get past the startup screen.
    Stays on LG logo (see pictures), standby light (red corner) flashing.
    Remote works, I can switch the TV ON and Off using it.
    Is there anything what I can do other then buying new main board, please?
    Any reset, service menu, eeprom reset etc...
    Thank you for any help.
  • Hamie
    • Apr 2014
    • 1383
    Re: LG 47LD690 stuck on LG boot logo, standby light flashing.
    Many people have had similar faults and reballing/reflowing the BGA tends to sort it out.
    • jczarniak
      • Oct 2015
      • 179
      Thank you.
      Do you know which chip it is in my case, please?
      • Hamie
        • Apr 2014
        • 1383
        The one in the center.
        The fact the heatsinks doest cover the whole chip may also have lead to an early failure. If reflowing it works I'd recommend using a better one.
        • jczarniak
          • Oct 2015
          • 179
          I'll try that today.
          Thanks a lot.
          Regards.
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            I have the 42LD490 which uses the same board, failed hdmi ports and no sound. Reflowing the shitty XD engine Cpu (centre Ic with half a heatsink) sorted it-common issue with Lg XD ic's is bad bga solder as they fail to heatsink them properly, a reflow should get it going. Fucking Lg shit.
            • jczarniak
              • Oct 2015
              • 179
              I like it
              Thanks for your comment !
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                No worries, also remove the heatsink and apply fresh thermal silicon to hold it down on the Ic after reflow. Maybe add a fan, these bloody processors get burning hot quick.
                • jczarniak
                  • Oct 2015
                  • 179
                  I will.
                  Thank you.
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    Keep us updated, I will have a video shortly on these boards
                    • jczarniak
                      • Oct 2015
                      • 179
                      Success!
                      Reflowing the XD engine Cpu fixed the problem with main board.
                      Everything working as it should.
                      Thank you very much for all support.
                      Regards.
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        Thanks for the update and glad a reflow fixed the problem.
                        • Hamie
                          • Apr 2014
                          • 1383
                          • Nick's Tvs
                            • Jan 2014
                            • 621
                            Just to give everyone a heads up but a re-flow is not a permanent fix and usually won't last more than 6 months up to a year before failing again. If you are going to be selling these tvs back out or if you are doing this for a customer, I would highly suggest going the re-ball route even though it is a lot more involved and difficult, it is the only way to do it ethically.
