hey guys working on a vizio m3d650sv for a local pawn shop and originally started with 3 vertical lines on right hand side...shop ordered a tcon board & they installed and lines were still there...then after having them switch the 4 ribbon cables around lost all picture including backlights...i went back to troubleshoot & noticed that when you disconnect the red wired cable from either tcon or inverter board you regain backlights...after doing some research i've concluded that this is probably a tab bonding issue in reference to the lines but as far as the backlight issue do you guys have any ideas for me? appreciate all information shared
vizio m3d650sv panel questions
Re: vizio m3d650sv panel questions
If the backlights were working BEFORE switching the ribbons cables around then it may mean that the cables were not put back in place properly, they can be real tricky some times.
As far as Vertical lines on the screen, I do say it is the panel problem.Never stop learning
Originally posted by BestAmusementsFL View PostThe 4 ribbon cables are identical...same pn on all 4...can they not be switched around?Craigslist Picks & Fixes
2 ea - Samsung 52"
Samsung 60"
