Vizio E500i-B1 Backlight
  • 0S1R1S
    • Mar 2014
    • 48
    Re: Vizio E500i-B1 Backlight
    Okay, so here's the latest update. I ordered a 24V 6 amp power adapter from Amazon and wired it in to the 24V outputs for the LED driver on the main board. Plugged in everything else, plugged in the set and turned it on, no backlight.
    Then I plugged in the power adapter, and still no backlight, even with 24V going into the LED driver.
    I know there is the one 24V rail coming FROM the main board to the power board, could that be my issue now?
    I would just give it up and order a new power board and main board, but that would be an added cost of over $100 for parts alone and not worth it for this set.
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8326
      The 24V runs the other way. 24V get generated on the PSU and feeds the main board on both connectors. The LED driver is on the main board. Did you check the backlight LEDs yet?
      So... if you just unplugged one of the connectors and fed 24V, you also have to do that on the other one too. You also have to make sure the BLon voltage is present, which comes from the main board and gets looped trough the PSU and back to the LED driver on the main board (on/off). Back feeding 24V to the other 24V rail isn't that great idea if you left the 24V pins connected.
      Problem is right now we have no clue how exactly you had the 24V hooked in to, if the on/off signal was present etc.
      • 0S1R1S
        • Mar 2014
        • 48
        With the original power supply in the TV and no changes made at all, my friend hooked up his benchtop power supply set at 24V and injected 24V into just CN9102. Backlights came on, but they were flickering.
        I ordered a replacement power board and installed it. Backlights came on but were flickering. I wiggled CN9102 and the flicker went away. May not have been correlated.
        Turned the set on and off a few times, then lost backlights completely. The new power board will still power the set up just fine, but I've lost backlighting and the voltage has dropped from 24V to 15.5V.
        I understand at this point it's most likely a fault of the main board damaging the power supply board, but how, I don't know.
        Main boards are too expensive to install both into this set and still be a cost effective repair.
        And yes, I know with Vizios, it's very common to have LED failure. At this point I'm thinking the set is beyond a cost effective repair and I should tell them to scrap it.
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8326
          "I understand at this point it's most likely a fault of the main board damaging the power supply board, but how, I don't know."
          because the LED driver is on the main board and not on the PSU or on a separate board.
          Another cause could be that a failing LED (thus the flickering) actually did fail now and went open circuit, so the backlights are staying off. Also you have to make sure on/off (BLon) is sent from the main board, other than that the backlights stay off too.
          • 0S1R1S
            • Mar 2014
            • 48
            Okay. I understand that the LED driver is on the main board, it's the top left section of the board there. But how can that be the cause of damage to the power boards, that's what I'm curious about.
            Anyway, current status is this. TV powers on. Backlight doesn't work with external or original power supply. 15.5V is there in place of 24V on the original power board still.
            Thoughts on where to go from here?
            • CapLeaker
              Leaking Member
              • Dec 2014
              • 8326
              what is printed on IC9103?
              • tvtanner
                tvtanner
                • Feb 2014
                • 70
                • usa
                #47
                The best way to check those two rectifiers is to replace them. I think that's your problem.
                • 0S1R1S
                  • Mar 2014
                  • 48
                  Problem was the main board. After ordering one and getting an incorrect part, I received the right one, and the backlights are now working just fine. Must have been an issue in the LED driver circuitry.
                  • CapLeaker
                    Leaking Member
                    • Dec 2014
                    • 8326
                    A1! Thanks for the feedback.
                    • RADIOTRON
                      • Aug 2011
                      • 7
                      #50
                      I have a tv the same problem as this is but this is the catch if i put 24v external supply to the inverter the backlight turns on. I cant seem see a problem causing the power supply drop voltage. Even no load to it, it still 15v im reading.
                      • mmac1488
                        • May 2017
                        • 10
                        • united states
                        #51
                        I have the same problem, 15v on all 24v pins on power board, but the tv works fine. After a couple weeks of using it, I went to use it one night and it wouldn't turn on. No backlights I mean. I brought it from home to my shop where I fix them and it's now almost a month later without a single issue, but still 15v everywhere it should be 24v. I want to double check everything before I sell it.
                        • mmac1488
                          • May 2017
                          • 10
                          • united states
                          #52
                          I get 400v at the main caps, no change in voltage with main board, led connector or anything else unplugged.
                          • mmac1488
                            • May 2017
                            • 10
                            • united states
                            #53
                            I do hear a very faint high-pitched sound from the area on power board where the side by side transformers are, but I've only noticed it since I've removed the board from the chassis and plugged it in. Any suggestions would be appreciated. I've been reading these threads for years now, you guys have walked me through quite a few repairs over the years. You guys are very, very much appreciated for your time and knowledge. Thank you
                            • keithsipa
                              • Apr 2018
                              • 7
                              • usa
                              #54
                              I dont think it is a problem with the power supply. Had a problem with one of these not turning on when warm. The 15.6V on the 24V line has been reported in a few threads, the general consensus was a misprint on the board, I think.
                              This is what I had seen.
                              https://www.badcaps.net/forum/showthread.php?t=68882
                              Replaced the power supply fixed the problem for me, but the 15V on the 24V rail remained the same, even with the new board and the TV is still working like a champ.
                              • Tynan Dill
                                by Tynan Dill
                                Assuming...
                                11-22-2024, 01:46 PM
                              • m1ch43lzm
                                by m1ch43lzm
                                05-12-2025, 08:37 PM
                              • C152Heavy
                                Samsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
                                by C152Heavy
                                Summary for TL-DR readers:
                                • Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
                                • Have obtained Samsung schematic & service documents - Can upload if helpful.
                                • Have read ALL applicable threads
                                • C1818 and CP820 replaced as low hanging fruit
                                • CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
                                • VCC pin (18) of PFC...
                                01-11-2023, 02:53 PM
                              • howardc64
                                by howardc64
                                07-24-2025, 05:17 PM
                              • ermals
                                Samsung UN55H8000AF - No Picture, Working Backlight, Replaced T-Con Board
                                by ermals
                                Hi all!
                                I've recently run into an issue with my Samsung UN55H8000AF LED TV displaying no image. I've done quite a bit of research in terms of what could be wrong with it. Below are the steps I've taken prior to reaching out here for some assistance:
                                1. I've tried replacing the T-Con board (BN95-01594A), twice and have still experienced the same issue with all the boards I've tested with.
                                2. I've tried to remove one side of the ribbon cable that goes from the T-Con board to the panel and still not getting any image on left or right side.
                                3. I've checked voltages...
                                08-01-2022, 10:35 AM
