Cross reference for B90N08
  • ned1
    • Feb 2014
    • 139
    • usa
    Working in Hanns.g monitor HL273 with bad power supply. It appears to have short B90N08 diode. Can someone cross reference the diode since I can't find it to purchase.
  • dick_barton
    • Aug 2015
    • 6642
    • Wales
    Re: Cross reference for B90N08
    Are you sure it's a diode. Can you post a picture?
      The main fuse also blown? And yes, pictures of what you are working on.
      • ned1
        • Feb 2014
        • 139
        • usa
        I removed diode from board and all 3 leads are short to each other. The main fuse is not blown, all capacitors are ok. During lead lifting I damaged diode so I will need it anyway. I will post pictures shortly.
        • ned1
          • Feb 2014
          • 139
          • usa
          Here is the picture
          • ned1
            • Feb 2014
            • 139
            • usa
            I put the diode back for reference of placement on board. You can see damage from removal.
            • CapLeaker
              Leaking Member
              • 8136
              A 90N08 should be something like a 90A, 80V Mosfet. However, IF that is shorted, then the fuse should be blown and maybe a few more parts yet, as budm already suggested. Pictures would be nice indeed.
              Never mind me on the pictures....
              • CapLeaker
                Leaking Member
                • 8136
                Yeah... I can see it. Q2 you are talking about. That's a Mosfet. Trick is to preheat that board first, or having a sodering iron with some "Ooomph".
                • dick_barton
                  • Aug 2015
                  • 6642
                  • Wales
                  You could have removed it by applying plenty of fresh solder on the tab and keeping your soldering iron on it until you can lift it up with tweezers or small nose pliers.
                  • dick_barton
                    • Aug 2015
                    • 6642
                    • Wales
                    Digikey have some similar logic gate level mosfets eg FDD3570-ND which may be a suitable replacement.
                      BTW, that power MOSFET is for the Boost converter circuit to step up the Voltage for the LED Backlights.
                      • ned1
                        • Feb 2014
                        • 139
                        • usa
                        • ned1
                          • Feb 2014
                          • 139
                          • usa
                          So should I follow dick Barton recommendation or I need different one?
                          • dick_barton
                            • Aug 2015
                            • 6642
                            • Wales
                            If that mosfet was short circuit then it may also have damaged U1. I would also check the resistors around U1 are all still the correct value and not damaged.
                            Edit
                            What is the part number written on U1
                            • CapLeaker
                              Leaking Member
                              • 8136
                              matter effect, you would have to check the whole gate drive circuit.
                              • ned1
                                • Feb 2014
                                • 139
                                • usa
                                The marking on U1 Is OB3362HP
                                • ned1
                                  • Feb 2014
                                  • 139
                                  • usa
                                  Received FDD3570-ND and installed. Getting green light on the monitor power button indicator, but still no picture. Any more suggestions.
                                  • flocko
                                    • Nov 2012
                                    • 1121
                                    I would think the OB3362 four string LED driver IC could also be blown, always best to replaced as a pair with mosfet, and check current limiting resistors as Dick suggests
                                    • dick_barton
                                      • Aug 2015
                                      • 6642
                                      • Wales
                                      What voltages are now missing????
                                      • ned1
                                        • Feb 2014
                                        • 139
                                        • usa
                                        with board removed and plugged to 120V I am getting 5V to both 5V pins to ground in and no voltages on ENA or ADJ pins to ground.
                                        • Francesc V.
                                          Diode marked as "E57".........not able to find it by reference
                                          by Francesc V.
                                          Hi:
                                          I have what it might seem a zener diode. It's marked as E57, but I haven't found any reference that might match my observations.
                                          I've took one from the same circuit and tested isolated with the power supply and a 1k resistor. with 10V, the possible zener stays at 6.6V.
                                          It seems a SOD123 package. It measures (2.6mm x 1.6 mm).
                                          Any idea? it's a 6.6V zener?
                                          06-14-2025, 09:56 AM
                                        • connorcc2005
                                          Thermistor specs and cross reference
                                          by connorcc2005
                                          I'm getting some conflicting information and thought I'd toss it out to all of you for input.
                                          What I have is a TTC-104 thermistor. This is part of a temp sense circuit that will drive a small 12v fan to cool components mounted to SMPS heat sink.
                                          The physical diameter of the piece is 5.1mm measured with a caliper.
                                          Other than what you see in the pic, there is no other writing on the part.
                                          My research of the TTC-104 says it should read 100 ohms at 25C. Out of circuit measurements have it at approximately 100k. It does change as the temp changes....
                                          06-16-2022, 04:16 PM
                                        • asr
                                          Finding replacement diode iPad Pro 3rd gen A1701
                                          by asr
                                          Hello, I am looking for help to replace a damaged diode. The tristar was replaced and a diode was damaged in the process. I have a picture of the diode but dont have an exact donor. I mostly have macbooks for donors and only a few ipad and iphone boards. Diode part number: DSF01S30SCAP
                                          Im not sure where to find the ipad board number. Anybody have an idea where else this diode is used on other boards? Thanks....
                                          07-09-2024, 06:24 PM
                                        • unimatrix93
                                          TV backlight zener diode
                                          by unimatrix93
                                          Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
                                          So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
                                          Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
                                          The led strips has 9 6V leds.
                                          02-10-2025, 12:13 PM
                                        • NicRac
                                          monowheel repair,Is the diode the problem?
                                          by NicRac
                                          Hello everybody☺️ I am glad to be here and looking forward to a good discussion.
                                          First of all, I am new here. Therefore I will shortly introduce myself.
                                          I am Nico and currently I study Physics.
                                          In my freetime I like to build and repair stuff. Especially big battery's.
                                          A few years ago I got myself an electric unicycle, monowheel or however you call that.
                                          The battery bms was broken so I replaced and resolder that. Nothing big.
                                          I used this thing for some years and had a lot of fun. Unfortunately I used it last time in heavy rain. Usually everything...
                                          07-26-2024, 06:13 AM
