Panasonic SA-BT230 "Please Wait"
  • midsomerjambo
    • Jul 2016
    • 8
    I have a SA-BT230 home cinema system that is showing "Please Wait" all the time. On a different thread I was able to obtain a copy of the service manual and proceeded on the assumption that something was probably wrong with the power supply (SMPS).
    I carried out the continuity checks on the main transformer (admittedly in situ) as indicated in the service manual. When I checked between pins 16 and 17 I got a short. According to the circuit diagram, pin 17 is +18V and pin 16 is ground. I'd have expected a short here to blow the fuse but it hasn't. Anyway, on checking the voltage across the speaker connectors I had about 0.5V on 1, 2, 3 and 4 and next to nothing on 5 and 6. Going by what was said on the earlier thread, that would indicate that the D-amp IC responsible for those speaker outputs is fried.
    If this is the case, ideally I'd replace the D-amp and the SMPS boards (I don't see me replacing the IC), but I can't find a source for a SMPS board and the D-amp sources I found are all overseas. I could source a replacement transformer but I've no way of telling whether any of the other SMPS components are fried and I don't want to put a new D-amp in just to have it blown because the SMPS is still misbehaving.
    Any suggestions (apart from buy a new system - which I'm starting to seriously consider)?
    Regards, MSJ
  • dick_barton
    • Aug 2015
    • 6642
    • Wales
    Re: Panasonic SA-BT230 "Please Wait"
    What voltage do you have when you measure between pin 16 & Pin 17.
    • midsomerjambo
      • Jul 2016
      • 8
      If it's reading short on a con check, I'd have thought 0V but I'll check and let you know. I intend to remove capacitor C5183 from the SMPS PCB and test it for a short in isolation although I'd be surprised as I'd expect a capacitor to fail open circuit. If that checks out, I'll remove the main transformer and test it in isolation.
      Regards, MSJ
      • dick_barton
        • Aug 2015
        • 6642
        • Wales
        Regards, MSJ
        Transformers having a low dc resistance reading is normal.
        • dick_barton
          • Aug 2015
          • 6642
          • Wales
          Have you tried any of the other outputs ie. video out and connected that to your tv?
          • davph
            • Apr 2014
            • 23
            Hi
            Try main smoother capacitor in power supply. Sorry cant remember circuit reference but have seen it o/c a few times.
            • R_J
              • 9535
              If you are getting "Please wait" I doubt the fault is with the power supply. most likely logic board
              You could try a master reset:
              While the unit is off, press and hold [+VOLUME], [OPEN/CLOSE] and [POWER] on the main unit at the same time for more than 5 seconds.
              • davph
                • Apr 2014
                • 23
                Yeah R_J you would think so but I've had the fault a few times. Will show "Please wait" or "F76" replacing C5712 has cured the fault.
                • R_J
                  • 9535
                  This is from the manual:
                  F76 error is "Abnormality in the output voltage of stabilized power supply" Description of error "in normal operation when DCDET1 is detected (low) for two consecutive times, F76 is displayed on FL for 1 second and after that PCONT will be turned to (low). This is due to any of the DC voltages (+9V, +7V, -7V, +5V, +5.3V etc.)
                  so bad C5712 (main filter) could cause the error.
                  Also mech & main board are replaced together ( I did a bunch of these when they were unde warranty)
                  • midsomerjambo
                    • Jul 2016
                    • 8
                    Many thanks chaps, I'll try replacing the cap as advised and let you know. However, I did check the output voltages to the Power PCB, Main PCB and D-Amp PCB and they all *seemed* to be OK.
                    Regards, MSJ
                    • joegalati
                      • Aug 2016
                      • 4
                      Hi midsomerjambo,
                      The symptoms you describe are exactly the same as I am having with my Panasonic BT337. They are almost identical models I believe.
                      Mine had been repeating the "Please Wait" message for the past couple of years, once or twice a year, but power cable out/in always seemed to fix it until today.
                      Just wondering if you had discovered anything since your last message.
                      Cheers,
                      joe
                      • midsomerjambo
                        • Jul 2016
                        • 8
                        I'm waiting for a replacement cap to be delivered but meantime maybe someone could suggest how to test the existing cap out of circuit. It doesn't look damaged and I'd have thought a duff electrolytic cap would show some physical sign of a problem. Also, the circuit diagram says the cap should be 270uF/400V but the actual cap on the board is 180uF/400V. Should I replace like for like or go with the circuit diagram/parts list? A word of warning - the underside of the PCB is marked "HOT" near the cap and they ain't joking - even disconnected for days it will bite if you touch anything bare in the vicinity (which sort of makes me wonder if there is actually anything wrong with C5712).
                        Cheers, Gerry
                        • joegalati
                          • Aug 2016
                          • 4
                          Update: I replaced C5712 on my BT337. The replaced cap was exact same specs as original capacitor.
                          No joy - issue "Please Wait" loop still persists.
                          Would appreciate any ideas that haven't already been mentioned above if someone comes across this thread.
                          Thanks in advance.
                          • Briesmith
                            Can High Side damage on an SMPS get across the Transformer to the Low Side?
                            by Briesmith
                            I have a blown smps and I am looking for some reassurance as to the amount of diagnosis I have to do. It blew the instant I plugged it in not under any load.
                            As you can see from the attached pix, the damage is located around the main or bulk capacitor (since removed for testing) and the resistor array/network that drives it (the bunch of SMD components to the left of the YAMAHA YC775 AMPS logo). The burn mark on the frame clearly shows the pins of the capacitor. And, for the avoidance of doubt, there is no way the board could have contacted the frame, it was correctly mounted on...
                            05-06-2023, 09:36 AM
                          • Andre Gilbert
                            by Andre Gilbert
                            Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                            Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                            11-20-2024, 08:52 PM
                          • mikey5791
                            Is it possible for transformer substitution?
                            by mikey5791
                            Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
                            Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
                            My questions are
                            1. How do i test to see if the transformer is in good working condition?
                            2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
                            Hope you guys understand what i was asking. My intention is...
                            11-03-2022, 02:11 AM
                          • PlayerOne
                            Velodyne SMPS, power transformer
                            by PlayerOne
                            I need help in finding a schematic or otherwise identifying the electrical characteristics of a transformer in a SMPS having the following marking:
                            042-010214-000ZR
                            ELY 1317
                            A photo of the transformer is attached. In particular, this is a PCB mounted transformer and I need the pinout.
                            I've tried Google searches of various portions of the part number with no luck, however managed to find posts with photos of this transformer having the same markings, except for the numbers following the “ELY” which leads me to believe they must be date code...
                            03-31-2020, 12:37 PM
                          • dennis_elx33
                            3PHASE STEP-DOWN Transformer in Check
                            by dennis_elx33
                            Hello All,
                            i would like to post an interesting topic regarding 3-phase stepdown transformer which we suspect to cause an overcurrent (138A) which resulted to power tripped off of the HV power supply (80KV output).
                            Problem statement: Power tripped Off
                            Initial Problem: Found 2 IGBT and 2 rectifier diodes shorted (burnt).
                            Action Done:
                            1) Replaced the faulty parts with good spare.
                            2) Measured impedance of the 3phase input lines and found that L2 to L3 has 23.3ohm while other pairs are 51Kohm. This pins will...
                            12-02-2024, 06:52 AM
