Samsung ln-s3251d power cycling
  • johns1mj
    • May 2015
    • 242
    I just picked up this tv. The power light flashed 4 times and waits 13 seconds and does it again. You can hear it power down. The inverter has all the correct voltages. The main input wire has all the correct voltages. There is a second wire going to the main board from the power board. I do not know if the voltages are correct.
    24v det 5.3 v
    gnd 1.9 mv
    pwm 5 v
    adim 3.4 v
    b/l on/off 1.4 mv
    I think I am looking at an input board problem. Can anyone confirm?
    Re: Samsung ln-s3251d power cycling
    You do not have BL ON/OFF signal to turn on the backlights circuits.
    ON = >2 Vdc
    OFF = <1 VDC.
    • johns1mj
      • May 2015
      • 242
      Is that supposed to come from the Input board or the power supply?
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        From the main board (input board)
        • johns1mj
          • May 2015
          • 242
          I thought I posted but it is gone. If deleted please let me know why.
          I can't find a board schematic for this board. bn97-00810a or bn41-00679b
          • fredaelsadany
            • Jan 2016
            • 66
            • EGYPT
            hi
            inside service manual you will find schematic of the main board
            this the link
            http://elektrotanya.com/samsung_ln-s.../download.html
            good luck
            • johns1mj
              • May 2015
              • 242
              thanks
              • fredaelsadany
                • Jan 2016
                • 66
                • EGYPT
                hi
                these 2 pic for the power of samsung tv taken from the service manual .
                I think will help you
                thanks
                • fredaelsadany
                  • Jan 2016
                  • 66
                  • EGYPT
                  hi
                  link to service manual
                  good luck
                  • johns1mj
                    • May 2015
                    • 242
                    i couldn't trace the issue. Thank you for every ones support. I replaced the board and the tv is now up and running.
                    • usbdevice
                      Acer X223HQ (Version Bbd) on/off-power-cycling
                      by usbdevice
                      Hi all
                      There's two other threads about this monitor with seemingly the same problem. The problem was resolved in one case by replacing the entire PSU board and in the second one by replacing an unknown IC.
                      https://www.badcaps.net/forum/showthread.php?t=50657
                      https://www.badcaps.net/forum/showthread.php?t=40512
                      The first one has pictures of the pcbs and I noticed that there's one IC and assorted caps not populated on mine (but the PCB itself looks identical) so I thought that'd warrant a new thread.
                      It's my dad's old monitor. He...
                      08-05-2022, 02:21 AM
                    • valvashon
                      Samsung UN55FH6030: random power cycling
                      by valvashon
                      Samsung UN55FH6030, perfect size for my office and does OTA well but isn't a smart TV. That's OK because I am a TV station engineer and only need it for OTA monitoring.
                      About a month ago it started power cycling itself once or twice a day and now it's nearly continuous once it's been on for a few minutes. Changing channels would really start it cycling and it would take several minutes to stabilize but now it's just doing it almost non-stop without changing channels.
                      Once I disconnected the antenna I found that I could change channels with no issues. My guess is...
                      10-20-2023, 09:59 AM
                    • PantherDave
                      by PantherDave
                      Hi all!
                      05-29-2024, 02:01 PM
                    • high-tech
                      Samsung UN55F7050AFXZA ver. TD01 power cycling
                      by high-tech
                      Hello everybody, I could use some help on this one... It's got me guessing...
                      I took pictures of all the boards and the pin out of the connector on the power supply that goes to the main board... I measured all the pins in relation to chassis ground, here are the result.
                      (B13v)1. 12.7 volts cycling (Vamp) 2. 12.7 volts cycling
                      (B13v)3. 12.7 volts cycling (PWM5) 4. 1.0 volts cycling
                      (OD_LE)5. 2.8 volts cycling (PWM4) 6. 0.9 volts cycling
                      (OD_ON)7. 2.8 volts cycling (PWM3) 8. 0.9 volts cycling
                      9. ground (PWM2) 10. 0.9 volts cycling...
                      09-15-2020, 03:39 PM
                    • mrtek
                      Samsung UN43NU6950FXZA No power
                      by mrtek
                      Hi
                      Picked up another TV. Samsung UN43NU6950FXZA. No power and no standBy led on. Removed back cover and:
                      Main fuse = OK
                      Back light LED = OK. Power them with aux power source
                      LED output = OK 156V
                      I do get 12 V DC out of the power supply going to the digital section but no 5V or 3.3V. PS_on voltage is only 1.8V. I have looked everywhere on the PCB , I could not find i reference for 5V output.
                      Also removed connections to panel, speakers and remote but no luck. One strange thing is that even with the LED power supply working, backlight LED do not turn on...
                      07-20-2025, 08:06 PM
