I got this set, and on plugging it in it had 1 blink. Tried with isolation of SC and SS board, and everything seemed fine.
Then noticed that everything is corroded on A board, especially A32 connector, it really looked very bad, so assumed that is the problem and i ordered new a board.
Got it - again 1 blink. Had no idea what else to try, because 2 main boards gave me 1 blink, thought maybe panel is bad.
Remembered tw fixed some 1 blinkers. So i got an ebay ch341 flasher. In mean time i acquired a TX-P42C2, and downloaded EEPROM IC9304, save it on my PC.
Today i tried again to check this 37c2, again 1 blink, checked everything else and everything is pointing to a board.
Flashed TX-P37C2 with TX-P42C2, plugged it in, turned on, and no blinks
Perfect picture, didn't try anything else like hdmi, only terrestrial but i assume it should work.
A board is TNPH0829, flashed IC9304.
So attached is bin file for TX-P42C2, but it should and it will work on TX-P37C2 1 blinker.
Thank you tw2005, it's your fix
all round. Your shout
