Panasonic th-p42x10z
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic th-p42x10z
    Originally posted by lambchopsnz
    Ok so I managed to test a couple of vsus points which were 187.7v before the tv shuts down again,the sticker says 187v so I'm guessing this means the power supply is working ok.
    Cheers
    Nick
    try checking TPVAD and TPVSCN on the SC
    • lambchopsnz
      • Jul 2016
      • 63
      • New Zealand
      Yeah I will do that again and write the result down this time.
      • lambchopsnz
        • Jul 2016
        • 63
        • New Zealand
        ok so i did some more testing on the tv tonight and these are the results i got...
        TPVSUS (SS)187V
        TPVe (SS) 125V
        TPSS1 (SS) 15V
        VSET (SC) 190V
        VAD (SC) -180V
        VSCN (SC) -35V
        TpVSUS (SC) 187V
        TPSOS6 (SC) 5.72V
        TPVDAT (P) 60V
        TPVSUS (P) 187V
        The Ve on the sticker is 125v and the Vsus is 187v does this mean the power supply is working ok?
        cheers
        Nick
        • tw2005
          • Oct 2011
          • 6458
          TPVSUS (SS)187V
          TPVe (SS) 125V
          TPSS1 (SS) 15V
          VSET (SC) 190V
          VAD (SC) -180V
          VSCN (SC) -35V
          TpVSUS (SC) 187V
          TPSOS6 (SC) 5.72V
          TPVDAT (P) 60V
          TPVSUS (P) 187V
          cheers
          Nick
          Puzzling, isn't it. Was Vset 190V or 290V
          • lambchopsnz
            • Jul 2016
            • 63
            • New Zealand
            oh my mistake it was 290v
            • tw2005
              • Oct 2011
              • 6458
              even better, so for the Vscn measurement how were the probes connected?
              Red to ?
              Blk to ?
              • lambchopsnz
                • Jul 2016
                • 63
                • New Zealand
                #27
                All measurments were taken with the black probe on the chassis metal and red on the test points i could find printed on the boards.
                • tw2005
                  • Oct 2011
                  • 6458
                  TPSS1, definitely 15V ? Just going through some history 102V on a 42X20 but that's with a running panel.
                  • tw2005
                    • Oct 2011
                    • 6458
                    So all the values on the Sc are good except TPSOS6 is obviously high and tripping the A board.
                    Do you have the old SC board?
                    • lambchopsnz
                      • Jul 2016
                      • 63
                      • New Zealand
                      #30
                      yeah im pretty sure this was 15v or close to that i can re check tomorrow. This is also the ss board i got through ebay not the original.
                      yes i do have the original sc board and buffers also the ss board.
                      • tw2005
                        • Oct 2011
                        • 6458
                        Well it's a shit deal but it may be worth checking a few things.
                        Check the C2 board, the ribbons between that and the A-board (2 of) , corrosion etc.
                        Check the SS has all the leads connected including SS23 - C23
                        Try the old SS
                        Replace the C2 board
                        Don't know how much you've sunk into this but It says either c21 or c22 removed triggers SOS 6. If one of those little 20 pin buffer ICs has failed that could also produce the same effect.
                        Failing thtat then that leaves the A board I guess although it appears at the moment to be behaving normally.
                        DO NOT run the TV with any of those bottom panel ribbons with them unbolted or not heatsinked. I think the sinks are on the ribbon anyway but best to have these all bolted just in case otherwise if they heat up and burn out it's all over.
                        I removed a metal strip once on a Samsung not realising it was a heatsink, burnt out the lot of them, panel destroyed.
                        • lambchopsnz
                          • Jul 2016
                          • 63
                          • New Zealand
                          #32
                          well i haven't spent to much on it and its been an experiment lol just harder than i expected.
                          I did check those ribbon cables from the c2 board and they looked perfect all the other cables are connected i will try putting the original ss board back in and re-test the voltages.
                          If that fails i will see if i can get a c2 board. I have been believing it was the A board most of the time and the guy i got the 3 boards was going to send me one to see if it made a difference unfortunately for me he sold his last one the other day so i will see if he has a C2 board to match and try that.
