Power Board FSP212-3F01 Problem
  • badcaphunter
    • Jan 2016
    • 88
    • England
    I picked up a Hannspree tv with this power board, i have replaced Q9 Q7 Q11 ZD4 and R65, i have got a replacement for Q4 but its reading ok.
    I have no standby or anything at all on the secondry side and i'm getting -120/-150 on the primary side heatsinks.
    Pin 4 on IC4 should be about 14v but i'm getting -120
    The bridge rectifier is reading fine.
    Re: Power Board FSP212-3F01 Problem
    You are using the wrong GND for your meter, when making the DCV measurement in the Primary Main side circuit, you have to use the negative leg of the MAIN filter cap as the GND ref. for your meter, not the chassis GND.
    Good clear pictures of the board?
    • badcaphunter
      • Jan 2016
      • 88
      • England
      Im still waiting for some caps but i changed what i could.
      I will post some more pics later
      • badcaphunter
        • Jan 2016
        • 88
        • England
        Should i remove all the white glue, is it conductive?
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8065
          unless you change a part that has the white glue, leave it. You can easily measure if the glue is conductive by putting your DMM in Ohm mode and stick your probes into the glue.
            So how bad are those parts you changed were tested out to be? P/N of those parts?
            Q9 Q7 Q11 ZD4 and R65 Where are they located at? They are SMD on the bottom side of the board?
            I also see one cap in the top left with bulging top so you probably has more than one bad cap on the board, especially the small lytics caps in the primary side.
            • badcaphunter
              • Jan 2016
              • 88
              • England
              The main blue cap is going up and down from 346v to 350v, and i'm getting 4v to 7v on pin 1 of IC1
              • badcaphunter
                • Jan 2016
                • 88
                • England
                Yes they are all underneath the board on the primary side
                Q7 - BC848
                Q9 Q11 - BC858
                ZD4 - BCX55C4V7 4.7V
                R65 - 5.6 Ohm Resistor
                  So did you replace that cap with bulging top and check the ESR of other caps.
                  • badcaphunter
                    • Jan 2016
                    • 88
                    • England
                    I dont have a ESR meter but all of the caps on the secondary side were bloated so i changed what i could, there is still 2 that are bloated, the replacements should be here tomorow
                    • badcaphunter
                      • Jan 2016
                      • 88
                      • England
                      Still waiting for the caps, i managed to get standby 5v. no sign of 12v, 24v.
                      Now that standby is there, when i press the power button i'm getting a pulsing clicking noise, not as loud as a relay, coming from near the bridge rectifier when the standby light goes from red to green, i have also ordered a esr meter and a load of low esr caps.
                      I dont think that schematic i posted is for this revision as some of the values are slightly different.
                      This youtube channel has been a great help for me, i would not even consider myself a novice..... yet
                      https://www.youtube.com/channel/UC2D...11URZqWBigcVOQ
                      The reason i did not have any standby voltage is the diode i used was 4.7v and needed to be 15v
                      Anyone else working this psu "BE CAREFUL" it has half mains voltage going through the heatsinks... trust me i found out the hard way
                      • Tynan Dill
                        by Tynan Dill
                        Assuming...
                        11-22-2024, 01:46 PM
                      • Destroyer-Br
                        [HELP] Acer AN515-55 (LA-J871P Rev: 1B) – Board won't power on after GPU investigation – Suspecting Super I/O or PCH
                        by Destroyer-Br
                        I'm working on an Acer Nitro 5 unit with the following specs:
                        • Motherboard: LA-J871P Rev: 1B
                        • Model: Acer AN515-55-59MT
                        • S/N: NHQ7JAL00403906A973400
                        • SNID: 03902728734
                        Initial Issue
                        The laptop initially presented graphic issues and driver failure (Code 43) for the GPU.
                        After preventive maintenance (cleaning, thermal paste, etc.), it powered on normally. We disassembled it again to inspect the GPU, reassembled...
                        04-17-2025, 08:18 PM
                      • Dani_2024
                        by Dani_2024
                        10-28-2024, 05:06 PM
                        After all of...
                        07-13-2024, 08:14 PM
                      • JDC
                        by JDC
                        ONN 100012588
                        Long answer:
                        07-15-2022, 07:39 AM
