60PA5500 dead as Dillinger - no picture, no sound
  • Cipher108
    • Jul 2016
    • 15
    I have an LG 60PA5500-UG with no picture, and no sound (most of the time, I'll explain).
    I've removed the back cover, and checked the three fuses in the power supply. I've also visually inspected for blown caps, but don't see any.
    In line with other advice here, I've powered the unit down and restarted with only the zsus disconnected, then again with only the ysus disconnected. No change in state fit either.
    Before the unit died (I think it's dead) the USB ports failed one by one. I'm down to one working (if I can ever make the tv work again). I'm thinking this is a problem with the input board. When it's plugged in, a single red led lights up on the board marked LD500 C500. Is this an error code?
    Same said for powering up. It clicks on right after I apply power, and the red stand by light next to the power button comes on. However, if I press the power button, there is no click, the red standby light blinks twice, and nothing else happens. Repeated pushing of the power button does nothing.
    Where do I go next?
  • Moreno83
    • Jun 2014
    • 2008
    • The Netherlands
    Re: 60PA5500 dead as Dillinger - no picture, no sound
    You need to measure the voltages going to the mainboard. Just looking at your thread i will say the mainboard is getting the standby voltage but does not turn on the tv.
    • Cipher108
      • Jul 2016
      • 15
      Attached pictures of the input board.
      Oh, and about the sound: I did get it to give me some static, but no picture, only once. I think it's stuck on an input with nothing coming in. But I can't change the input to test again because I can't see the screen...
      • Cipher108
        • Jul 2016
        • 15
        Thanks Moreno! When you say "the main board" Is that what I'm calling the "input board"?
        • CapLeaker
          Leaking Member
          • 8177
          Originally posted by Cipher108
          Thanks Moreno! When you say "the main board" I'd that what I'm calling the "input board"?
          Like in your post #3 first picture. That's the main board.
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Probably Bga solder under the main Cpu which is mounted under the heatsink on the Mb. Maybe reflow it see if it sorts it ?
            • Cipher108
              • Jul 2016
              • 15
              Update, I now have sound but no picture. I tried measuring the input voltage to the main board, but my DMM is made for electrical work and not electronics. I sparked it once by touching two pins simultaneously.
              I'm going to take that as it having power...
              • Cipher108
                • Jul 2016
                • 15
                Thanks Reecey. I read another post that said to remove the main board and "bake it" at 400° for ten minutes to re flow. I did that, but no results.
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  Hmm ok I misread this, have you ran the sets test patterns ?
                  • Cipher108
                    • Jul 2016
                    • 15
                    Not sure I can with no image.
                    • dick_barton
                      • Aug 2015
                      • 6643
                      • Wales
                      It bypasses the main board.
                      If you have an image then you most likely have a faulty main board
                      If you dont then you need to investigate further.
                      https://www.badcaps.net/forum/showth...a+test+pattern
                      Have you measured all the voltages to see if any are missing, IE VA, VS, VZB etc
                      • Cipher108
                        • Jul 2016
                        • 15
                        There are two rows of pins, and a key coming of the power board (picture attached). The pins are in rows of nine (top and bottom). I disconnected the wiring harness to the main board, and measured the voltages supplied. They are (name, then measurement)
                        1) "17V" measured 17.3V
                        2) "GND" measured 0V (of course)
                        3) "5.1V" measured 5.1V
                        4) "Error Detect" measured 5.1V
                        5) "GND" measured 0V
                        6) "GND" measured 0V
                        7) "Stby" measured 5.1V
                        8) "AC Det" measured 0V
                        9) "Auto gnd" measured 0V
                        Then the bottom set of pins
                        4) "5.2V" measured 4.8V
                        8) "AC Det" measured 4.8V
                        9) "Auto gnd" measured 3.8V
                        Figuring that "Error Detect" might be an error flag, I unplugged the zsus, and checked again - still 5.1V. Then I reconnected zsus, unplugged ysus, and checked again - it dropped to 0V!
                        Does this mean there's a problem with the ysus?
                        • Cipher108
                          • Jul 2016
                          • 15
                          Next, I checked the power coming into ysus (again, picture attached). They measured
                          "VS" measured 205V
                          "VA" measured 55V
                          "M5V" measured 5.1V
                          • Hamie
                            • Apr 2014
                            • 1383
                            Run test patterns as previously advised.
                            • Cipher108
                              • Jul 2016
                              • 15
                              I read the post on how to do that. Maybe I'm thick. But it looked like it was for Samsung and Panasonic tv's...
                              • Hamie
                                • Apr 2014
                                • 1383
                                Upload picture of control board
                                • Cipher108
                                  • Jul 2016
                                  • 15
                                  Picture attached to post 3
                                  • dick_barton
                                    • Aug 2015
                                    • 6643
                                    • Wales
                                    Picture 3 is the main board not the control board
                                    https://www.badcaps.net/forum/showth...ght=tom+plasma
                                    • Cipher108
                                      • Jul 2016
                                      • 15
                                      Thanks guys. I'm trying to keep up with the terminology (and failing). I appreciate your patience.
                                      • dick_barton
                                        • Aug 2015
                                        • 6643
                                        • Wales
                                        Follow the link in post#18 which tells you how to complete this test.
                                        • ChaosLegionnaire
                                          by ChaosLegionnaire
                                          09-13-2022, 09:02 AM
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • Ierwin
                                          by Ierwin
                                          05-13-2025, 03:31 PM
                                        • jchang
                                          Samsung UN70NU6900F no picture and no sound
                                          by jchang
                                          Hi all
                                          I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                                          Symptom:
                                          No picture no sound.
                                          When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                                          No sound at all.
                                          What I tried:
                                          1. I tried unplugging the left or right ribbon...
                                          01-09-2023, 06:28 PM
