JVC EM32TS LED - No Display, yes backlight
  • mikeyd
    • Jun 2016
    • 21
    I'm new to TV repair. Thanks for any and all help.
    I have this LED TV that lights up, but the screen stays black. I can tell the backlight or leds come on though, but no image. I can't find a service manual for it. Any help or direction on this one?
  • mikeyd
    • Jun 2016
    • 21
    Re: JVC EM32TS LED - No Display, yes backlight
    at J14 (connector next to the input)
    pins
    1: 5v
    2: 0
    3: 0
    4: 0
    5: 3.3v
    6: 5v
    7: 0
    8: 1.5v
    i'm sure one of those is my PS on but nothing is labeled.
    • Diah
      • Feb 2013
      • 6614
      did you have sound ?
      BTW you need to seated the LVDS cable which go out from Boards to LCD, its wrong show on the photo
      • mikeyd
        • Jun 2016
        • 21
        on the photos i didn't have any of the cables connected. i had already unplugged everything before remembering to take photos lol.
        i did not test sound. i can hook something up real quick to play a movie so sound comes through. let me go check
        • Diah
          • Feb 2013
          • 6614
          on photo no 5 the LVDS siting just one side... this will make more damage
          • mikeyd
            • Jun 2016
            • 21
            yes, that was just because i laid the board in there just for a photo. i unhooked the cable.
            and i cannot test sound because I cannot change the input on the tv because I cannot see the display.
            i did notice some vertical lines where the channel numbers were
            • Diah
              • Feb 2013
              • 6614
              its complex to trouble shoot ,, as the boards all in one. but one things you can do,, take the boards out.. and with yours DMM on Diode peep ton method check all SMD component No started with FB they are fuseable SMD parts.
              good lucks
              • AcGeorgiegirl
                • Jun 2013
                • 203
                Just a quick thought to help....use either the remote or the tv's control buttons to cycle through inputs...you don't have to see them on screen...just listen as you have a dvd, a tv channel, etc, playing until you hear sound. If you've cycled through as many connects as you know you have, then probably no sound working.
                • vidrio jalisco
                  • May 2016
                  • 12
                  • mexico
                  hi friends, by chance, some of you have the eeprom file,
                  buy a logic board, and this came with inverted image, and I can not find information anywhere,
                  This great forum has taken me out of many troubles,
                  thanks
                  • vidrio jalisco
                    • May 2016
                    • 12
                    • mexico
                    I leave the wrong file, someone can work,
                    • koka0011
                      • Apr 2013
                      • 30
                      • Sri Lanka
                      check voltages on led panel driver board.check VGL/VGH/HAVDD/AVDD/3.3v/1.8v
                      specially the VIN voltage
                      • Martin Serrano
                        • Sep 2023
                        • Estados Unidos
                        Necesito Service Manual Panasonic Led EM32TS
                        • pni
                          Backlight panel diffuser melt by backlight leds broken
                          by pni
                          Hi guys, I changed my backlight to a 5g in Samsung but the broken leds burned the thick plastic panel . I give the photo. Do you think if I try to rotate the panel, with the botton on the top I have a good image? Becacause now how u can see, on the light color I sse the leds because of the burned on the plastic diffuser....
                          10-12-2025, 12:08 AM
                        • lanovey
                          SF314-41 BIOS without internal display
                          by lanovey
                          Hello there,
                          I have a SF314-41 motherboard that i bought impulsively recently, the problem is that i only bought the motherboard only, nothing else. When i tried powering on the board with 19V (soldered on the DC IN port), and then shorting the pin 1-2 of the keyboard, the board is turning on (as indicated by the fan), however it seems like the board is displaying on the internal display as connecting to a display on the HDMI (external) does not display anything.
                          I tried connecting a USB keyboard, the keyboard is powered on, however pressing numlock do nothing (supposed to toggle...
                          06-13-2025, 02:38 AM
                        • howardc64
                          by howardc64
                          Problem
                          08-04-2024, 10:36 PM
                        • dbuergi
                          Acer XF240Y display backlight on and off then stays on but no display
                          by dbuergi
                          my display shows some strange bevahior. The backlight turns on, off and then stays on but i get no display or Acers logo. After some time it goes into standby. My notebook identifys the screen when i connect it by HDMI but i don't get an image.
                          Voltages seem n​ormal and the only possible problem i found is the cap on C33 on the tcom board. It shows 0 Ohm and 0V in diode testing. Any ideas for next steps or what i can check?...
                          11-14-2024, 04:36 AM
                        • howardc64
                          Insignia NS-43D420NA20 backlight on no display - LCD panel burn failure
                          by howardc64
                          Eventually discovered a burn mark near lower corner of LCD. Here is a summary
                          • Backlight on, no image
                          • Disconnect right buffer board (view from front), left side display comes on
                          • Masked off pin 7+8 (both ~12,5v on both left and right buffer board) from t-con to right buffer board (view from front) display works but have some lines
                          • Buffer board is pretty simple
                          Removed the front bezel to examine edge of the glass. Found burn mark on lower right (view from front). Plastic bezel covering the burn mark region shows heat signature on the inside surface facing the LCD panel. Last 2 pics. Bright...
                          07-11-2025, 04:04 PM
