panasonic tnpa5330 transistors
  • Moreno83
    • Jun 2014
    • 2008
    • The Netherlands
    Re: panasonic tnpa5330 transistors
    Yes they read short on a normal board. Why did you remove all those fets??
    Diode RF1501 is only short if the other 6 fets are short. Same for DAF30A. If the fets on TOP op the board are short then you probably have bad buffers.
    There was no need to remove the DG302 top right on the board ?
    • Hombre
      • Jul 2013
      • 231
      • Croatia
      First test buffers for shorts, if they are bad than makes no sense to continue with repairing the board
      So put one of the probes in one of the holes where i marked it red/green and than with another one drive along the connectors for the flat cables.
      If there is a beep, buffer IC is bad.
      That ground tab between buffer connrctores looks really burned
      All of those that you removed are bad?
      Can you make a list?
      • dj01fad
        • Sep 2014
        • 92
        • romania
        I guess you have a shorted buffer on this board. in your picture, you have 3 large non smd resistors on the left side under the second buffer. if you have a short between these resistors (any leg) and the ground, then for sure you have a shorted buffer.
        • matyka
          • Jan 2015
          • 179
          • Uk
          Hello and very sorry for this update (been away Holiday)
          I have checked for shorts like Moreno83 and dj01fad said and all looks ok no shorted buffers on this board .
          When first time I have opened the tv the shorted bits was 2 fets (R6015ANX) and 1 fuse on the power supply.
          On the tnpa5330 I had short:
          Q421,Q422,Q423 ---- RJP30H2A
          Q401,Q402,Q403 ---- 30F131
          Q621,Q622 ---------- 30F131
          Q611------------------RJP63G4
          Q451------------------DG302
          IC502-----------------BD8693FVM
          Q531------------------CPH5524-TL
          This All been changed with original new ones.
          I have checked IC501 and Q501 and they are ok.
          What do you see in the picture those RFN20 (D641,D642,D643) with the plastic bits, I managed to get them broken by lifting the legs up .
          I had 1 attempt to power Up the tv and Bummm Again
          I have Q661--Q621--Q622 Shorted again.
          Tv Has 6 red light flashes now. First time was 7 .
          What value I should have on the little resistor R507 near IC502 looks like has a little hole in .
          • matyka
            • Jan 2015
            • 179
            • Uk
            Hello anyone had this problem with this TV right side of the screen is fine left side has some dots see photos please.
            • dj01fad
              • Sep 2014
              • 92
              • romania
              #26
              hello.
              because the left side is broken... service mode is not a solution for mirror
              first of all, check and clean all the connections from A-board to c-board and from c-board to panel. if it will be the same, then I say 10% is the left C-board and 90% is the panel... remove the aluminium stand mount and check all the large resistors from all the ribbons on C-boards. If you find a burn one then you have a bad COF on that coresponding ribbon. if not, try another left C-board. another test: remove the first ribbon coresponding to the bad zone (only the ribbon, leave the heatsink) and give it a shot: if it starts only vith a black stripe... it's the panel. if is the same situation... maybe is the c-board.
              If it was from the A-board you did not have odd shapes on that half of screen.
              • BigPete
                Panasonic Heatpump Dryer Repair
                by BigPete
                I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
                The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
                In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
                Unfortunately the whole machine has to come apart to fix it.
                I have...
                11-01-2025, 06:40 PM
              • Andre Gilbert
                by Andre Gilbert
                Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                11-20-2024, 08:52 PM
              • AquaMan Ua
                by AquaMan Ua
                05-17-2025, 09:40 AM
              • rivetcity
                Panasonic TX-P42UT30E, IGBTs on the SN board
                by rivetcity
                I'm having problems with my plasma Panasonic p42txu32e. The issue started about 12 months ago.
                I have a remote controlled main outlet so whenever I turn off the TV set at night, I also switch off the whole power outlet.
                It gives me a better feeling to know I don't have 230V on any cables, so my dog can't get hurt if he gets the idea to start chewing on something.
                About 12 months ago the TV started to have the following problem: when pressing anything on the RC to get it on, the red led would go off.
                Sometimes it would turn...
                08-12-2021, 01:25 AM
              • Francesc V.
                Onkyo A8200 - Not the right voltages in some transistors
                by Francesc V.
                Hi:
                I am trying to repair this amplifier that I've bought as faulty. I've found some transistors damaged, the ones where I am drawing a red circle.
                With the final transistors not yet installed (the expensive ones), I've started to measure some voltages:
                Where I am supposed to have 1.12V (base Q524/Q523) I am reading -42V..................both channels don't seem ok.
                Where I am supposed to have -1.12V (base Q526/Q525) I am reading -44V..................both channels don't seem ok.
                I removed and tested Q514,Q516 & Q513,Q515 but the analyzer...
                04-19-2025, 07:17 AM
