I'm completely new to TV repairs. While searching for the cause of the symptoms of my TV - having a nearly white picture whilst sound is fine - I stumbled upon this forum.
After seraching here and reading the related threads, I think my problem is related to the T-Con board.
I already ordered an "new" T-Con board via AliExpress, but the symptom is the same, after changing the T-Con board: still nearly white picture and sound is fine.
So either the cause for my issue is not the T-Con board or the "brand new" T-Con wasn't brand new. As I could see some remains of Fluxx on the board, I guess it wasn't.
Anyway - I'd like to fix the TV and therefore would appreciate it if someone could guide me in the right direction. I do have some experience in soldering SMD, so if the problem can be isolated to some chips / caps / whatever, I'm positive that I am able to exchange the parts.
Attached you can see a video with the symptoms (had to zip it) as well as pictures of my original T-Con board (the chinese exchange is in the TV right now - but type number was identical to my T-Con board).
So for my questions:
Any help is higly appreciated.
Thank you very much in advance,
Sascha
- Is this symptom related to the T-Con board?
- If so - in most cases where someone helped, first thing was to measure the test points on the board. Which ones would that be? There are three places which could be tested (see pictures).
- If not - what could be the cause for the nearly white picture?
Sascha
