plamsa power supply
  • knightdad
    • Apr 2015
    • 54
    • usa
    plamsa power supply
    ok all I have an bn44-00330a
    working on an plasma tv set
    issues with set it no pic no sound trun on an relay cliks
    checking ps out of set the volts are there
    my qustions is how long should the vs va volts stay power up on ps
    with the ps on to gnd an vs-on to 5.3volts should the ps stay on until power of or does the ps have an protect on it to shout down
    the ps reads the right volts for 30-40 secs the shouts off
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: plamsa power supply
    If the relay clicks more than likely the PSU is good. Post clear pics of back side of PSU and I may be able to guide you into performing a self-test. Do you have two incandescent light bulbs 100W 120 or 230 Vac available?
    • JimBanville
      Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
      by JimBanville
      The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
      I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
      09-13-2023, 07:21 AM
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • CMCM
      Russound CA4 Power Supply Repair
      by CMCM
      Hello Everybody,
      Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
      Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
      The outputs marked 12v and 20v are all measuring only 1v.
      The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
      The capacitors physically look clean (no bludgesor leaks) and...
      07-03-2025, 01:12 PM
    • Gust zhang
      Mid 2014 A1398 MacBookPro,Is it feasible to remove the battery from the MBP and connect it to an external power supply?
      by Gust zhang
      ​I have a 15 - inch Retina MacBook Pro from the mid - 2014 model. Here is the link: https://www.badcaps.net/forum/showth...light=820-3662 . The battery broke some time ago. After I removed the battery and plugged in the original power adapter, the MBP could boot up normally. However, when I checked with IntelPowerGadget, I found that the CPU speed was limited to 0.8 GHz, and it ran very slowly. Later, I found a solution on GitHub. There is an open - source project called cputune that can set the CPU running speed. So I can now run the MBP at full speed. But another problem...
      02-16-2025, 08:39 AM
      12 volt switching power supply modification to 14.5 volts before blocking diode add
      I saw this switching power supply on eBay and wanted to see if could be modified to run 14.5 volts before the blocking diode was add and this switching power supply seems to have no issues doing this
      I did recap the switching power supply except the the main filtering capacitors and I managed to break the selector switch for the voltage setting but just jumped it
      One note I used 25 volt capacitors on the output side of this power supply because they used 16 volt capacitors and because I am running the voltage up a little bit higher 12 volts to 14.5 volts there would...
      04-11-2021, 11:01 AM
