Sharp LC-42D69U won't turn on, has 5V standby.
  • kevinm34232
    • May 2012
    • 1884
    Seemed like a main board issue. So I jumped PS-ON and BL-ON, backlight flickering. The 12V voltage comes up, but 24V is erratic, bouncing from 21-26V, every once in a while settling in at 24V. This happens with or without inverter board conncected.
    So I think the main board is bad, and another problem on the PS.
    Is there something common that would cause this unstable voltage, even with no load?
    Also note the voltage at the large cap also fluctating when PS-ON, from 390-398V +-
    Attached is SM, and you can find schematics starting on page 119. Any help would be apprecited! Thanks
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Sharp LC-42D69U won't turn on, has 5V standby.
    So you have a Power Board issue......Why do you think you also have Main Board issue, though???
    • CapLeaker
      Leaking Member
      • 8138
      Cuz he can't turn the tv on, so he forced the PSU.
      • cts_casemod
        • Jul 2016
        • 8
        • Lisbon
        Generally a bad 24V supply will affect the backlight only, not the logic.
        On your case it might be caused by a high ESR on capacitors, but as said earlier, this should not stop the main board and LCD panel from turning on.
        • cts_casemod
          • Jul 2016
          • 8
          • Lisbon
          Also forgot.... It is normal for the HV capacitor voltage to oscilate as much as +/-15V, thats the Power factor correcting IC regulating to keep the input current sinosoidal (If the supply didnt had PFC you would see rectifid mains, at about 320-360V or half of that for 115V countries)
          This is normal and not a fault.
          • kevinm34232
            • May 2012
            • 1884
            So I should start with the secondary caps? None are bulging, it's a somewhat newer TV so I didn't suspect them..
            • CapLeaker
              Leaking Member
              • 8138
              To clear this up: do you get PSON and BLon from the main board?
              • kevinm34232
                • May 2012
                • 1884
                No. Just standby 5V+, power on comes from button controller board, but nothing else.
                  Since you are not getting the PS-ON command from the main baord to turn on the power supply, then how about the BL-ON and the DIM command signals, are they present?
                  BTW, the switched 12V and the 24V are generated by the same power transformer, so
                  • kevinm34232
                    • May 2012
                    • 1884
                    The 12V is pretty stable. What does that mean? I'll have to double check, but I don't think I had any voltage except 5V standby.
                      If the main board does not send the PS-ON then you are going to have any output at the switched 12V or the 24V, at least right now you do have main board problem.
                      • Andrew F. Ali
                        • Jan 2014
                        • 2450
                        • Trinidad & Tobago
                        OOPS!! Some how missed that
                        • kevinm34232
                          • May 2012
                          • 1884
                          I am jumping the PS-ON and BL-ON with 3.3V, and turning on the PS. This is when 12V and 24V come up, but I the backlights were flashing on and off. When I checked 24V line it was fluctuating.. I am just trying to see how I can narrow down where the problem on the power board is. I know the main board is bad too.. Thanks.
                          • CapLeaker
                            Leaking Member
                            • 8138
                            have a look at the feedback circuit of the 24v supply. There is also an overvoltage protection circuit that needs to be checked.
                            • kevinm34232
                              • May 2012
                              • 1884
                              What would be a good starting point, I have not done much t/s'ing on these circuits?
                                The dim command signal stable?
                                • kevinm34232
                                  • May 2012
                                  • 1884
                                  Is DIM the BRIGHTNESS as in photo? I'll have to check again, but I think there was 0V. And remember, this is with the main board disconnected from the power board.
                                    the brightness is the same as DIM, 0VDC = NO BACKLIGHTS.
                                      BTW, what is the LCD panel model number?
                                      • PNI E.
                                        Samsung ue55tu7170u not turn on and no standby led main bn9650990e
                                        by PNI E.
                                        Hi guys, I’m back here my friend give me her tv, that doesn’t turn on and no standby red led. When u plug in the cord the red led of one two second is on, then turn off. If you push the power button or the remote the red led blinks but nothing happen. I give u some photo with voltage, don’t look the fuse….because I blow it for mistake nd I dint have the right replace so I just put it for test the tv. The standby voltage should be 11,88 volt on the diode, but I have 13 volts. I put in the photo the different volts I test and there are someone negative…I don’t know if it s normal. On...
                                        03-17-2025, 04:23 AM
                                      • madsox
                                        Harman Kardon AVR 171S - standby led lights up, does not turn on
                                        by madsox
                                        Greetings!
                                        Thank you in advance for your understanding, I am writing to you through a translator.
                                        A Harman Kardon AVR171S amplifier was given.
                                        The history of the machine is as follows:
                                        It was faulty when I bought it, I want to fix it.
                                        I replaced the HDMI switch and one of the DAC ICs in it.
                                        After that it worked without a problem.
                                        I watched a movie using the amplifier, and at the end the amplifier got really hot.
                                        The cooling was faulty, I will fix this later.
                                        I switched it to standby mode, waited for...
                                        09-24-2022, 10:46 AM
                                      • pajdek
                                        Lenovo Y700-17ISK turn on and off
                                        by pajdek
                                        Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                                        09-20-2023, 02:49 AM
                                      • SJX1290
                                        Sharp 50BL2AE stays on standby
                                        by SJX1290
                                        Hi,have Sharp 50BL2AE which is not powering, stays on stand by, White control led is permanently on, signal from remote is coming on board as well from power -mutifunctional button on back side. All power voltages seems to be ok. Backlight checked, working..
                                        Any ideas?
                                        12-10-2024, 01:17 AM
                                      • Egidio85
                                        SHARP LC-40LE814E does not turn on 2 flashes
                                        by Egidio85
                                        hi, I have a sharp tv model LC-40LE814E with DPS-126CP-1 A power supply.
                                        the tv initially turned on, displayed the image for 10 seconds and then turned off. so in a loop until the power was cut off.
                                        reading the classic optocoupler problem I changed the mounted cosmos with SHARP PC817 recovered from other boards.
                                        now the TV turns on for 1-2 seconds and turns off giving 2 flashes in the front LED.
                                        to avoid banging too much I preferred to take an identical tested and working card (or so the supplier says)
                                        07-21-2023, 11:49 AM
