LG 32LV5500 CH:LT12E goes on but no image, BL or sound
  • yoritomo
    • Sep 2012
    • 155
    • Belgium
    Hello all
    This TV set is a LG 32LV5500 the chassis number is LT12E available service manual at Electrotanya.
    Main board number : EAX64104702(1)
    When pushing stby button on the remote the TV goes ON as the red led it turning white, no sound or images , back light is still OFF but working as I could force it to start, I only got a blank black screen.
    then i checked the power outputs, 12, 24 and 3.5V are all ok, no have any 5V from power supply board.
    If I check pin 10 of IC602 which seems to be BL-on i see 3.5V there but no reaction from backlight.
    There are the tensions i could find on the coils :
    L1807, L1808 : 0.78V
    L1810, L1811 : 0.67V
    L505 : 0.94 V
    L508 : 3.34 V
    L509 : 5.05 V
    L516 : 5.15 V
    Where is the 1.5V for the rams ?
    There is an image from the board i could find on the net, except the connectors i don't have on this set strangely.
    Thank you again for your great help.
  • DeeJayAlex
    • Aug 2016
    • 6
    • Romania
    Re: LG 32LV5500 CH:LT12E goes on but no image, BL or sound
    Hello
    You have 5v and 3,3 v on LVDS CONNECTION?
    • yoritomo
      • Sep 2012
      • 155
      • Belgium
      Hello
      On the larger LVDS connector I could measure 3.24v on pin 4 and 5
      Nothing on the 4 last pins mentioned Panel_VCC.
      • yoritomo
        • Sep 2012
        • 155
        • Belgium
        I guess back light control and panel power supply are controlled both together when the set is ready.
        I perhaps may try the internal t-con board auto test color bars to check the validity of the t-con board and panel, but i am sure the result would be correct because i think the culprit is the main board .
        What would you do first ?
        Thank you for your ideas.
          Can we see the whole back side of the TV showing all the boards?
          Since you do have BL-ON (at INV_ON pin) signal, what DCV do you have feeding the LED driver power supply and at the LED connectors?
          So for sure you can force on the backlights, but that does not make sense if you indcated that you do have BL-ON signal.
          How about the dim control signals A-DIM, P-DIM? What do you get?
          Panel_VCC is the DCV for running the T-CON, it is fed through switched MOSFET.
          • Diah
            • Feb 2013
            • 6568
            there are always simple test needed to do in order narrow the fault. you wrote no sound and picture, no backlight and 12 & 24 volts okay. did you test with torch light at dark room if you have picture ? did you try to turn on or off with RC if it work or not ?
            • yoritomo
              • Sep 2012
              • 155
              • Belgium
              This tv set is exactly this as this picture i could find on the net except for the video connectors on main board.
              I could find the signal INV_CTL on the chip but it is not going to the power supply connector, that is why i was wondering and decided to force it to see if any image present, no luck. Perhaps INV_CTL and BL_ON are not relative ?
              The +24V is present and correct but i need to check again the led dc power value A-DIM and P-DIM, that tv is on my labo, i am currently at home.
              Thank you very much, i will give this value when i am going there.
              • yoritomo
                • Sep 2012
                • 155
                • Belgium
                Diah , yes i wrote it in the first post, when i turn on manually the backlight, just a black blank screen, no osd ..
                Yes with remote control it works, the led is turning white and all power outputs are on as i described already, it means at least the micro controller is responding.
                  https://www.badcaps.net/forum/showth...549#post687549
                  The INV_ON and the DIM command pins are on that white connector of the main board to goes to the Power supply board, you see the labels for each pin on that connector.
                  The problem right now is that you need to that PANEL_VCC to run the T-CON baord also find out if you do have DCV on that INV_ON pin on the main board connector or not.
                  • yoritomo
                    • Sep 2012
                    • 155
                    • Belgium
                    As answer to the question of Budm, i did the following measures this afternoon :
                    On the output connector of the driver board, i could find 52V on the first and last pin when the Back light is forced ON. and P-dim = 3.15V A-Dim= 0v.
                    The INV_ON is 0V (of course unless i force it)
                    I made a test, forced backlight on and applied 12V coming from the the other connector to Panel_vcc nothing works because it is falling to 1.5V either that 12V power is too weak or perhaps abnormal consummation on the T-con board or panel itself. Today i had no time to apply an external 12v power supply to know what is wrong there. I will do next.
                    Thank you for your help again
                      When you applied 12V to the TCon board, did you completely Remove ALL the wires for 12V going back to the main board first, if not you had just cause more damages to the main board.
                      Same for any force on.
                      • yoritomo
                        • Sep 2012
                        • 155
                        • Belgium
                        I have disconnected L1501 to prevent it
                          Typical T-CON requires 3~5A to run, you can look up the spec sheet of the LCD panel to get the actual spec.
                            Where is the L1501 on the main board?
