LG 55LE5500 with main board EBU60904803
  • jason123
    • Oct 2015
    • 1108
    I'm hoping someone came across this issue.. I have an LG 55LE5500, that all of a sudden went blank (backlight is on, but no picture), audio is ok all other controls seem to be working. When you look at the screen you can almost tell there is a divide (though not a vertical line) between left and right.
    The main board on this unit is both controller and Tcon in one, expensive and not available. Reseating cables, didn't improve things. Voltages on the connector to / From Power board are all within spec +/- 1 or 2 %
    Is it worth pursuing sending the main board for repair? or is there a way to find out if it's a bad panel?
  • jason123
    • Oct 2015
    • 1108
    Re: LG 55LE5500 with main board EBU60904803
    So, I sent board to PTS Electronics for repair.. they said they can't find a problem with the board and they ran it overnight, and it's working fine on their set (I'm assuming - they just said they can't find a problem)
    Does this suggest I have a bad panel? I'm taking the panel apart and I'm doing spot checking on the LVDS Panel connector / board (Bottom Left) and I'm finding many caps that are shorted.. These are ceramic caps.. either they're shorted, or the panel is.. no way to know without removing them. Anyone know where I can find a schematic for these boards? LC550EUB Right Source_V5 - P/N 6870S-1011A
    • JeffJ
      • Apr 2012
      • 189
      Are you sure the blights are actually on? this model and similar are well known for the back lights failing and causing your issue.
      I have the next model above this, the leds failed not once but twice 4 months apart. Lg eventually released firmware that "fixed" this issue but now i sit on a tv that no leds are available for because the use market does not have a single set that works.
      • jason123
        • Oct 2015
        • 1108
        Hi JeffJ, yes, the backlight is on - I agree with you, when I bought it, I thought it was a quick edge light strip repair like the ones I've seen before .. but that's not the case unfortunately.
        • jason123
          • Oct 2015
          • 1108
          Just a quick update.. I know this is something rare, but it turned out there is a ceramic capacitor (10 uF) on the panel boards (the skinny boards that the LVDS cables from Tcon / Main card connect to) that was shorted.
          Replacing that, took care of the problem.
          • vinceroger69
            • Mar 2012
            • 6714
            Thanks for the update im sure the information may help others users too.
              Great job finding the cause of the problem.
              If you can post the picture of the bad cap that will help other people as well.
              • jason123
                • Oct 2015
                • 1108
                Sorry it took a while.. but here are some photos that will show the bad component. Replaced with a 10 uF X7R @ 16 V
                • dick_barton
                  • Aug 2015
                  • 6643
                  • Wales
                  Excellent find. Good feedback.
                  • Dani_2024
                    by Dani_2024
                    10-28-2024, 05:06 PM
                  • ygorsan
                    by ygorsan
                    🧩 Problem Summary:
                    • I
                    07-28-2025, 08:34 AM
                  • jb_Bak
                    by jb_Bak
                    CN6401
                    Pin 01 NC
                    Pin 02 NC
                    Pin 03 "BL_ON": 0V
                    Pin 04 "N/C"
                    Pin 05 "STBY 3.3V": 3.5V
                    Pin 06 "GND": N/C
                    Pin 07 "AC_OFF"...
                    09-27-2021, 04:52 PM
                  • JDC
                    (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
                    by JDC
                    ONN 100012588
                    Issue: No Power, Then Rebooting After Main Board Change
                    Short answer: replace main board and power board
                    Technical answer: replace main board and Q306 & Q307 on power board.
                    Long answer:
                    TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
                    07-15-2022, 07:39 AM
                  • m1ch43lzm
                    by m1ch43lzm
                    05-12-2025, 08:37 PM
