LG 42px3rv shouts off
  • nbdy
    • Aug 2015
    • 162
    • Croatia
    When i turn the TV for the first time it works for 1-2 minutes,then turns off ...
    Afther that when i try to turn it on it comes to orange light and red again (no turning on the screen)
    The voltage measures are all OK,the fuses are all ok ...
    I have disconected the ZSUS board and the tv goes off ...
    When I disconet the YSUS board the TV goes down after 1-2 minutes ...
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: LG 42px3rv shouts off
    What voltages are you getting: Va, Vs, etc??
    • nbdy
      • Aug 2015
      • 162
      • Croatia
      Va 190V,Vs 64V,VS-ON 4.5V,BL-ON 4.5,STBY 5V,Vcc 5.2V
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Is that with the set working ?
        • nbdy
          • Aug 2015
          • 162
          • Croatia
          What set ??? Didn't find it
          • maxvalutech
            • 804
            • australia
            He means the TV are the voltages ones you measure while it is going - take the vs va at switch on with probes already in place then check if the other small voltages stay on or not.
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Let me rephrase that for you. What voltages do you get when the Tv works and when the Tv does not work from the power supply, please measure Vs and Va mainly.
              • nbdy
                • Aug 2015
                • 162
                • Croatia
                Ok,the voltages I messured are in the 2 minutes the TV is ON
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  Ok when the Tv does not work then, in a dark room does the screen appear to glow ?
                  • nbdy
                    • Aug 2015
                    • 162
                    • Croatia
                    Must try this today, I'm at work now
                    • ReeceyBurger123
                      Never Give Up !
                      • May 2014
                      • 7325
                      • Britain
                      Ok bud, if in a dark room when the Tv does not work but screen is lit up the control board will probably be the issue but if its not lit up even slightly probably the susboards but thats unlikely we shall see anyway.
                      • nbdy
                        • Aug 2015
                        • 162
                        • Croatia
                        Ok, will check, thx for fast reply
                        • nbdy
                          • Aug 2015
                          • 162
                          • Croatia
                          Sorry didn't find the edit button for post ...
                          The TV does not glow in a dark room ...
                          The voltages on stand by are:
                          AC-ON - 4.5V
                          BL-ON - 40mV
                          STANBY - 5V
                          Vs-ON - 41mV
                          5VNom - 0V (somthing like that writes on board)
                          Vs - 300mV (YSUS)
                          +5V - 0V
                          Vcc - 0V
                          Va - 16mV
                          Vs - 220mV (PS board)
                          19V - 0V
                          6V - 0V
                          3.4V - 40mV
                          Forgot to say that when I try to power it on again the orange led glows,and goes back to red ..
                          When the TV is ON the green goes to orange and then to red ...
                          When I unplug the TV from 220V and turn it on after cca 5min it works again for 1-2min
                          • nbdy
                            • Aug 2015
                            • 162
                            • Croatia
                            Do I have to mesure somting else
                            • nbdy
                              • Aug 2015
                              • 162
                              • Croatia
                              someone to help ???
                              • dick_barton
                                • Aug 2015
                                • 6643
                                • Wales
                                Have a read though the following:-
                                https://www.badcaps.net/forum/showthread.php?t=18542&
                                • nbdy
                                  • Aug 2015
                                  • 162
                                  • Croatia
                                  thx
                                  • nbdy
                                    • Aug 2015
                                    • 162
                                    • Croatia
                                    OK,I have read the tom66 guide,but didn't find the symptoms ...
                                    My TV goes off after 1-2 minutes with no picture and no sound and I can't turn it on (orange and then red light) ...
                                    Could it be power supply
                                    when the TV is on the picture is OK
                                    • ricosavy
                                      tc-p50gt30
                                      by ricosavy
                                      My is sc board is shorting out replaced the 30f131 and rf1501 .Soon as i turn the tv on it shorts out.So what i did was put a light bulb in power cord when i turn tv on it lights on for a sec or two and tv shouts off.I disconnect the sc board from power supply and bulb lights up.Also disconnect the ss board and bulb still lights up.When i disconnect Ps2 on power supply the bulb does not light up and gets a 8blink code.I was wondering if my power supply is shorted.Looks like that supplies power to sc board....
                                      04-15-2019, 05:06 PM
                                    • BAM
                                      LG 42PX3RV-TA Sound, no pic, YSUS causes shutdown to standby
                                      by BAM
                                      Hi, been lurking amongst some of the other threads but so far haven't had any luck.
                                      I picked up a couple of non working 42" plasmas, and LG 42PX3RV and Hitachi 42PMA300A, both with the usual sound but no picture. Gave up on the Hitachi as decided not worth the time or money to fix a low res set in my opinion, but would be good if could get the LG up and running.
                                      When I got the LG most of the fuses were missing, from PS, ZSUS and YSUS.
                                      After replacing them none have blown, but if YSUS is connected, the unit powers on for a few seconds with green led, then...
                                      04-11-2013, 10:18 PM
                                    • DieselManiac
                                      Real or fake FGD4536?
                                      by DieselManiac
                                      Can someone please check if i got real or fake FGD4536.
                                      The last picture is made afther a IPA whipedown.
                                      Thanks!...
                                      08-17-2018, 11:20 AM
                                    • knightdad
                                      plamsa power supply
                                      by knightdad
                                      ok all I have an bn44-00330a
                                      working on an plasma tv set
                                      issues with set it no pic no sound trun on an relay cliks
                                      checking ps out of set the volts are there
                                      my qustions is how long should the vs va volts stay power up on ps
                                      with the ps on to gnd an vs-on to 5.3volts should the ps stay on until power of or does the ps have an protect on it to shout down
                                      the ps reads the right volts for 30-40 secs the shouts off
                                      11-20-2015, 12:17 PM
                                    • is_it_a_bird
                                      smd fuse question
                                      by is_it_a_bird
                                      Hi
                                      Before anyone shouts at me I know how important it is to get the correct fuse rating, but yesterday I got hold of a samsung with a back light fault, after stripping it down I found that it looks like it has had fluid damage as there was rust and tell tale signs on the top of the inverter, plug 1 was melted to the connector and the smd fuse had blown.
                                      I cleaned everything up and replaced the fuse, the original fuse was 3.15a 74v, I have only got 3a 63v fuses available so fitted one and the TV was playing away fine for 2 hours, it then packed up again.
                                      04-28-2013, 04:26 AM
