an embarassing question (LG, 47LB5900 I think)
  • RCA2000
    • Sep 2014
    • 111
    I have a request. Kinda ashamed to even have to ask this. I was helping a friend repair bad LED strips on this set. We were successful. FOUR bad LED..on 4 different strips. BUT...upon re-assembly..SOMETHING went wrong. This has NEVER happeend to me before--and I have successfully done a number of BL repairs, both LED and CCFL.
    We put all of the successive layers back behind the panel...checked the BL.. BEFORE re-assembly...and NOW.. you can EASILY see a BUNCH of the individual led's as "bright spots. with the panel on ..it DOES show BADLY.
    We had the sheets lying on each other--in the order they came off...I THOUGHT at least. First...the "frosted" sheet went over thre BL. Then the "prismatic sheet" then the other somewhat frosted sheet, but darker than the first. FInally, the plastic diffuser..over which went the panel.
    Is this RIGHT_-or is it BACKWARDS ? I have NEVER had this problem before..when i did this MYSELF. I ALWAYS sat the sheets on top of each other in the order they came off. THIS time...I THINK they may have gotten " mixed up"...they fell and may have gotten mixed up... Does the diffuser go lAST.or FIRST...over the BL or is it right behind the PANEL?
    I messed up..now..I have to figure out where. Set is FIXED...just has the OBVIOUS "bright spot" issue..
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: an embarassing question (LG, 47LB5900 I think)
    Are the bright leds you can clearly see the replacement leds?
    • RCA2000
      • Sep 2014
      • 111
      No...you can see most all of the LED's..depending on the ANGLE..at which you look at the set.. Now..a LOT of those fragile lenses DID pop off, just TOUCHING them causes that...but we successfully glued them back on. If you look from the top, you can see most of the leds on top, from the bottom, the reverse.. The replacement leds look a bit DIMMER In fact...than the old ones do..not much but a bit. Dimming the BL HELPS...but even at 20% ..you can STILL see them through the panel !!
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        The only thing I can think of is to remove the LCD panel again and reverse the order of the thin sheets (in the event that his may of happened) then bring up the backlight to see if the screen is correctly diffused before re-assembling the frame and LCD panel.
        Edit.
        I have to admit that I have been guilty of this error to.
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Sounds like you didnt glue the lenses on properly at the right angle to me.
          • 102mm
            • Dec 2013
            • 181
            • us
            I concur.. I've done this several times, luckily they were give away or garage TVs. if you have several that fall off it's hard to get them to match back up like they were before..
            Craigslist Picks & Fixes
            2 ea - Samsung 52"
            Samsung 60"
            • sleeper123
              • Aug 2016
              • 17
              Diffuser goes over the back light, frosted on top, polarized sheet next, then frosted again.
              TVs fixed:
              Vizio E470i-A0
              LG 50PT350
              Vizio E470i-A0
              LG 47LN5400
              LG 47LN5750
              Vizio E470i-A0
              Vizio VP322
              Magnavox 40ME325V/F7
              Emerson LF501EM5F
              • Moreno83
                • Jun 2014
                • 2008
                • The Netherlands
                Finger prints/greasy fingers can cause some bad effects on the display also.
                • Diah
                  • Feb 2013
                  • 6613
                  it happen, of sure you have the first thick plate ( reflector )in opposite way, it should the smooth surface to the top.
                  • dick_barton
                    • Aug 2015
                    • 6643
                    • Wales
                    Have you resolved the problem?
                    • daffsters
                      • Feb 2018
                      • 5
                      I have the white spot issue where the plastic reflector has fallen off of the LED. Since my TV is out of warranty, I disassembled it to glue the fallen reflectors back into place. Unfortunately, I did not note what order and orientation the hard plastic and 3 flexible diffuser sheets go in for re-assembly. What is the correct order? I know the hard plastic goes first, but does the smooth side or the textured side face the reflectors? After that, which sheets go in which order? Thank you!
                      • Pipolups
                        Corsair K70 LUX RGB dying LEDs
                        by Pipolups
                        Hi there !
                        I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
                        Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
                        10-08-2024, 11:58 AM
                      • howardc64
                        by howardc64
                        Problem
                        08-04-2024, 10:36 PM
                      • THE GTC
                        Insignia NS-37D20SNA14 intermittent LEDs
                        by THE GTC
                        So I use this TV daily as a second monitor for my PC or my Playstation - at one point a few months back I tried to fix the problem - but in the process, I figured out something that works so I haven't posted this for awhile. It is an annoying trick to have to do though, so I decided to post about it to see if anyone could spot what's wrong. It baffles me because it works on it's own half the time.
                        When I first got this TV, I was told it wouldn't turn on, and of course I did the flashlight test, and the image was there. Also, the red LED on the front indicated that it had power (it...
                        11-03-2020, 02:40 AM
                      • pni
                        Backlight panel diffuser melt by backlight leds broken
                        by pni
                        Hi guys, I changed my backlight to a 5g in Samsung but the broken leds burned the thick plastic panel . I give the photo. Do you think if I try to rotate the panel, with the botton on the top I have a good image? Becacause now how u can see, on the light color I sse the leds because of the burned on the plastic diffuser....
                        10-12-2025, 12:08 AM
                      • VitalComputing
                        Replacing Mode Indicator LEDs
                        by VitalComputing
                        I have what should be a simple job but is causing me issues. There are three LEDs (yellow, green and red) on the indicator panel of a solar PWM controller and these have broken off. I need to replace them but I am unsure of the voltage drop across these. I don't want to replace with random LEDs in case they blow.
                        I took one of the LEDs out of circuit, put 19V across it with a 500 ohm resistor in series and there is a drop of about 13V across the LED, and this seems to increase as I increase the input voltage.
                        I thought I could just put a resistor...
                        09-17-2023, 04:43 PM
