Cross reference for B90N08
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Cross reference for B90N08
    Can you take the voltage readings with everything connected and attempting to turn it out of standby and at the second red box marked
    • ned1
      • Feb 2014
      • 139
      • usa
      Here is the voltage measurements:
      corner connector is same as before
      5V 5V
      5V 5V
      G 0
      G 0
      ENA 0
      ADJ 0
      Connector that I missed previously to give readings is
      PIN1 0
      PIN2 0
      PIN3 25V
      PIN4 25V
      PIN5 0
      PIN6 0
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        Do you have a picture of the back of the set with all the boards to see the interconnections.
        You could try taking ENA to +5V using a 1K resistor and see if the leds light up or at least check the voltages going to them.
        Since it's a monitor it may not have ENA voltage unless it's plugged into a source but I'm not certain. Probably needs the ENA to switch on the OZxxxx chip to power the leds.
        • ned1
          • Feb 2014
          • 139
          • usa
          When I plug the power cord on it tries to light the LEDs , you can see a blink and it stays dark after it
          • CapLeaker
            Leaking Member
            • 8179
            sounds like a bad LED.
            If you have the main board connected to the PSU and the ENA pin stays 0 when you turned the TV on, then you have a main board problem as well.
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              #26
              The led output connector is only at 25V so I think the OZxxx chip is not running but that could be because it's not enabled.
              • ned1
                • Feb 2014
                • 139
                • usa
                #27
                I will measure to enable voltage at the moment when I power it on, it may get 5V then goes to standby.
                • ned1
                  • Feb 2014
                  • 139
                  • usa
                  #28
                  Correction, the ADJ pin is 2.9V ENA pin is always 0.
                  • ned1
                    • Feb 2014
                    • 139
                    • usa
                    #29
                    Here is the picture of how the boards and panel are connected
                    • dick_barton
                      • Aug 2015
                      • 6643
                      • Wales
                      #30
                      1. "Do you have a picture of the back of the set with all the boards to see the interconnections"
                      Photo's please
                      2. You could try taking ENA to +5V using a 1K resistor and see if the leds light up or at least check the voltages going to them.
                      Have you tried this and what was the result.
                      3. Since it's a monitor it may not have ENA voltage unless it's plugged into a source but I'm not certain. Probably needs the ENA to switch on the OZxxxx chip to power the leds.
                      Is this a PC monitor and does ENA go to 5V when connected to the PC.
                      • ned1
                        • Feb 2014
                        • 139
                        • usa
                        #31
                        Is the picture I sent earlier the one you are looking for
                        • dick_barton
                          • Aug 2015
                          • 6643
                          • Wales
                          #32
                          Sorry I missed that. There are cables at the top of the photo running to the right and off the photo and also cables at the bottom of the screen that go off to the unknown.
                          Edit
                          I'm trying to work out how everything is connected.
                          • ned1
                            • Feb 2014
                            • 139
                            • usa
                            #33
                            I am looking for 1k resistor then will do test. Few more closer pictures.
                            • ned1
                              • Feb 2014
                              • 139
                              • usa
                              #34
                              Main board connection
                              • ned1
                                • Feb 2014
                                • 139
                                • usa
                                #35
                                Hope this helps
                                  It looks like the RED/YELLOW/GREEN/BROWN/??? wires bundle is for the LED BACKLIGHTS but not 100 % sure since we cannot see the whole LCD panel.
                                  When you force on the ENA pin, the connection going back to the LOGIC/MAIN board has to be disconnected otherwise the ENA line will be kept LOW by the LOGIC/MAIN board.
                                  The resistor can be anything between 470~1000 Ohms.
                                  It looks like it has 4 strings of LEDs.
                                  https://www.badcaps.net/forum/attach...6&d=1472745624
                                    What is the DCV rating of the cap C2A (Filter cap for the boost converter output)?
                                    What is the DCV on C110 (input Voltage to the boost converter)?
                                    • ned1
                                      • Feb 2014
                                      • 139
                                      • usa
                                      #38
                                      C2A cap is 100V 47uF. C110 is 50V 680uF.
                                      The bundle of wires from power supply board that is disconnected on the end connects to the panel.
                                        OK, 25V input to the boost converter is about right, and since the boost converter is not ON so you will see the 25V at the LED b+ connector that feed the Anode of the LED's strings.
                                        Once the ENA signal is present then you should see much higher B+ for the LED strings if the boost converter circuit is OK.
                                        • ned1
                                          • Feb 2014
                                          • 139
                                          • usa
                                          #40
                                          Can I remove power board take it with me to work and solder 1k resistor between 5v pin and ENA then measure other pins that were 0 on the power board.
                                          • Francesc V.
                                            Diode marked as "E57".........not able to find it by reference
                                            by Francesc V.
                                            Hi:
                                            I have what it might seem a zener diode. It's marked as E57, but I haven't found any reference that might match my observations.
                                            I've took one from the same circuit and tested isolated with the power supply and a 1k resistor. with 10V, the possible zener stays at 6.6V.
                                            It seems a SOD123 package. It measures (2.6mm x 1.6 mm).
                                            Any idea? it's a 6.6V zener?
                                            06-14-2025, 09:56 AM
                                          • connorcc2005
                                            Thermistor specs and cross reference
                                            by connorcc2005
                                            I'm getting some conflicting information and thought I'd toss it out to all of you for input.
                                            What I have is a TTC-104 thermistor. This is part of a temp sense circuit that will drive a small 12v fan to cool components mounted to SMPS heat sink.
                                            The physical diameter of the piece is 5.1mm measured with a caliper.
                                            Other than what you see in the pic, there is no other writing on the part.
                                            My research of the TTC-104 says it should read 100 ohms at 25C. Out of circuit measurements have it at approximately 100k. It does change as the temp changes....
                                            06-16-2022, 04:16 PM
                                          • asr
                                            Finding replacement diode iPad Pro 3rd gen A1701
                                            by asr
                                            Hello, I am looking for help to replace a damaged diode. The tristar was replaced and a diode was damaged in the process. I have a picture of the diode but dont have an exact donor. I mostly have macbooks for donors and only a few ipad and iphone boards. Diode part number: DSF01S30SCAP
                                            Im not sure where to find the ipad board number. Anybody have an idea where else this diode is used on other boards? Thanks....
                                            07-09-2024, 06:24 PM
                                          • unimatrix93
                                            TV backlight zener diode
                                            by unimatrix93
                                            Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
                                            So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
                                            Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
                                            The led strips has 9 6V leds.
                                            02-10-2025, 12:13 PM
                                          • NicRac
                                            monowheel repair,Is the diode the problem?
                                            by NicRac
                                            Hello everybody☺️ I am glad to be here and looking forward to a good discussion.
                                            First of all, I am new here. Therefore I will shortly introduce myself.
                                            I am Nico and currently I study Physics.
                                            In my freetime I like to build and repair stuff. Especially big battery's.
                                            A few years ago I got myself an electric unicycle, monowheel or however you call that.
                                            The battery bms was broken so I replaced and resolder that. Nothing big.
                                            I used this thing for some years and had a lot of fun. Unfortunately I used it last time in heavy rain. Usually everything...
                                            07-26-2024, 06:13 AM
