Panasonic th-p42x10z
Re: Panasonic th-p42x10z
OK cheers for ya help and advice anyway really appreciated and no one else wanted to comment lol
Now to see if we can get Russell's tv going.Comment
Nick has very kindly let me try his power supply pcba and I'm pleased to confirm that the picture is now completely normal. Vsus and Vda are stable under load unlike my pcba where they seemed to sag. So am now confident that this was causing the picture issues.
Unfortunately this doesn't help Nick with his set though.
Kind regards
RussellComment
tw2005, we appreciate the help and the time that you give. Who would think that it wouldn't show an error with that drop in voltage. My thoughts without investigating are that either the Power board is saying all is fine or that this error isn't being checked for after the display is turned on. Probably the first is most likely and is part of the board fault that it thinks it's in regulation with load when it's not.
Nick hasn't given up on his yet, he is just busy with other things at the moment. Kind regards
RussellComment
yes really appreciated all the advice and feedback you gave us tw2005,at least we fixed one problem.
Now this maybe a silly question but was just reading on another forum about a panasonic plasma with 6 blinks when plugged into an extension cord but turning on when plugged straight into the wall socket... now do you really think this would make a difference because i just realised everytime i plugged my tv in it was plugged into an extension cord and i never tried it into just the plug. hmmm not really hopeful but i guess it could be possible..Comment
sounds crazy, you'd have to wonder how many amps it was drawing.yes really appreciated all the advice and feedback you gave us tw2005,at least we fixed one problem.
No I think short of finding a working TV and swapping your boards one by one into it to replicate the fault, I have no ideas at all.Comment
Well I gave up on my original tv for a while but i have just managed to get hold of a second tv of same model..This one had the 12 flashes of led when powered on so changed my A board over and to my surprise it goes lol just not 100% the screen has 2 little vertical lines one each side of panel so now i hope its one of the spare boards i have and not the panel itself...Comment
well this tv went for about 5 mins with the 2 lines on the screen and not sure what i did if i just unplugged the wrong cable or something but when i turned it back on i was back to the same 6 blinks that i had with the other tv so after 9 months of this tv sitting in the spare room in bits i think i ready to give up. I think i will take the boards out and try to sell them since i believe its the panels that are the problem...lesson learnt dont play with plasmas lol
Anyone interested in the boards?Comment
Been heree before. Clip sos6 from SS output to bottom panel driver boards. It's an erroneous error. Panasonic's are very temperamental with vertical VA buffer shorts.Did I leave the soldering iron on?Comment
Assuming...7 Photos -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by sam_sam_samI did not have any 27uf @ 50 volt capacitors but one nice thing is that it has enough room for two capacitors in parallel a 22uf and a 4.7uf @ 50 volts 22 plus 4.7 equals 26.7uf which so very close to 27uf I will show some pictures of it sometime tomorrow
After all of... -
by canadaboy25I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was... -
by hartleyhare5Post body:
I'm working on my Samsung QE65Q9FN (65" Q9FN QLED, European model) with relay clicking and no picture. The power supply board in the display itself is the BN44-00944A, known on the board itself as the 65A board (silk-screened designation). There is also a second board, the 65B, which looks identical but is only partly populated for the LED power.
Symptom: Continuous relay clicking on the one connect — TV will not start up, no picture. However the standby LED is on constantly — so the standby supply rail appears to be alive and the... - Loading...
