Hey all,
I am by no means an electronics technician, but more of a jack of all trades. That being said, I am looking for some experts in the field to help me out with what I should be doing next to troubleshoot.
I have a Vizio D500-Bi that if unplugged or not turned on for a while (1 hour perhaps) it will start and work fine, until it is turned off.
Once the TV is shut off, it will not turn on again, however the stand-by light will light up and there is 5v at the stand-by pin on the power supply. If I try to turn it on immediately there is no sigh of life at all, other than the the standby light illuminating.
If I unplug the TV for 10 or 20 minutes. Then try to power it on, the big V will appear for a very short amount of time on the screen, then the screen will go black. There is no blacklight, and when I try the flash light test, there does not appear to be any image on the screen.
If I leave the TV unplugged for a while (around an hour or longer) the TV will turn on and work as normal. Then the same thing happens again, if I turn it off.
I have disassembled and looked at the power supply and main board and there are no obvious signs of any problems on any of the boards.
What are the first steps to take. When I had the back off of the TV, I had probed the voltages at the power supply to the mainboard, the standby voltages were a steady 5v, pins 15 and 16, pins 11-14 seemed to be running around 15V while the TV was working fine.
Any help would be appreciated guys.
