Philip Plasma 50pfp5332D/37 Single Horizontal Colored Line
+ More Options
Posts
  • Round2thrift
    • Jun 2016
    • 20
    Re: Philip Plasma 50pfp5332D/37 Single Horizontal Colored Line
    ReeceyBurger123
    The words and letters look like they are out of focus almost like a blur and when the people move there are like pattern around there body like they go out of focus then it catches up and everything clears up i think i read somewhere the x-main could cause this. hope i explained it well enough where you can point me in the right direction
    • Round2thrift
      • Jun 2016
      • 20
      Reeceyburger123
      look like the words are out of focus and when people move picture goes out of focus with a pattern around people body until it catch up to a beautiful i quess it bad motion what your take on that i think i read somewhere X-main could cause a slow motion effect
      • Round2thrift
        • Jun 2016
        • 20
        When i turn the tv on with out any signal this is what the screen look like until it warms up
        standing in front of the TV this is the left side this sparkling goes from top to bottom accross about a 1/4 of the screen
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Your panel has mal discharged. You need to adjust Vs and Vsc voltages etc so the panel is able to discharge properly will find Toms thread on how to get this MD free.
          • Round2thrift
            • Jun 2016
            • 20
            So far i have only changed out a few board and checked a few voltages doing these adjustment sound like i need special tools have to do some more research, trying to find tom thread you mention have not learned how to completely get around in here yet.
            • Round2thrift
              • Jun 2016
              • 20
              Tested the voltages on this set today
              Va 63 in range sticker 63
              Vs 204 sticker says 207
              ve 92 sticker says 94
              where do i go to test the vsc and where can i find where to adjust them
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                #27
                If you look about the boards you will see the adjustment pots for the voltages buddy. Set Vs to 210v or so and -vsc to around -200 normally sorts the Md and Ve to 104 keep Va at factory voltage.
                • Round2thrift
                  • Jun 2016
                  • 20
                  Reecey
                  The setting sticker on the panel says Va at 63V it measure 54V you say leave at factory setting, i raise the Vs from 204V to 210V did get rid of the top half of the screen mal discharge there or only 2 adjustment pot on the power supply and thats Vs and Va. should i adjust the va?
                  Ve Voltage measured 92V the sticker say 94V have not located the Adjustment Pot
                  VSC I have not located the test spot or the adjustment pot or these on the X and Y sustains?
                  • Round2thrift
                    • Jun 2016
                    • 20
                    Can i replace 4 1000uf 25V Caps with 4 2200uf 25V caps?
                    • ReeceyBurger123
                      Never Give Up !
                      • May 2014
                      • 7325
                      • Britain
                      #30
                      The caps that should be changed are on the susboards as shown in my video also the adjustment pots for Ve and Vsc are on the Ysus and Xsus.
                      • Round2thrift
                        • Jun 2016
                        • 20
                        Got it thanks for your help Reeceyburger123 Set is working great now
                        • ReeceyBurger123
                          Never Give Up !
                          • May 2014
                          • 7325
                          • Britain
                          #32
                          Awesome work
                          • Round2thrift
                            • Jun 2016
                            • 20
                            Do anyone know a good place to purchase Lcd Screens i have two 2013 flat screen tv with crack screen one is a sanyo Model#Dp42841 Manufactured june 2013 the other is a element electronic Model# ELEFW502 Manufactured March 2013 will be gratful for any help
                            • ReeceyBurger123
                              Never Give Up !
                              • May 2014
                              • 7325
                              • Britain
                              #34
                              Prolly not worth it but check ebay.
                              • bffargo
                                2014 LG 60" Plasma shut down just clicking unless I disconnect 17V line to main CPU
                                by bffargo
                                LG 60PB66550 NOV 2014
                                PSU: EAY63168603
                                PCB: EAX65359531 2013.11.01 Rev:1.0
                                Main board: EAX65399305(1.0) 13.11.27 PU42A/PA42A/PD42A
                                Symptom:
                                While watching, just went black and started clicking relay every few seconds.
                                Initial diagnosis:
                                Removing JUST the main CPU/Input PCB from circuit stops the clicking. No problems with any other boards/drivers. (Removing all other boards and only putting Main back in is all it takes to start clicking again)
                                Deeper diagnosis:
                                Pulling pins #1/#2 (Blue/Grey) from the connector housing...
                                09-09-2022, 07:34 PM
                              • cubytus
                                Samsung UN50TU8000FXZC shows thin horizontal green line when warm
                                by cubytus
                                Hi to all,
                                I was given this TV, an entry-level 4K 50" set. Some have criticized its lack of contrast and relatively poor colour rendering, but for my needs, it's very decent.
                                I reset everything to factory settings, but this line keeps on fading in and out when watching a streaming channel from the Tizen firmware. Interestingly, it only happens when TV is warm, after about 1h45 of it being turned on.
                                Watching a movie from an external source doesn't trigger the line as easily (needs 2 hours), and from a normal viewing distance, is hardly noticeable. It...
                                01-10-2024, 01:26 AM
                              • canadaboy25
                                LG 50PG10 Plasma Vertical Line
                                by canadaboy25
                                Hey guys, I'm being offered an LG 50PG10 plasma with a vertical line running down the screen.
                                Apparently, if you give the TV a good smack on the frame above the line, it will go away for a while.
                                Does this sound like a bad solder joint or loose ribbon cable? Or a bad panel? If it's not likely to be a bad panel I will likely pick it up.
                                What do you guys think?
                                Thanks...
                                11-24-2020, 11:50 AM
                              • TrueSword88
                                Kogan - KALED65XU9220STB - Blue Vertical Line
                                by TrueSword88
                                Hi all.
                                I have a Kogan 65' LCD Panel with a thin blue vertical line (top to bottom) on left hand side of panel.
                                The line just happens to coincide with the end of COF and start of the next COF (attached).
                                The line is permanent no matter what I've tried. I've tried pressure testing the panel (top to bottom) and all over, I didn't notice any difference with the line, either temporary or semi-permanent.
                                Also tried unplugging all flex cables, cleaned with isopropyl then re-inserting to no avail - line remains.
                                Hoping to fix...
                                05-05-2023, 04:28 PM
                              • FALKLAN
                                Running Line Voltage and Integrating LED Pods - Automotive
                                by FALKLAN
                                Howdy everyone! I hope all is well where ever you are!
                                I'm attempting to integrate a couple of LED pods into an automotive reverse lamp circuit. The problem being, while the vehicle is running there is a 8.5v current present on the reverse lamp power wire. Needless to say is that all LED pods and lights dimly illuminate while the 8.5v is present, so the LEDs are always powered on while the vehicle is running. When the vehicle is shifted into reverse, the voltage changes to 12 volts.
                                I am uncertain how to convert this line into a switched 12v output line for the LED pods....
                                02-05-2025, 12:30 AM
