samsung UN55ES6500 left side screen issues
  • tampoon
    • Oct 2016
    • 7
    (moving this to its own thread)
    got the tv in 2013, working great to now. wife was using it during the day ( i was not home) turned off to pickup kiddo at school came back says she thinks i made a noise and then the issue happend
    problem is on only the left side of the screen. right side is normal. in fact if you cut the tv in to vertical 1/4th's the left most has a normal lighting but is interlaced horizontally with black lines and come dim color and animation ghosts in this area the left middle no ghosting but is very dim, right mid and right most both look norm. back light seems to be good across the tv.
    after reading on here a bit i tested disconnecting the t con board and powering up screen looks good totally black back lights are all on no images persist on the screen. reconnect the t-con and back to my problem state.
    i have experience with repairing several electronics but mostly just component boards not so much with testing caps and power bars and such. mostly have worked with pc's and game consoles first time getting inside a tv like this
    looking for someone else who might have some since of what could be the root of this.
    thanks for any help. can post pictures if helpful.
  • nwcs
    • Dec 2015
    • 311
    • usa
    Re: samsung UN55ES6500 left side screen issues
    Mine has the same issue. Did you ever figure out if it was the tcon or panel.
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Images of fault ?
      • nwcs
        • Dec 2015
        • 311
        • usa
        first picture is with both ribbons on tcon hooked up the second one is the right side unhooked as you look at the back and the third is the left side unhooked.
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          I would say panel failure sorry.
          • nwcs
            • Dec 2015
            • 311
            • usa
            I am inclined to agree but was hoping that maybe someone found the tcon to be the problem.
            • Andrew F. Ali
              • Jan 2014
              • 2450
              • Trinidad & Tobago
              Since removing one side of T-CON ribbon causes the whole screen to show dark it says that your panel/screen is definitely defective.
              • nwcs
                • Dec 2015
                • 311
                • usa
                Thanks, that helps put the nail in the coffin.
                • nwcs
                  • Dec 2015
                  • 311
                  • usa
                  So by chance does anyone think removing the tabs from one side might fix it? If so would it be the right side that is bad?
                  • Andrew F. Ali
                    • Jan 2014
                    • 2450
                    • Trinidad & Tobago
                    No...I tried that once....it didn't help....sorry
                    • nwcs
                      • Dec 2015
                      • 311
                      • usa
                      Based on what I have found I want to try. What is the harm. Anyway I presume that I should remove the tabs from the left side but want to make sure first. Can anyone confirm this.
                      • martino
                        Not so "senior"
                        • Aug 2013
                        • 997
                        • canada
                        Is there a small print board on the panel where the tcon tabs go into? If so might be worth while to measure for a shorted cap on that?
                        Proud owner of dozens of broken TV's and many,many,many boards.
                        Our website and passion:http://hollenhundshepherds.com/
                        • nwcs
                          • Dec 2015
                          • 311
                          • usa
                          I will check next week, thanks.
                          • nwcs
                            • Dec 2015
                            • 311
                            • usa
                            Well found one capacitor shorted c01 on the right hand side tab but I have no idea what the value of it is.
                            • martino
                              Not so "senior"
                              • Aug 2013
                              • 997
                              • canada
                              first just remove the cap and see if short is gone on the board,then turn on tv and try it?
                              • ReeceyBurger123
                                Never Give Up !
                                • May 2014
                                • 7325
                                • Britain
                                Im liking your effort here, maybe remove ones near it and find their value ? Quite low voltage Id say as well.
                                • budwich
                                  • Jul 2015
                                  • 3097
                                  go to the board on the other side and measure the one there .... :-)
                                  • nwcs
                                    • Dec 2015
                                    • 311
                                    • usa
                                    Pulled the capacitor and the short was still there and promptly lost the capacitor. Problem changed, now I only have lines in video on about 1/4 of the side and video is tripled.
                                    • ravi_1617
                                      HCL Laptop SCREEN SIZE SHRINK LEFT SIDE AROUND 2 INCHES
                                      by ravi_1617
                                      Hello to all ,
                                      I have this HCL ME LAPTOP K 41 ,screen image is shrieked clock /speaker left side approx. 2 inches .Its 14.1 LCD SCREEN. I have replaced lcd screen ,found no difference
                                      Its blank that area blank and bottom of Task bar is rolled at bottom displaying top portion image . In bios /setup also getting same problem
                                      on external VGA port image is perfect /normal , Attached image...
                                      07-25-2025, 12:07 AM
                                    • kca
                                      by kca
                                      Hello all ~
                                      08-31-2025, 06:38 AM
                                    • jkruns
                                      M1 A2338 screen and touchbar issues after cleaning up liquid damage
                                      by jkruns
                                      This is my first post after browsing this wonderful treasure trove of knowledge for many, many evenings. I've decided to learn how to fix these things, properly.
                                      My patient is an A2338 Macbook Pro M1 (late 2020).
                                      It had some corrosion around JT710 and JT700 caused by liquid spill, as well as against the protective barrier around the USB-C chips UF000 and UF100. So I took the main board out and cleaned it with a toothbrush and alcohol, then with alcohol in an ultrasonic cleaner. Cleaned the touchbar flex connectors as well. The board looks...
                                      04-22-2024, 06:45 AM
                                    • Ryan.man
                                      by Ryan.man
                                      02-04-2025, 12:23 PM
                                    • howardc64
                                      by howardc64
                                      Problem
                                      08-04-2024, 10:36 PM
