Vizio SV420XVT1A missing 12v on main board
  • bikerbuddy
    • Jun 2011
    • 134
    Need some help with this main Board I am working on , The TV power on with amber light and stay on , no picture or sound , I jump the power supply with a 1000 ohm resistor and have all the right voltage comes up with main board cable disconnected , but the 12 v that supposed to go into the main Board is not showing up at the fuse on the main board .
    I took some reading on the voltage regulators and this is what my findings are
    U45
    AZ7805ST
    adj out in
    000 000 000
    U16
    AZ7805ST
    adj out in
    000 000 000
    U19
    0809 ul (1084)
    adj out in
    1.258 2.057 5.08
    U22
    G1117 (k218)
    adj out in
    2.055 3.29 5.13
    U17
    G1117 (k218)
    adj out in
    2.079 3.32 5.07
    U20
    0809 ul 1084
    adj out in
    .556 1.812 3.31
    U21
    G1117 k218
    adj out in
    .001 1.242 2.497
    Re: Vizio SV420XVT1A missing 12v on main board
    'U19
    0809 ul (1084)
    adj out in
    1.258 2.057 5.08"
    Vout = 1.25Vref + Vadj
    So in your case you have 1.258 @Adj pin so the output should be 1.25Vref +1.258Vadj = 2.50V, you are only getting 2.057V so you need need new regulator.
    12V is switched power supply, it will not be present until PS-ON command is sent to the power supply board from the main board.
    • bikerbuddy
      • Jun 2011
      • 134
      Thanks Budm, I looked on line and cannot find this regulator , not even a hint of it ,Is there a substitute I can use . thanks
      • dick_barton
        • Aug 2015
        • 6642
        • Wales
        Can you post a picture of' U19, 0809 ul (1084)
        • bikerbuddy
          • Jun 2011
          • 134
          here is a pic of U19 DB.
          • bikerbuddy
            • Jun 2011
            • 134
            • bikerbuddy
              • Jun 2011
              • 134
              here is a full main board pic
              • vinceroger69
                • Mar 2012
                • 6714
                Maybe this?
                https://cdn.badcaps-static.com/pdfs/...d543900844.pdf
                although on google images the marking at the top is ap maker
                • bikerbuddy
                  • Jun 2011
                  • 134
                  Should i look into 3.3 or adjustable ?
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    im sure budm will advise the correct replacement as im not sure myself
                      What you have is the Adjustable type, NOT the fixed output type, you can tell by the resistor network connected to the ADJ pin and the Output pin.
                      So get the Adjustable type.
                      • Diah
                        • Feb 2013
                        • 6368
                        hold on, you checked PWB with IK R and 12 Volts was Okay. set turn on but no picture and sound. .. did you get the MB out and checked under layer of bad soldering..?
                        • bikerbuddy
                          • Jun 2011
                          • 134
                          Yes I went through the under side all looks ok , Thanks you.
                          • bikerbuddy
                            • Jun 2011
                            • 134
                            Will order that part and post back later, Thanks to all .
                            • dick_barton
                              • Aug 2015
                              • 6642
                              • Wales
                              Maybe this?
                              +1 That's also what I found when I searched and I fairly certain you are correct.
                              • dick_barton
                                • Aug 2015
                                • 6642
                                • Wales
                                Have you checked if you have all the voltages on the power supply. So you have 12V for the main board and 24V for the inverter at the power supply?
                                You say that the 12V going to the mainboard does not show up at the fuse. Does it show up at the power supply and have you used your ohmeter to do a continuity check (with set off) to make sure the wire connected to the 12V pin at the power supply end actually connects to the mainboard at the fuse?
                                Have you check the fuse continuity for open circuit?
                                  He has to find out if he has PS-ON signal to turn on the 12V/24V, he is not getting the 12V to the main board right now.
                                  • bikerbuddy
                                    • Jun 2011
                                    • 134
                                    Conformed ps/on voltage is .035 v ,I do have 12v , 24v when I disconnect the main board cables and use jumper on ps/on to 5v .
                                    Any way i have ordered the LM1084 adj from Mouser so we will see what the results will be within a week or so .
                                    Very greateful for all the help .
                                    • bikerbuddy
                                      • Jun 2011
                                      • 134
                                      Update , Chip has arrived today LM1084 which is a replacement for 0809 UL
                                      Installed it and Did not find any change it is showing In 5.08v, out 2.508V, adj 1.258V ,still cannot get 12V to main board , also did jump the( ps-on to 5v) again to make sure that the P/S is still putting out 12V all voltage on P/S are correct
                                      24V = 24.27v
                                      12v =12.01v
                                      5v = 5.01v
                                      A = .056
                                      B= .023
                                      C = .000
                                      Big chip under the heat sink is getting very hot, hotter than the normal touch .would this be an indication that the chip is toast?
                                        Your readings:
                                        24V = 24.27v
                                        12v =12.01v
                                        5v = 5.01v
                                        A = .056
                                        B= .023
                                        C = .000
                                        I am confused, in post one you said you do not have 12VDC at he fuse but right now you do have 12.01V from the the power supply, same for the 24V so it means the main baord is sending the PS-ON to the power supply board to turn on the 12V/24V power supply.
                                        You must have 12v at the both ends of the fuse on the main board at this point.
                                        Right now I see that the main board is not sending the BL-ON or the Dimming signals (A & B) which are routed through the power supply board to get to the inverter board.
                                        BTW, what DCV do you have now at U16, U45?
                                        U45
                                        AZ7805ST
                                        adj out in
                                        000 000 000
                                        U16
                                        AZ7805ST
                                        adj out in
                                        000 000 000
                                        Same as shown above still?
                                        • Dani_2024
                                          by Dani_2024
                                          10-28-2024, 05:06 PM
                                        • ygorsan
                                          by ygorsan
                                          🧩 Problem Summary:
                                          • I
                                          07-28-2025, 08:34 AM
                                        • jb_Bak
                                          by jb_Bak
                                          CN6401
                                          Pin 01 NC
                                          Pin 02 NC
                                          Pin 03 "BL_ON": 0V
                                          Pin 04 "N/C"
                                          Pin 05 "STBY 3.3V": 3.5V
                                          Pin 06 "GND": N/C
                                          Pin 07 "AC_OFF"...
                                          09-27-2021, 04:52 PM
                                        • JDC
                                          (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
                                          by JDC
                                          ONN 100012588
                                          Issue: No Power, Then Rebooting After Main Board Change
                                          Short answer: replace main board and power board
                                          Technical answer: replace main board and Q306 & Q307 on power board.
                                          Long answer:
                                          TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
                                          07-15-2022, 07:39 AM
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
