Sony Bravia KDL-40EX403
  • finntricky
    • Jan 2014
    • 449
    Ok guys, got this tv in with stand by light flashing 7 times and then repeating, done a bit of reading and found out that main board was faulty,
    replaced the board with another and now get solid stand by, but when i turn it on, the green and amber lights flash together non stop,
    i did read somewhere on here about the problem and it was 2 mosfets and a fuse-able resistor that was replaced and solved the problem, so i checked this out and mine are fine.
    im also getting 24v at the inverter as well, but back light are not turning on,
    i need some help on where to go now, as power board volts all seem ok ?
    ill get some pics up ASAP.
  • finntricky
    • Jan 2014
    • 449
    Re: Sony Bravia KDL-40EX403
    quick update, rechecked volts and jumped the standby and power on, now got back lights,
    it would seem that i have been sold another faulty main board,
    or have i ?, i have no volts for the T=CON on, from power supply
    • finntricky
      • Jan 2014
      • 449
      some pics
      • CapLeaker
        Leaking Member
        • 8352
        We need the voltages with the corresponding pin outs. Maybe one with everything attached to the PSU, the other only the PSU by itself forced on. There is a Tcon on pin and a TCon power. So in order to get Tcon power, you have to turn it on, like PSon and BLon.
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          May also be worth checking those orange looking resistors which I believe are fuses.
          • finntricky
            • Jan 2014
            • 449
            hope you can understand these,
            pic 1 is in stand by., pic 2 is turned on with flashing green and amber lights,,
            pic 3 is power supply jumped on, pic 4 is pic 1 and 2 together.
            as you can see, im already getting the power on signal from the main board while in stand by.
            • flocko
              • Nov 2012
              • 1121
              The main boards on these Sony set are awash with SMD fuses on the front and rear , I would carefully check these first,and use a marker to mark the ones as you go
                And they are VERY SMALL and hard to see.
                • finntricky
                  • Jan 2014
                  • 449
                  UPDATE,
                  got a full refund on the main board i got from EBAY, have'nt even got to send it back, RESULT, and have ordered another one, just have to wait and see,
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4542
                    • Italy - Milan
                    Why don't you try to repair the original one in the meantime? Wich research have you got on it? Only manuals&internet searches?
                    • finntricky
                      • Jan 2014
                      • 449
                      when it comes to main boards, i lose interest and give up, so trying to repair is not for me.
                      • CapLeaker
                        Leaking Member
                        • 8352
                        Mainboard isn't sending BLon.
                        • JUCaESAl
                          Sony bravia KD-65AF9
                          by JUCaESAl
                          Hola a todos, necesito el esquema electronico de la placa 1-983-356-11 de un televisor sony bravia KD-65AF9.
                          Hello everyone, I need the electronic diagram for the 1-983-356-11 board of a Sony Bravia KD-65AF9 television.
                          10-20-2025, 04:03 AM
                        • PopsCaps
                          Sony Bravia KDL-40V2500 that will not power on
                          by PopsCaps
                          I have a Sony Bravia KDL-40V2500 that will not power on. The indicator flashes red 3 times.
                          I do not hear any sound and I cannot see any backlight.
                          I have tried disconnecting every cable on each board one at a time to see if anything changes.
                          The only change is when I disconnect AC-DET cable on the Power Supply board or on the other end if I unplug the CN7009 connection on the B-Board and try to power on the TV the indicator will stay on solid green until I power off.
                          My friend ordered another used power supply board but it is also doing the red indicator flash 3 times...
                          03-25-2025, 11:23 AM
                        • alegatorul
                          sony bravia kdl-43w756c, no power, no sound
                          by alegatorul
                          the charger brick has 19,2-19,3 vcc
                          changed the inverter board same result.
                          where should i start?
                          cheers
                          11-15-2025, 10:00 AM
                        • justin35
                          Sony bravia kdl-43w755c - boot loop
                          by justin35
                          i have this sony bravia kdl-43w755c which boot loops. After sony logo, it shows the android animation loading then it restarts…
                          from what i read online it looks to be an emmc issue…
                          i’m not familiar with this kind of tv repairs… i’m repairing laptops and gpu’s…
                          i took out the board and say an samsung 16gb emmc
                          i don’t have an exact replacement, but i have a few 32 and 64gb emms’s from laptops…
                          i could try to put one instead of the 16gb one, but will it work?
                          where do i get the software from?
                          any help will be much appreciated!...
                          03-06-2024, 12:26 PM
                          Sony Bravia 22" LED Full HD TV KLV-22P402B Schematic
                          Sony Bravia 22" LED Full HD TV KLV-22P402B Schematic...
                          10-16-2024, 05:15 AM
