TCP55ST30 SU/SD board test needed (7 blinks)
  • Truncatedhose
    • Oct 2014
    • 343
    Re: TCP55ST30 SU/SD board test needed (7 blinks)
    Update: So the upper buffer has a short and I got one ordered. The SC and lower buffer seem to test okay. I will update when I get the buffer. Thanks so much for all involved.
    • tw2005
      • Oct 2011
      • 6458
      So what about the SC? You never came back and explained what you did for
      " isolation procedure for both SU/SD simultaneously and the TV still has the 7 blink error code."
      Is the SC good?
      • chth96
        How Can I test PWM DM0365R?
        by chth96
        Hello
        I have power adaptor(220V/input, 12V 1.2A/output) which has symptom of fluctuating output DC voltage between 11.5V-12.2V.
        So I opened its plastic case and when switched it on, I heard constant tik tik sound from inside its PCB.
        I measured DC voltage between negative and positive pin of the largest capacitor(400v 10uf) and it was measured contant 300V.
        I also measured ESR value of all capacitors and I noticed that one of capacitor(KMG 16v 470uf), which located in the secondary side, have high ESR value(10 ohm),So I replaced it with same specification NXH capacitor....
        06-18-2025, 04:14 PM
      • khelane
        test active pfc power with lamp test
        by khelane
        Hello
        I have a big problem and that is that in some cases when repairing active pfc power supplies I cannot work with a test lamp. I can only get help with 5 volts standby and for starting and starting I have to work without a lamp and this way there is a possibility of parts exploding and other parts being added.
        Sometimes with a multimeter test the problems can be reduced to some extent, but I had several cases that had to be tested on and online and recently two varistors exploded. They had terrible resistance because the power supplies were over 800 watts.
        Is there a way...
        06-03-2025, 01:00 AM
      • chronic519
        Mats / mods: detected and repaired GPU fault. Cant seem to test after!
        by chronic519
        Hello.
        GPU came in, green lines. Spent lots of time using to get the Mats / mods drive working (found on youtube).
        Found issue with a RAM block
        Replaced, green lines gone.
        Trying to test again, assuming getting the false positive. Originally had over 1K on a single bank. Now getting tosses low between banks.
        Used a good card to test and same results low errors 32+.
        I am just search for some form of command to do a full test on the GPU.
        I just ran the mats command with my good GPU and passed after roughly 40 min.
        The repaired one, ran...
        05-20-2025, 07:56 PM
      • hemant_2222
        Yamaha 2064 No sound but Test audio working
        by hemant_2222
        Hello Guys,
        Greetings!
        Hope you all are doing well.
        I am looking for suggestion on Yamaha 2064. The problem with this receiver is that it has no sound however when the test tones are activated it does outputs from all the speakers. It is working in two channel stereo mode but when you select other sound modes, it doesn't. The last time it had a problem, I had replaced the DAC
        PCM1681DBQR - IC263 and it worked fine.
        Other issue with it is one of the STK ICs is getting more heated then the other one but that can be looked at later.
        11-01-2025, 11:20 PM
      • Nairolf
        Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
        by Nairolf
        I have a Samsung DM32D display.
        When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
        Here’s what I have tried so far:
        1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
        2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
        3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
        From these tests, I suspect the problem might be on the mainboard. Could anyone...
        08-24-2025, 03:47 AM
