LG 43UK6090 no image
  • alfatv
    • Sep 2020
    • 353
    Suspect bad panel, but looking for advices especially from those familiar with this model.
    TV is turning on, there is backlight and sound.
    The picture is grey.
    Main supply voltage to the panel (big electrolytic cap) is quickly is turning off after power up, but it stays on on if panel is disconnected.
    I checked for shorts, nothing obvious.
    There are few types of panels and main boards used in this model, mine is with 2 panel connectors inwards like here:
    https://www.ebay.com/itm/LG-EBU64868...M/363237919773
  • Diah
    • Feb 2013
    • 6502
    Re: LG 43UK6090 no image
    99.9% panel cracked
    • alfatv
      • Sep 2020
      • 353
      No, it's not cracked, but I will double check inside.
        Please attach the pictures of the whole backside of the TV showing all the boards and the screen shot of the panel when TV is turned on so we can see what we are dealing with.
        • alfatv
          • Sep 2020
          • 353
          I removed the panel, no cracks at all.
          See attached pictures, one of them shows lines when TV is turning on. After that it goes steady grey.
          Image is always grey no matter what cable to panel is connected.
          But power supply shuts down only if the right side (looking from the front) is connected.
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            Can you post photos of the long thin circuit board connected to the lcd panel.
            • alfatv
              • Sep 2020
              • 353
              Here is long board, 6 COFs total
              • alfatv
                • Sep 2020
                • 353
                Just got image out of it with tape method.
                Had to cover about 20 pins or so on the left side of connector.
                Tried to cover less pins, but it either stops working or starts flickering or there are line patterns on the right side.
                Experts, what's going on and what to do next?
                • brucetv
                  • May 2015
                  • 281
                  • united states
                  You have a short in one or more MLCC's on the lower driver boards for the panel. The UK series is plagued with this problem and you have to remove the shorted cap to get the panel to fire up. It's a slow pain in the ass process. Life is NOT good with LG crap panels.
                  • alfatv
                    • Sep 2020
                    • 353
                    Brucetv, thanks for advice, I already tried to to find shorted caps, bus was not able to.
                    Are they dead short or somewhat leaking? Should I use resistance or diode check?
                    Or do you mean removing them one by one?
                    • dick_barton
                      • Aug 2015
                      • 6643
                      • Wales
                      Set your meter to ohms and check for very low resistance close to very low to zero ohms
                      • Raulnn
                        Tdsystems K40dlt3f Panel V400HJ6-PE1 REV C2 short circuit no image
                        by Raulnn
                        good evening. I have put the panel model, because it is a generic Chinese tv. The symptoms are the following: The rear light turns on, but there is no image, 12v arrives at the tcon integrated in the panel. I have made measurements of vgl, vgh and vaa. They are not present but they all act as rectifiers except for vaa, which is shorted. my questions are. Do you know any quick method to know the capacitor that is shorted without having a laboratory source? How could I know the value of the capacitor once extracted? I can't find schematics for this panel. a greeting
                        12-20-2022, 05:11 PM
                        HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                        This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                        09-12-2024, 02:20 PM
                      • howardc64
                        LG 49UJ6500 LCD panel lighter band that goes away
                        by howardc64
                        49UJ6500 LCD panel has a lighter band on top when first powered on. Goes away (or gets much fainter) after TV on for a few min. After powered off for awhile and power back on, same band appears. If powered on immediately after powering off, no or much fainter band. Running the latest firmware.
                        Disassembled the TV and lifted the LCD panel during testing. Band is on the LCD panel (can see the band on the panel as I lift it slightly) Backlight is perfectly even at the top edge. Double checked LCD panel alignment in the frame and is perfect but since band moved with the panel, its on...
                        02-19-2023, 12:13 AM
                      • Jaime Morillo
                        Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                        by Jaime Morillo
                        Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                        The TV was stuck on the logo and I couldn't access the update menu.
                        I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                        The image result was good, but the image is inverted.
                        The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                        Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                        08-18-2025, 11:38 AM
                      • Storyteller12
                        QN55Q60R Service Menu Panel Help
                        by Storyteller12
                        I had a the above tv qn55q60r that had a bad panel but everything else good. I had another panel here from un55nu6900 with bad leds and melted diffusers.
                        I put the nu6900 panel in and powered it up and it does work but there are lines vertical lines.
                        I was trying to change the panel type in the service menu but don’t see my exact panel. Anyway to fix this or someone have similar experience.
                        the clear picture is the panel type from the service menus on the nu6900. The other 1 is the panel type that was set for the q60r with the bad panel....
                        01-13-2024, 01:57 PM
