ue46c7700 white haze and vertical lines
  • anna1980
    • Mar 2016
    • 40
    • holland
    Hi
    I have a samsung ue46c7700 with a white haze on the left side en dark vertical lines right of the middle
    Before Im going to repair it, I just want to get some hints.
    Is this a panel fault or tcon. It also could be a dirty of broken lvds but I'm not so sure about the last
    My first impression is tcon because of the white haze but I'm not so sure
    With regards
    Anna
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: ue46c7700 white haze and vertical lines
    If you did some research you would have a better idea. Seems like tab bonding fault to me, check for tab bond repair on here if that fails I would say the panel is toast sorry.
    • anna1980
      • Mar 2016
      • 40
      • holland
      Thanks for the quick reply
      Ofcourse i did some research. But the thing that made me doubt was the white haze on the left. I know the dark stripes could be a bonding fault, but how does that relate to the white haze on the left part.
      Could both problems be related to a bonding fault?
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Its ok, also remove the front frame for the screen and inspect the tab bond drivers and push on a few see if it has an effect. This looks like a driver fault or even something like water damage.
        • anna1980
          • Mar 2016
          • 40
          • holland
          This one was a really bad panel. Thanks for the support
          • Stanley1843
            by Stanley1843
            06-29-2024, 11:54 AM
          • blake.s
            LG 65UJ6300-UA has blue haze and small white vertical lines
            by blake.s
            I have a LG 65 inch tv. When i turn it on it has a blue haze and slightly noticeable white vertical lines. I am wondering if this is the t-con or the panel tabs?
            08-04-2021, 01:39 PM
          • pni
            LG 49uf695v vertical coloured lines
            by pni
            Hi guys…I need your help. My cousin ask me to fix her tv. The tv when I went to pick up showed 3 horizontal black line. So I know it was a bad panel issue but I could try to fix with the tape method so I said her I could fix easy. When I come back to home, I turned on the tv and now the tv show vertical line colored….and the problem is that I unplug the ldvs cable, first the right side then the left side I still have the lines. The lines never disappear. When the right side is plug in I don’t have nothing on the screen only this vertical lines, when the right side is unplugged I have picture...
            11-14-2025, 03:15 AM
          • brad2157
            Vizio E70-E3 Two white vertical lines
            by brad2157
            I picked up a Vizio E70-E3 for free that shows Vizio logo and then goes to a black screen. Original owner said he started having wifi issues and then he tried to reset the TV and that's when it wouldn't boot up any longer after his reset attempt. I picked up a replacement main board from eBay that matches the same model # board as the original from the TV.
            Original main board - Shows Vizio logo when TV powers on, then goes to black screen. Doesn't boot up. No screen issues with any lines on start up Vizio logo.
            Replacement main board - Boots up fine, but starting...
            12-13-2021, 05:11 PM
          • Falki
            Colorful LCD Vertical Lines on Samsung ue55es8090
            by Falki
            Hello there, ive recently found an older 55inch Samsung SmartTV.
            A similar issue has been posted as well but also with no actual response ...
            08-12-2025, 04:19 AM
