Help! My Panasonic TC-P65ZT60 wont turn on!
  • djw43
    • Mar 2015
    • 95
    Re: Help! My Panasonic TC-P65ZT60 wont turn on!
    Will check once home
    Thanks!
    • djw43
      • Mar 2015
      • 95
      hahaha, i tried, but couldn't find the PCM setting last night!
      i have a ZT card due by tmr, so I am hoping that will help. If not i will be back to the drawing board.
      thanks all
      • budwich
        • Jul 2015
        • 3097
        hopefully it will work. If you post what you see in the sound mode settings, the "clues" maybe obvious.... maybe. I take it you have never used / seen this set / type in operation.
        • djw43
          • Mar 2015
          • 95
          yes, i have P65S2 and i rarely adjust the settings
          • budwich
            • Jul 2015
            • 3097
            ah but I think the S has differences in settings than post s versions... it was panasonics way of making things better... :-)
            • djw43
              • Mar 2015
              • 95
              TNPH1043UE for P65ZT60 arrived, and I plugged it in and I have sound!
              Thanks everyone, sorry if i wasted anyones time.
              • budwich
                • Jul 2015
                • 3097
                great... glad things are working.
                • lwrs10
                  • Nov 2018
                  • 10
                  I know this is digging up an old thread, but where di you find that A board at? I have the same tv and need one. Can't find one.
                  • m1ch43lzm
                    by m1ch43lzm
                    05-12-2025, 08:37 PM
                    by sam_sam_sam
                    After all of...
                    07-13-2024, 08:14 PM
                  • canadaboy25
                    Panasonic TC-P54VT25 No image. A or D board?
                    by canadaboy25
                    I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
                    The panel is primed as there is a slight glow from the entire panel. This means the problem should be logic related. The service manual also confirms this and recommends replacing the A or the D board.
                    I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
                    01-17-2021, 01:06 AM
                  • howardc64
                    by howardc64
                    07-24-2025, 05:17 PM
