Sanyo DP26647 - Pls help me diagnose it
  • lkvee
    • Feb 2009
    • 198
    Plug it in, hit the power button, and I hear a faint click (relay?), but no LED and no backlighting. Failed to see image.
    T4AH/250V fuse is intact.
    No voltage of any kind going to the inverter.
    Pins 4 and 5 to the video board generate 5.13 V
    Pins 8 and 9 to the video board generate 0.167 V
    All other pins to the video board show zero.
    No caps look bulged. None are from the notoriously bad brands.
    Not sure whether to continue looking elsewhere or whether to just replace all caps or do something else.
    Re: Sanyo DP26647 - Pls help me diagnose it
    There are labels for each pin of the connectors to tell us what they are, so you must put down the pin name and follow by the DCV reading when TV is plugged in but the power switch is NOT activated, and then the readings when the power switch is activated so we can easily see what are missing.
    Pin names are at the bottom side of the board.
    I.E.
    Voltage reading: OFF/ON
    Pin 1, +24V = ?? V/???V
    Sanyo 1AV4U20C09700 (DPS-161AP-1 ) Power Supply for DP26647
    http://www.shopjimmy.com/sanyo-1av4u...er-supply.htm#
    Pictures provided by shopjimmy.
    BTW, there is no relay on the power supply board.
    • lkvee
      • Feb 2009
      • 198
      Thanks for the feedback. I looked at the pics, and I tested DCV when the TV's plugged in, but the power button was not activated. I also tested after hitting the power button.
      I used a flashlight but still wasn't able to find an image. I did see something that looked like the faintest flicker of backlighting, before going back to black.
      The pins had these labels:
      24V
      24V
      GND
      GND
      12V
      12V
      GND
      GND
      5V
      5V
      GND
      GND
      PSON
      DCV after plugging in only:
      0.10
      0.10
      0
      0
      0.167
      0.168
      0
      0
      5.13
      5.13
      0
      0
      0.09
      DCV after hitting power button:
      24.40
      24.39
      0
      0
      11.88
      11.88
      0
      0
      5.13
      5.13
      0
      0
      4.79
      I placed the ground lead not on a ground pin, but on a metal plate.
      Still not sure what to examine next, but I'm starting to wonder about the mainboard.
      • R_J
        • 9561
        Check your backlight inverter, there should be a couple fuses on it, remove the shield and post a couple pictures of it
        • corrize
          Where to find a very small fpc connector 0.3mm between 2 pins ?
          by corrize
          Hello, I search this connector (oxydated).
          It's a fpc zif low profile connector. It come from camera sensor, it is very small : 0.3mm between 2 pins.
          I ordered 2 from Aliexpress called « 0.3mm pitch » but one was 0.5mm between 2 pins and the other 0.6mm. In fact « 0.3mm pitch » seams to be the pad width and not the distance between 2 pins.
          I can't find it. The other websites like mouser dont show the datasheet, and I can't check if it is 0.3mm between 2 pins ?
          Do you know how to find this connector please ? What is the exact name for find it ?
          08-06-2024, 05:25 PM
        • SS454
          vizio e650i-a2 backlight flashes then turns off
          by SS454
          vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
          panel: au optronics T650HVN05.4
          72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
          link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
          Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
          https://www.shopjimmy.com/vizio-56-0...-power-supply/
          Vizio 55.75J01.001G (91.75J10.004G) Main Board...
          08-20-2020, 03:57 PM
        • DominanceINC
          MSI Pro Z790-P Wifi 1missing CPU pins
          by DominanceINC
          I am a new forum member. I found a broken MSI motherboard with lot of problems. The other problems need schematic. Because, the missing parts what were breaking down with screwdriver and pliers at a standoff.
          So, its actual problem is a missing Vcore and Gnd pins in the CPU socket. My question is that, can it be used safely without these two pins? Only for testing at first, while the other problems will be solved. I would wish repair them later.
          The other spots are thermal phaste, because, the under educated installer of the CPU did wipe the contacts of the...
          07-21-2025, 05:38 AM
        • corrize
          How to diagnose little step down and power management BGA chips never shorted
          by corrize
          I have different sort of those little BGA chips (step down DC-DC, power management battery, …) I replaced 10 on differents mobile devices (no schematics) but I noticed often they can be dead but never shorted. I see some signs : burn marks, resistance drop by comparison with good board (40 KOhms to 1 KOhms for example)… but not easy to be sure of the diagnose. Because I can't access on all tracks (balls) with the meter.
          Sometime, I know only after replacing chips.
          Do you have tips for diagnose please ?
          05-02-2024, 08:30 AM
        • cj_reha
          Mystery 80s Sanyo cap - perhaps polymer?
          by cj_reha
          Hey all I've been working on a 1984 Sanyo 27" color TV which had a smattering of bad caps in the video switching circuit. I found this oddball little 1uF 25V cap which looks to me like an early polymer, but I can't find concrete info proving it. I know Sanyo was a big player in early polymer cap development and this is the time period where they were just getting on the market, so I'm wondering if anyone has crusty old datasheets that could help identify it and determine if my suspicions are right? It has the same epoxy end seal and font/formatting as some old stock Os-Cons I've got laying...
          01-06-2023, 09:24 AM
