Samsung LE40M87bdx picture problem
  • vagos_89
    • Apr 2014
    • 61
    • Greece
    Hello all and sorry for my english. I have the tv above and the problem is that when i open the tv i hane no picture at all. The half picture is blue and the other is black and gradually in seconds go to black. The sound play without problem. When i coonect via vga or hdmi cable i have picture but with vertical lines in the left and some black shadows.
    I measured the voltages of power suply and are 5.6V(i think is good) and for 12 and 13V i have both 11,5V. I replace the electrolytics capacitors in the psu output but didnt change anything. I see from the schematic that the 13V goes to the inverter board which is working fine, the lamps goes on and stay on altough the 13V are 11,5V to my measurement.
    Also i must say than i replaced the t-con board of the tv and the problem remains exactly the same as before. i thought to buy another mainboard(AVboard) but because is a little expensive i would like to be sure where is the broblem before i buy.
    So, could anyone help me? Is possible to have psu or panel issue or my problem is in the mainboard? Thanks in advance!
  • vinceroger69
    • Mar 2012
    • 6714
    Re: Samsung LE40M87bdx picture problem
    sounds like a bad lcd panel too me but i guess it maybe a faulty mainboard lets see what the others have too say
    • vagos_89
      • Apr 2014
      • 61
      • Greece
      Is it possible to be lcd panel problem and when i conect vga or hdmi the picture is "clear" with lines and when i conect the TV source the picture is completely black? If its the panel the picture should not be the same in both cases?
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Need images of fault.
        • vagos_89
          • Apr 2014
          • 61
          • Greece
          The first picture is with vga, the second with hdmi, the third with AV conection.
          With the tv tuner as i say i have a half picture blue and in seconds goes and stay to black, only sound play.
          Sometimes when i change the source stays an idol behind from previous source for few seconds. Is tha possible to be faulty panel?
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            When using the AV input (photo 3) does the picture on screen remain clear of lines and display correctly when playing.
            • vagos_89
              • Apr 2014
              • 61
              • Greece
              When i connect the AV the picture have some black shadows but for a few seconds only, therln clear and its ok. But only in AV mode.
              • dick_barton
                • Aug 2015
                • 6643
                • Wales
                I would have thought that if you have a decent picture when connected through the AV input that it would be a mainboard problem. Best to see what others think.
                • vagos_89
                  • Apr 2014
                  • 61
                  • Greece
                  Also if i try without source. I have black picture in the tuner mode again. And to hdmi, vga the picture is blue with vertical lines. I don't know sometimes i can see shadow idols from previous source that remains to the picture for a while when i change the source and make me wonder that there is a possibility to be lcd panel problem.
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    I say mainboard the boards used in this set are prone to failure.
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      what is the mainboard part number
                      • vagos_89
                        • Apr 2014
                        • 61
                        • Greece
                        Thanks all for.your replies. So you suggest me to try to replace the mainboard? Is sure that the panel is ok? The mainboard is BN94-01490A
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          No one can be sure the panels ok but the signs are showing a possible mainboard issue another sign it maybe is a mainboard issue is that after a quick search i cant find any for sale in stock so this board may have a high failure rate.
                          • vagos_89
                            • Apr 2014
                            • 61
                            • Greece
                            Thanks! So i think to risk and replace the mainboard. Is threre any way to can test if is lcd panel or i should try to replace mainboard and see if the problem solve?
                              09-07-2024, 05:50 AM
                            • Rusenga
                              Samsung PS43E450A1R Picture Problem
                              by Rusenga
                              Hie techs, I have a samsung plasma TV which when plugged in shows a very dull reddish image. Tested some voltages and below is what I get:
                              Note the green light on the tcon flashes every second.
                              Power supply board:
                              PS on 0v
                              Stby 5v
                              VS CON 1.72v
                              VS ON 3.2v
                              VS 208v
                              VA. 57v
                              X buffer :
                              Svt vs 209v
                              Svt xout>flactuating between 280 to 900v
                              Y main board:
                              Svt vs. 208v
                              Svt ve. more than 1000v
                              Svt yg c More than 1000v
                              Svt yout flactuating between 400v and 1900v
                              Svt...
                              11-24-2023, 09:26 AM
                            • KYBOSH
                              Samsung UN55MU8000 - Backlight But No Picture Problem
                              by KYBOSH
                              Hello all
                              I pick this up free as a repair project for the holidays.
                              The original symptom was power cycling after 3-4 seconds with a single red light flash.
                              To remedy this I went through and unplugged each component 1x1 and discovered that when the FFC cables were disconnected the backlights stayed on and the TV did not reboot.
                              I tried remove one or the other to see which side of the display was causing the issue (expecting to see half a picture to show) but didn't see anything. But the boot loop only appears when the top FFC cable (right side...
                              12-21-2022, 12:42 AM
                            • Mgiffune
                              by Mgiffune
                              06-09-2024, 10:28 AM
                            • Dodgethis
                              Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                              by Dodgethis
                              Hello all,
                              This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                              09-11-2024, 07:39 AM
