TCL LED backlight voltage drop
  • Alex9
    • Sep 2016
    • 18
    Re: TCL LED backlight voltage drop
    LED tester connected to pins 5 or 6 and pins 1 or 2 all light up the board at 60v. It seems 5-6 and 1-2 are connected.
    I tested pin 2 again to see if the readings match pin 1 and got these readings:
    24v, .9v (with BL flash), 1.5v
    The tv came on with full backlight for about 20 seconds this morning when I plugged it in.
      I am confused, if you pull the female connector of the board then use the tester between pin 2 and either pin 5 or pin 6 of the female connector and you see the tester shows 24v, .9v (with BL flash), 1.5v?
      Pin 1 and pin 2 will be tied together only when it is plug into the male connector of the board, same for pin 5 and pin 6.
        BTW, the panel is still apart so you can actually see the LEDs?
        • Alex9
          • Sep 2016
          • 18
          Sorry, I had the tv put together due to lack of working space. I just took it apart though.
          strip 1 is 19.3v with 7 LEDs
          strip 2 is 22v with 8 LEDs
          strip 3 is 19.3v with 7 LEDs
          They appear to be connected in Series.
          Soooo I put it all back together and for some reason the backlight is staying on now. It's been 10 minutes already without turning off. The only thing I can think of is that I disconnected each LED strip from each other to test them individually just now and maybe reconnecting one of them fixed a loose connection problem? I don't know what to say except that I'll post back if it stops working?
          • Alex9
            • Sep 2016
            • 18
            The backlight just went out again. It happened when I connected a vga cable between it and my computer. Not sure if that's related or a coincidence.
            • Diah
              • Feb 2013
              • 6562
              i would suggest you to connect all the Cable direct on the LED strips jump the sockets .. , its more safe for future and best way to be sure all connection exist.
              • frankrizo
                • Mar 2020
                • usa
                #27
                So I have a simaliar problem, I think its the power supply board, I dont have a tester to test all the led strips. my voltage, with led conector unplugged, starts at 100 and drops to 35 volts dc. then stays there, with and without led connector connected.
                Bad Cap??? Father in law had his tv do the same thing, his was a 2 amp part the guy replaced, part was 2 pounds, labor was 80....
                anyway. if you need photos, how do i upload?
                and, how do i test led strips without an led tester? i do have some things around the house...maybe to test them...
                hope someone can help.
                cheers
                frank
                  cheers
                  frank
                  The LED drive Voltage went up to 100V and then dropped down to around 35V because the circuit detected no load, you have open circuit in the LED strings some where.
                  • m1ch43lzm
                    by m1ch43lzm
                    05-12-2025, 08:37 PM
                  • howardc64
                    by howardc64
                    Problem
                    08-04-2024, 10:36 PM
                  • howardc64
                    by howardc64
                    07-24-2025, 05:17 PM
                  • Yanleb
                    Vizio M70-D3 4K with dark spots backlight issue
                    by Yanleb
                    I have a Vizio M70-D3 4K with a dark spots backlight issue. It is using the Y8387248A backlight driver board.
                    On this model each of the 64 transistor powers 2 LEDs. Using my TKDMR TD3H backlight tester I've determined that the backlight LED strips were the issue, and the backlight driver board was just fine. Some LED pairs required 5.9 volt at 155mA, some required 9.5 volt and some were completely open.
                    I've removed the LCD panel and once the LED strips were exposed I've tested them again by connecting my LED tester directly on the test pads. To my surprise all, I've...
                    03-22-2022, 01:06 AM
