Sony Bravia KDL-40EX403
  • finntricky
    • Jan 2014
    • 449
    Ok guys, got this tv in with stand by light flashing 7 times and then repeating, done a bit of reading and found out that main board was faulty,
    replaced the board with another and now get solid stand by, but when i turn it on, the green and amber lights flash together non stop,
    i did read somewhere on here about the problem and it was 2 mosfets and a fuse-able resistor that was replaced and solved the problem, so i checked this out and mine are fine.
    im also getting 24v at the inverter as well, but back light are not turning on,
    i need some help on where to go now, as power board volts all seem ok ?
    ill get some pics up ASAP.
  • finntricky
    • Jan 2014
    • 449
    Re: Sony Bravia KDL-40EX403
    quick update, rechecked volts and jumped the standby and power on, now got back lights,
    it would seem that i have been sold another faulty main board,
    or have i ?, i have no volts for the T=CON on, from power supply
    • finntricky
      • Jan 2014
      • 449
      some pics
      • CapLeaker
        Leaking Member
        • 8326
        We need the voltages with the corresponding pin outs. Maybe one with everything attached to the PSU, the other only the PSU by itself forced on. There is a Tcon on pin and a TCon power. So in order to get Tcon power, you have to turn it on, like PSon and BLon.
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          May also be worth checking those orange looking resistors which I believe are fuses.
          • finntricky
            • Jan 2014
            • 449
            hope you can understand these,
            pic 1 is in stand by., pic 2 is turned on with flashing green and amber lights,,
            pic 3 is power supply jumped on, pic 4 is pic 1 and 2 together.
            as you can see, im already getting the power on signal from the main board while in stand by.
            • flocko
              • Nov 2012
              • 1121
              The main boards on these Sony set are awash with SMD fuses on the front and rear , I would carefully check these first,and use a marker to mark the ones as you go
                And they are VERY SMALL and hard to see.
                • finntricky
                  • Jan 2014
                  • 449
                  UPDATE,
                  got a full refund on the main board i got from EBAY, have'nt even got to send it back, RESULT, and have ordered another one, just have to wait and see,
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4460
                    • Italy - Milan
                    Why don't you try to repair the original one in the meantime? Wich research have you got on it? Only manuals&internet searches?
                    • finntricky
                      • Jan 2014
                      • 449
                      when it comes to main boards, i lose interest and give up, so trying to repair is not for me.
                      • CapLeaker
                        Leaking Member
                        • 8326
                        Mainboard isn't sending BLon.
                        • PopsCaps
                          Sony Bravia KDL-40V2500 that will not power on
                          by PopsCaps
                          I have a Sony Bravia KDL-40V2500 that will not power on. The indicator flashes red 3 times.
                          I do not hear any sound and I cannot see any backlight.
                          I have tried disconnecting every cable on each board one at a time to see if anything changes.
                          The only change is when I disconnect AC-DET cable on the Power Supply board or on the other end if I unplug the CN7009 connection on the B-Board and try to power on the TV the indicator will stay on solid green until I power off.
                          My friend ordered another used power supply board but it is also doing the red indicator flash 3 times...
                          03-25-2025, 11:23 AM
                        • justin35
                          Sony bravia kdl-43w755c - boot loop
                          by justin35
                          i have this sony bravia kdl-43w755c which boot loops. After sony logo, it shows the android animation loading then it restarts…
                          from what i read online it looks to be an emmc issue…
                          i’m not familiar with this kind of tv repairs… i’m repairing laptops and gpu’s…
                          i took out the board and say an samsung 16gb emmc
                          i don’t have an exact replacement, but i have a few 32 and 64gb emms’s from laptops…
                          i could try to put one instead of the 16gb one, but will it work?
                          where do i get the software from?
                          any help will be much appreciated!...
                          03-06-2024, 12:26 PM
                          Sony Bravia 22" LED Full HD TV KLV-22P402B Schematic
                          Sony Bravia 22" LED Full HD TV KLV-22P402B Schematic...
                          10-16-2024, 05:15 AM
                        • Spc.
                          Sony Bravia KD43XF7596BAEP - Android no picture
                          by Spc.
                          Greetings everyone.
                          I also have Sony Bravia, model:
                          Sony Bravia KD43XF7596BAEP - Android.
                          What happend is that image dissapeared while we were watching tv.
                          Diagnostics:
                          1. TV turns on, no errors
                          2. Backlight turs on, no errors
                          3. Power indicator turns on, white color, no errors
                          4. Menu works on android, you can hear sound while switching channels
                          5. Volume up and down works via TV remote and via buttons
                          6. Tunner works, HEVC / MPEG-4 decoder works
                          7. I get audio from channels
                          8. No picture is present,...
                          05-19-2022, 04:28 AM
                        • dominik0801
                          SONY KDL-43W755C | 5 blinks stand-by LED
                          by dominik0801
                          Hello guys.
                          Today I got this TV for free, the friend included a "new" (used) TCON with it, since he told me, that doesn't work either.
                          With the stock TCON, this TV turns on, stays on, but the screen only has 5 RED vertical lines on it, and that's it.
                          Backlight stays on and is fine.
                          With the "new" TCON, the TV turns on, shows SONY logo, some spinning circles, then the TV goes blank, and the stand-by LED is blinking 5 times, won't react to anything.
                          I have read some forums, where it's been told that the part number is not always enough...
                          12-18-2023, 11:40 AM
