LG 60PV450-UA.AUSLLHR, repeat YSUS failure
Re: LG 60PV450-UA.AUSLLHR, repeat YSUS failure
Okay, I was reading those test points incorrectly. Here is the results when the buffer was connected:
VSC: 15v
VY: -180v
VZB: 0.00v or occasionally 110v, but only for a moment, then stays at zero. Very strange.
With buffer removed:
VSC: 0v
VY: -180v
VZB: starts around 40v or so and drops quickly to 14vComment
You have a short on one if your susboards again then. You need to test the Igbts in the erc track mainly.Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
https://www.facebook.com/Telford-Tel...7894576335359/Comment
Apologies for my ignorance, but what do you mean by that? Can you explain how to do that? I appreciate your assistance and kindness tremendously!Comment
I have the same LG TV model, there is no audio only video, after reviewing the Y board, I noticed that the resistors on the SMD surface are burned, also the transistors FGPF4633, someone that could tell me the values of these resistors circulated in red.Last edited by andariego; 03-14-2018, 11:26 PM.Comment
no one? ThanksComment
by corrizeHello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping... -
by MicroSMD LabThe board number is GU502DU. I repaired this a couple weeks ago and it came back with the same issue, same mosfet failed (PQH9201). I'm hoping that the GPU was spared this time.
I used the same replacement part (purchased from Mouser) and I'm certain the soldering was done properly since it took just as much effort to remove as before. What could cause this same mosfet to fail? I'm thinking if it was unsuitable then the others would fail too. I looked for similar failures on YTube and the mosfet was replaced with AOE6930 in one instance and AOE6932 in the other but it's possible that the... -
TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...-
Channel: Common Parts Library - Datasheets
10-07-2024, 06:07 AM -
by jesteraceHi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
by jshhhHi guys,
I'm inexperienced with electronics repairs, I've done a little bit of soldering caps and whatnot, but i have a blown fuse on this mimaki printer I got which I have bought a replacement for.
How do I remove this type of fuse (see picture)...it kinda looks like it would pull out of that bracket but it didn't come at first pull and I didn't want to brute force it incase it's soldered on there like most of the rest of the components.
Anybody know how to remove this type of fuse?
(The fuse is toward the bottom of the image labeled F2)... - Loading...
