Samsung 50" TV flashing power light
    Re: Samsung 50" TV flashing power light
    let's see if this get's the ball rolling. The 6270 has the same PSU, the main is different but potentially the same pin outs, maybe the flow charts will help too
      Ok thanks will look at them
        You know, so far we still do not see the pictures of YOUR boards and how all the boards are connected together.
        BN44-00617A
        Shopjimmy does not have the pictures for me to look at either.
        So far it look like it has two set of LED power supplies.
        Those two service manuals do not show anything much about the power supply/LED driver board.
        I need to see the chart of the power supply board connector pins.
          The 2 main boards are shown in post 21
            I have one picture showing the layout but cannot find how to do the attachment, can anyone help
              You've managed to do this in past posts?
              "Advanced", "manage attachments" "choose file", "upload" "submit reply"
              resolution no bigger than 2000 x 2000
                These are the boards in this TV
                  Thanks for the information tw2005
                    theres two connectors on the power supply can you take some pictures of the writing by them then we can advise more
                      u could try to check the voltage being supplied to the leds, if it is steady
                        https://www.badcaps.net/forum/attach...6&d=1477845295
                        Picture is to blur to be able to read any printing on the board especially the charts that show what the pins of each connectors are for.
                        Just remember this, we do not have the boards in front of us to look at, the only thing we can go by are the provided the pictures, if you cannot read any prints on your pictures then we cannot read them either.
                          I hope this helps will checks the voltage later
                            The second picture is for the backlights
                              Looks like the 13v is only about 8v, the other voltage appear ok. So do I assume if the Back-lights flash with the main board disconnected, that the Power board is faulty.
                                Would be nice if some one was to leave some type of message, or to confirm my question from item 34
                                  Hi Budm, have put the info on you wanted.
                                    Anyone got a circuit diagram for a PS U board BN41-00522B, from a Samsung LE26R51BDX/XEU
                                      Hi, I have same problem B13V is about 8V so the PSU should be faultly ?
                                        Start a new thread with a description of you issue and if you did any tests what are your findings and pictures. Yes pictures so we can see what you have.
