I have a request. Kinda ashamed to even have to ask this. I was helping a friend repair bad LED strips on this set. We were successful. FOUR bad LED..on 4 different strips. BUT...upon re-assembly..SOMETHING went wrong. This has NEVER happeend to me before--and I have successfully done a number of BL repairs, both LED and CCFL.
We put all of the successive layers back behind the panel...checked the BL.. BEFORE re-assembly...and NOW.. you can EASILY see a BUNCH of the individual led's as "bright spots. with the panel on ..it DOES show BADLY.
We had the sheets lying on each other--in the order they came off...I THOUGHT at least. First...the "frosted" sheet went over thre BL. Then the "prismatic sheet" then the other somewhat frosted sheet, but darker than the first. FInally, the plastic diffuser..over which went the panel.
Is this RIGHT_-or is it BACKWARDS ? I have NEVER had this problem before..when i did this MYSELF. I ALWAYS sat the sheets on top of each other in the order they came off. THIS time...I THINK they may have gotten " mixed up"...they fell and may have gotten mixed up... Does the diffuser go lAST.or FIRST...over the BL or is it right behind the PANEL?
I messed up..now..I have to figure out where. Set is FIXED...just has the OBVIOUS "bright spot" issue..
