Insignia NS-37D20SNA14 with bad LED backlights
    I used the LG Innotek LED LATWT470RELZK (ANODE is large pad) for this one from ALIEXPRESs, ran it all afternoon today and still working, 3 of them has open circuit, one is shorted.
    Store:Guoxin Electronics Co., Ltd.
    http://www.aliexpress.com/item/LG-LE...5-93396de54953
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Insignia NS-37D20SNA14 with bad LED backlights
    Nice work matey, also 3 open one short ? Only takes one open to pull it down normally as theres only one drive line on that too.
      Two open one shorted.
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8326
        nice work, I hope the LEDs keep on running.
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          should replace all.waiting for the next led to drop...
          • vinceroger69
            • Mar 2012
            • 6714
            • uk
            How are you guys replacing the new leds hot air or soldering iron as ive read a few threads and it seems overheating them whilst fitting shortens the life of them.
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Im guessing Bud used hot air mate as he has brand new ones.
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                But they can last longer with the brightness switched down on them replacing them all is a huge pain and costly too. Ive had very good luck but just replacing the bad ones and turning the Bl down.
                • dick_barton
                  • Aug 2015
                  • 6643
                  • Wales
                  When I did mine I heated the strip from underneath and when the solder on the pads melted I quickly dropped the led on and using tweezers positioned it. I think that minimized the time the led was subjected to the heat.
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    • uk
                    This is how i do mine at the minute but have been reading a few threads where people are using soldering irons.
                      I remove the old bad LED one by using diagonal cutter to crush the white body to expose the two metal tabs then I used flux and add solder to remove the old tabs, clean up the board, add flux and hand solder on the new LEDs
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        • uk
                        This website has some good info etc on leds
                        https://www.sahy.cz/sahy/eshop/5-1-L...-LED-Backlight
                        • Spork Schivago
                          • Mar 2012
                          • 4734
                          • United States of America
                          I know this is an older thread, but Budm, how hard was it to get to the actual LED strips? I've been reading and was under the impression is model TV might not have good solder on the strips. Am I wrong on this? Now that I got the TV up and running, I was going to open the actual screen and try resoldering the LEDs, but from the pics you shared, it almost looks like this isn't needed....
                          Also, in the power supply picture ( https://www.badcaps.net/forum/attach...1&d=1472948823 ) What's the purpose of that right top most electrolytic capacitor? Does that need to be low ESR?
                          Thanks!
                          -- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full
                          • neilc6
                            • Nov 2015
                            • 1550
                            Not too much luck with TVs this week. Got this model. 12V on PS connector and BON goes low when power button is pressed but no backlight. Opened up TV and found 2 bad LEDs. Replaced with LG-compatible 3528 3V ones (strip looks like those used on LG models, LEDs are very cheap on Aliexpress). Plugged in without panel and backlights all came on. When I was putting the panel back on, I snagged a tab bond and ripped it completely off.
                              Oh man!
                              BTW, the TV is still working, backlights is set to 50%.
                              • Andrew F. Ali
                                • Jan 2014
                                • 2450
                                • Trinidad & Tobago
                                I understand your pain. It happened to me a couple times, too.
                                • max789
                                  Samsung UE48H6410 replaced Mainboard but backlights doesnt go on
                                  by max789
                                  Hello, I have a problem with my Samsung UE48H6410SSXZG with the main board BN41-02156A and the power board BN44-00709A. Everything seemed like this, the TV could no longer be switched on, the standby LED always flashed 5x2 times. Backlight was off and no sound from TV. Also made the flashlight test and there was no picture.
                                  I made the following tests:
                                  1. Disconnected the main board from Power Board = backlight works.
                                  2. Connected the main board and disconnected the T-Con = backlights does not work.
                                  So I ordered a main board from Ebay also BN41-02156A but from...
                                  01-18-2024, 06:56 AM
                                • bpcannan
                                  VIZIO M557-G0: Backlights or ???
                                  by bpcannan
                                  'Morning,
                                  I get sound and picture when powering on the TV and its stays that EXCEPT that the left half of the screen will dim every few seconds then return to normal while the right side of the screen performs as designed.
                                  Did the soft and hard reset options pulling the plug, using the reet option in the vizio menu to no avail.
                                  I checked the mainboard - found some popped capacitors so replaced it - but that did not change the situation.
                                  I checked the t-con board. It is getting good power. Then I removed one ribbon cable to see if I could isolate...
                                  10-29-2023, 06:36 AM
                                • jesterace
                                  Samsung UE49MU6400 acts dead until disconnecting backlights, then works.
                                  by jesterace
                                  Hi everyone I have this TV which was dead one day when I tried to turn it on. I've had the cover off and there was just a pulsating/electrical clicking/ticking noise from the PSU. I disconnected the mainboard as sometimes this works to just fire it up with backlights on? That didn't help. Same noise. Then I disconnected the backlight cable from the PSU and the TV came alive. It appeared to respond to the remote and i'm pretty sure it's fully operational when there is no backlight connected.
                                  However, I am in a dilemma.
                                  I tested the backlight outputs with the lights disconnected...
                                  10-20-2024, 10:15 AM
                                • x_orange90_x
                                  Sony KD-75X750H no backlights
                                  by x_orange90_x
                                  I just removed the back cover to test the backlights because when I first plug it in it will flash once and then start dark but I can see the image. I got 131v on string 1 and 167v on string 2. Usually when I get a bad set the meter reads 300v and they won't light up. When testing, each set lights up inside the tv. When I plug in the power and check the leads with my multimeter both strings are only about 3v.
                                  Does this difference in voltage between the strings indicate that the lesser has bad LEDs? Or is it normal that they are not the same voltage? I've read some about this tv and...
                                  07-16-2025, 07:49 PM
                                • jimbofz
                                  toshiba 65ul2163 dbl no backlights NOT BACKLIGHTS?
                                  by jimbofz
                                  Hi this vestel 65in tv had classic no backlights ,so nothing new there!
                                  tested with b/l tester and the b/l seemed to be fine
                                  so investigated psu 17ips72 (on this 65inch there are 3 fets and control iv type DB83630P)
                                  did a thorough check on b/l circuit all ok .
                                  When i tried again with b/l tester all ok .but then when i reinstalled psu all worked fine ,
                                  could there be a component on psu that is causing the protection mode to stop b/l
                                  .maybee causing it to be too sensitive?
                                  it seems to me if the b/l have been on with my tester ,within a couple of minutes...
                                  06-07-2025, 10:11 AM