                            • yoritomo
                              • Sep 2012
                              • 155
                              • Belgium
                              yes it is the one providing 12v to the panel
                                At this point you do have main board problem.
                                • yoritomo
                                  • Sep 2012
                                  • 155
                                  • Belgium
                                  IC602 is the micom chip, the pin 10 is sending order to start the back light, looks like the 0 V of A-DIM is connected directly to the line of INV_ON , and the order of PANEL_VCC is coming from the t-con itself, without it, no 12V PANEL_VCC will be provided. How t-con determines if needs to feed the panel or not ?
                                  May it be a faulty T-Con board ?
                                  Or how should i start to troubleshoot the motherboard anyway? If no reply from the ram would it occurs such fault ?
                                  EDIT: i have an oscilloscope to try deeper tests and i would like to learn more about a such problem.
                                    The panel_VCC feeding the SMD fuse to the T-CON BOARD through the LVDS cable by the way of power MOSFET Q507 on the main board that is turned on the by MICOM.
                                    A-DIM (Analog Dimming control signal 0~5V, 5V = Max lamp brightness) is variable signal, so it cannot be the same as the INV_ON (HIGH or LOW signal), there is also PWM_DIM (Pulse Width Modulation Dimming control), which depends on which one the manufacturer will use, ANALOG or PWM.
                                    When power switch is activated, the main board will send PS-ON to turn on the rest of the power supply, after that the INV_ON signal is sent to turn on the backlights circuit, then the MOSFET Q507 for the 12V feeding the T-CON is turned on to supply the Voltage to run the T-CON.
                                    Look at PDF page 52
                                    • yoritomo
                                      • Sep 2012
                                      • 155
                                      • Belgium
                                      Some part of schematics are better to discuss, i could not find any output from micom to control Panel VCC.
                                      There is the 12 power PANEL_VCC switching circuit :
                                      An here is the control pin coming from the T-Con board by the lvds 54 pins connector :
                                        Well, look at PDF page 31, the MICON IC602 OUTPUT PIN 11 MODEL_OPT_1 is the PANEL_CTL SIGNAL PIN which is used for turning on the power MOSFET to supply PANEL_VCC, that same control signal is also to that pin 10 SHARP_OPT, that is RECEIVING PIN NOT output pin.
                                        When PANEL_CTL goes LOW the MOSFET is turned on to supply 12V to T-CON.
                                        You need to look at the schematic really well, and how can the T-CON turn on its own power to supply the 12V to the SMD fuse when it needs the 12V to be present first for it to do anything, common logic..
                                        Look up the spec sheet of the LCD panel to find out what that SHARP_OPTION pin is for.
                                        • ChaosLegionnaire
                                          by ChaosLegionnaire
                                          09-13-2022, 09:02 AM
                                        • domix
                                          Sony KD - 65XF9005 - No image, sound OK
                                          by domix
                                          at tv KD - 65XF9005 i have a problem.
                                          Afrer a coupe of minutes (10-30) i got black screen, no image. But i have sound.
                                          is this a common problem for this tv?
                                          i attached pictures of inside. Supply board looks okey, no blowed caps....
                                          07-21-2025, 06:37 AM
                                        • Kartowl
                                          philips 47pfl6158k/12 image faded away, sound still coming from TV
                                          by Kartowl
                                          Hi, my TV image started showing those lines and the image faded away, but sound is still coming from it, what could be the cause and is it fixable? I thought it could be the tcon board but I red on the internet that it could be a failing panel
                                          04-23-2024, 12:57 AM
                                        • wolf1976
                                          samsung ue40d6100 has no backlight no sound and image
                                          by wolf1976
                                          hi to all
                                          on the above model of samsung i have the faults i have told already on the title
                                          iI have standby i can from remote control open and close the tv and it seems reacts the tv when i press someone button from remote control but and with the help of a torch i cannot see anything image on the tv and no sound
                                          any idea from someone what can i measure so i can find the problem ?
                                          the power supply is the bn44-00482a i cannot find the service manual so i can test if the leds are ok and maby these are the cause of my problem
                                          11-17-2024, 01:02 PM
                                        • howardc64
                                          LG 43UK6500AUA no LCD image, backlight and sound okay
                                          by howardc64
                                          Similar to another LG UK series here
                                          https://www.badcaps.net/forum/showthread.php?t=93943
                                          Have backlight and sound. no LCD image.
                                          • main board has integrated T-Con
                                          • main board T-Con has LCD DCDC/PMIC RT6950GQW QFN68 package. Richtek chip. Can't find datasheet. Chip generates VADD (10.44V), VGH (~28V), VGL (~-14.5V)
                                          • RT6950 pin 18-19 (clockwise) appeared to be bridged. Unlikely from my probing, looks like ball squeezage so it probably got hot
                                          • Cleaned up bridging. Pin 17 is VGL (-14V) Pin 20 is VGH (28V). Pin 18 (I think 19 too) jumps between VGL and VGH voltage
                                          03-12-2023, 01:04 PM