                          Thank you again for all your help tw2005 i really appreciate it and im glad i found this forum.
                          I will keep you posted with any updates.. and i hope i can find a board or an A board.
                          cheers
                          Nick
                          • lambchopsnz
                            • Jul 2016
                            • 63
                            • New Zealand
                            #33
                            I changed my ss board back to the original one and retested TPSS1 i think the first test showed 120v but not 100% sure now since i retested and got 15v each time.
                            I also tried unplugging the white ribbon cables from the C boards to the A board and with the 2 from the C boards and the 1 from the SC board disconnected the led stays green and the tv stays on but with the 2 ribbons from the C boards connected and just the SC unplugged i get 8 blinks.
                            cheers
                            Nick
                            • tw2005
                              • Oct 2011
                              • 6458
                              cheers
                              Nick
                              The 15V could be normal until the panel comes on. On mine I see 15V then 95v with the panel on.
                              When I disconnect sc20 only I get 6 blinks. Is that what you did for your 8 blinks? Also I see 15V and for a blink it goes OL as ittrips. I would say this is when the panel is about to come on and the SOS shuts it down. The meter is too slow to give the reading as it's auto ranging at that point , hence OL.
                              • lambchopsnz
                                • Jul 2016
                                • 63
                                • New Zealand
                                #35
                                Yeah I'm pretty sure it gave me 8 blinks
                                • tw2005
                                  • Oct 2011
                                  • 6458
                                  If I disconnect one of the C2 board ribbons I get 8 with sc20 disconnected as well.
                                  Seems to point to the C board because if I disconnect just the C board ribbon I get 6 which is your original fault.
                                  • lambchopsnz
                                    • Jul 2016
                                    • 63
                                    • New Zealand
                                    #37
                                    Yeah I was thinking that thanks for your help I'm just waiting to hear back from a guy to see if he's got a C board if he doesn't not sure what I'll do next..
                                    • tw2005
                                      • Oct 2011
                                      • 6458
                                      there's plenty around on Ebay. Not a common board to fail.
                                      Sometimes payless works out ok if you get stuck, postage kills it a bit
                                      http://www.paylesscomponents.com/pan...-tnpa4893.html
                                      May be worth considering getting both c1 and C2 if you can just in case it may be either C board
                                      can't promise this is it but there are not many boards left to swap.
                                      reminds me so much of my X20, absolute nightmare to fix
                                      • lambchopsnz
                                        • Jul 2016
                                        • 63
                                        • New Zealand
                                        #39
                                        Cheers for that I did think I probably need to replace both.
                                        Do you think there's a high chance it could be the panel instead of all these boards? I really hope not.
                                        • tw2005
                                          • Oct 2011
                                          • 6458
                                          Doubt it.
                                          The worst thing about this is being wrong but you've replaced the obvious stuff with no luck, keep plodding along, all you can do.
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            05-12-2025, 08:37 PM
                                            After all of...
                                            07-13-2024, 08:14 PM
                                          • canadaboy25
                                            Panasonic TC-P54VT25 No image. A or D board?
                                            by canadaboy25
                                            I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
                                            I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
                                            01-17-2021, 01:06 AM
                                          • Biruslapio
                                            Panasonic P50VT20B Plasma 12 Blinks, Power Supply or A-Board?
                                            by Biruslapio
                                            Hello, I've had this TV for 3 years, 2 years ago it stopped working signaling 12 Blinks, SOUND_SOS according to the service manual.
                                            It has no VSUS or VDAT, and P15V has 1.0V instead, the same 15V goes to A board. F15V is ok and other main voltage rails.
                                            It seems the power supply is defective, since unplugging D20 ribbon cable that goes from D-board to SC-board makes the behavior change, the TV stays on, there's no image nor VSUS, but 15V reads 2.4V, high enough to not trip the SOS 12 blinks, so it stays on, fans do not spin but I left it 2 hours, green led lit up...
                                            02-16-2021, 09:44 PM
