LG 42LD560 PSU Problem? (stuck in standby)
  • mostachio
    • Apr 2014
    • 22
    • New Zealand
    hoping you can help me out. I am a novice (but keen to learn!) so please dumb down stuff to the point a small furry animal could perhaps read it.
    Trying to get a TV going for the garage and I have this faulty LG LCD so i'm hoping, with help, I can get it going without buying a replacement board.
    Tools avail:
    Multimeter
    Soldering gear
    Variable heat gun
    Common sense around electricty
    etc
    TV: LG 42LD560
    PSU: EAX61124201/15
    Symptoms:
    Will not boot. will not react to the remote. Is stuck in standby with its red light slowly pulsing.
    Inverter Test Result: Working. When put into inverter test backlight stays on and does not go off.
    Board looks physically OK, no domed caps and solder joins look fine.
    Output voltages are incorrect (I can go through and test them again and post if needed) but very irregular, sometimes 0, sometimes I get weird voltages on *some* of the outputs (Like one 20V will test OK, one will test 3.5V). Power ON/OFF remains 0. I am not sure whether these voltages would be turned on once the TV turns on? Anyway there's a ebay repair kit that comes with all the capacitors (C220 C210 C218 C205 C217 C215 C208) beside the output to main plug. I do not have an ESD meter to test the caps. Could this be my issue? I don't mind doing a blanket change to check.
    Thanks!!
    Edit: Blanket changed all the capacitors (except 220uf 25v) between the volt regs & the output to main plug ($4-5 meh). No change in symptoms... Have not re-checked the DC outputs on main plug. TV still stuck in standby.
    Should i just bite the bullet & buy a new PSU board?
  • syaoran123
    • Jun 2014
    • 178
    Re: LG 42LD560 PSU Problem? (stuck in standby)
    You have a heat gun which might come in handy. Use it on the large heatsink on the mainboard at 200C for 2 minutes and see if that works.
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8320
      If PSon is 0 V DC, the PSU will not turn on. You have a main board problem.
      If you force the PSU on manually you probably find that the PSU itself is working correctly.
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Originally posted by capleaker
        if pson is 0 v dc, the psu will not turn on. You have a main board problem.
        If you force the psu on manually you probably find that the psu itself is working correctly.
        +1
        • mostachio
          • Apr 2014
          • 22
          • New Zealand
          Oh praise you man, that fixed it. I'm guessing xbox style bga of the broadcom chip is dead. Thank god I didn't replace the PSU
          I'll see how it goes & order a new main board if necessary.
          P.S. For those that come across this,.. I may've done this at 250C for 2min 30... will keep this thread updated if/when it dies again.
          Thank you syaoran123. Appreciated!
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 8320
            yw
            • syaoran123
              • Jun 2014
              • 178
              Indeed, it is a common probem with these models.
              For a more permanent solution, you can use higher temperature. I use heatgun at 380C for 2-3 minutes to resolder the bga joints. Probably worth doing the same thing for the chip on the top left just incase. Make sure you keep the board flat and dont move it while its hot, or you could disturb the smd components.
              • mostachio
                • Apr 2014
                • 22
                • New Zealand
                Just saw this after having to repeat the process several times & looking up the number of the board from post to buy. Have tried a full 3min at 380C. TV works will keep updated. Cheers
                • lepak06
                  TV LED 4K Selecline 65S18 ( T.MS3458.U801) stuck in Standby mode
                  by lepak06
                  Hello
                  I have an TV Led 4K Selecline 65s18 with mainboard T.MS3458.U801
                  The TV is faulty with stuck in Standby RED LED. Can't power the TV.
                  Before this problem , the TV stuck the picture with artefact , i unplug the AC cable and since the tv is stuck in standby .
                  All voltage are OK on PSU and main board for regulator. I tried flash firmware 25Q64 with many dumps
                  But the voltage on power button is 0.6V not 3.3V. When i press power button the voltage up to 0V. I tried to add 5V with Power Supply on 5V_STB and 3.3V on Power...
                  01-12-2023, 01:43 AM
                • toty79
                  Hisense LTDN50K220WSEU stuck in standby
                  by toty79
                  Hello to all friends of the forum and well found, here I am asking for your help and sorry for my translated English.
                  As per Hisense tv title LTDN50K220WSEU stuck in standby
                  PSU rsag.820.5687 HLL 4855WF
                  Main rsag 7.820.5842
                  I enclose the psu diagram, after the first routine checks I find myself with a regular standby voltage of 3.3v blue light on steady when the power button is pressed nothing happens, psu disassembled and bench checked ... forced ignition by sending a signal 3 , 3v on the SW and PWM2 pins the psu turns on and delivers all the voltages...
                  05-01-2022, 04:39 PM
                • lego1234567
                  LG 32LB1R - stuck in standby mode
                  by lego1234567
                  Hi. I have the following problem with my TV. After connecting to mains, the standby led (red) turns on, but TV is not responding to remote control or buttons on TV. After some measurements, I found out that +5 V standby voltage is present, but I dont have ON/OFF signal coming in to turn PSU on. It stays at zero volts. After looking at the schematic of the mainboard, I should get ON/OFF signal coming in at the R1402 resistor, but it stays around +3,5 V. So I removed it and I was able to turn on TV with buttons on TV, but not with remote control.
                  What could be the problem ? Thanks...
                  01-21-2024, 03:39 AM
                • nono34
                  Hisense stuck in Colors cycle like test pattern.
                  by nono34
                  I accidentally changed the project ID in the service menu of my Vidaa Hisense 100U7KQ TV. When I turn on the TV, the screen displays an RGB color cycle (test mode???). I contacted Hisense, and they sent me a usb_MTK_9618.EU.bin file, but it doesn't work. I can see that the USB drive is being read, and it flashes for about 10 minutes (the screen remains in the color cycle during the firmware reading), then the TV turns off and restarts, but still in the color cycle mode.
                  I want to mention that the 4GB USB is formatted in FAT32 MBR. I've also renamed the file to...
                  10-24-2024, 04:31 PM
                • Stunt
                  Hp Laptop Stuck on Hp protected by hp sure start screen
                  by Stunt
                  Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
                  I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
                  I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
                  Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
                  screen that's it and stuck there. I left it until the following day and i still...
                  09-02-2025, 01:51 PM
