Panasonic P42UT30 with 14 blinks.
  • Moreno83
    • Jun 2014
    • 2008
    • The Netherlands
    Hey guys ,
    It's been a while but im back with repairing tv's.
    Picked up this nice plasma tv from Panasonic and its giving me 14 blinks. No green led , just red LED with 14 blinks.
    So this is what i have done/tested.
    1) No shorts on P2 / P11 / SN2 / SS 11
    2) No shorted IGBT's on SS/SN board. ( No continuity beep )
    3) No shorted diode's on SS/SN board. ( Only continuity on outer 2 legs ).
    3) No shorted bufferboards.
    It has the TNPA5349 board with integrated buffer boards.
    https://www.youtube.com/watch?v=iHBI...J3qoRImWktec0F
    In this video you see the exact same boards.
    https://www.youtube.com/watch?v=uIyHr13b5w8
    In this video i tested the same parts the same way and they are ok.
    so it's either a bad mainboard or power board. Lets test.
  • Moreno83
    • Jun 2014
    • 2008
    • The Netherlands
    Re: Panasonic P42UT30 with 14 blinks.
    I do get F15V on the power supply and 5VSTB.
    When i turn on the tv the 5VSTB goes to 0v and 5VSTB-ON comes up and stays on.
    It does not matter what connector i disconnect , it always gives me 14 blinks.
    For example :
    If i disconnect SC20 and P2 , it gives me 14 blinks
    If i then also disconnect SS11 it also gives me 14 blinks.
    So its either the PS or the mainboard. Mainboard turns on the tv as i get 5V STB-ON.
    Removed P2 connector and turned tv on. I don't get any voltage on that connector.
    I will remove the PS for further testing.
    Any suggestions?
    • Moreno83
      • Jun 2014
      • 2008
      • The Netherlands
      Ow boy. Somebody tried to replace some capacitors on the powersupply and replaced them for cheaper ones. Bad soldering to be honest.....
      Dont think this is a capacitor problem but i hope i can still fix this board.
      So a small update. Im missing the 15Vs
      • Moreno83
        • Jun 2014
        • 2008
        • The Netherlands
        Resoldered the capacitors but still the same problem.
        The training manual says that if F15v is present --> replace A board.
        The 15V line on IC4800 is present but disappears after the click , im suspecting the mainboard to be bad.
        • Moreno83
          • Jun 2014
          • 2008
          • The Netherlands
          I actually bought this tv with this problem , hoping it was the SC board/IGBT problem. After measuring all boards im almost certain that the A board is the problem.
          I don't measure shorts on the connectors or IGBT's/Diodes on all 3 boards. No matter what connector i remove , i always get 14 blinks. The F15V / 5V / 3.3V on the power supply is present so that looks good. However , the 3.3v line on the mainboard is jumping from 0 to 3.3v , it goes up and down and the 15V line goes dead.
          Im suspecting that the A board has a communication error , maybe bad CPU due to lightning/power surge?
          I have to get a new mainboard to test it or does someone have any last suggestions?
          • Diah
            • Feb 2013
            • 6613
            how about disconnect IR section from MB and check !!!
            • Moreno83
              • Jun 2014
              • 2008
              • The Netherlands
              Thanks Diah , already did that and it was fine.
              • Moreno83
                • Jun 2014
                • 2008
                • The Netherlands
                TV IS WORKING!!!
                I was searching the forum for 14 blinks and found a thread from Reecey where he reflowed the audio chip on the mainboard.
                This mainboard has a big CPU which i know from VT/GT/ST models that they get really hot. As i was pretty sure that the mainboard was bad i thought , lets reflow that big cpu.
                Applied flux all around that cpu and reflowed it with a heat gun for a few minutes and let it cool.
                Reinstalled the mainboard and the TV is now working!!!!! Damn , what a gamble!
                Need to further test it to see if all functions like HDMI work but atleast i know the problem.
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  Sweet work buddy glad to of helped
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    What does this prove how can the Ir board fail ?
                    • Moreno83
                      • Jun 2014
                      • 2008
                      • The Netherlands
                      Hmmm unfortunately im back to square 1 , picture looked like this and now it wont turn on anymore.
                      It keeps blinking 7 times but i cant find any shorts on the sc board. Is this still a mainboard problem?
                      Will go further test tomorrow.
                      • Diah
                        • Feb 2013
                        • 6613
                        claim this questions to Panasonic which great the service manual.. cheers.. the party seem end fast lol
                        • Moreno83
                          • Jun 2014
                          • 2008
                          • The Netherlands
                          It ended to quickly yes!
                          But it only saw 1 HDMI so thats not good either. Will recheck everything tomorrow , i still think that the A board thinks the SC/SN board is blown.
                          Diah has that information out of the service manual that indeed says the infrared sensor is shorted which causes the 14 blink error , service manual is not that great.
                          Lets hope i'll have better luck tomorrow.
                          What causing the negative colours? A board?
                          • Malachi
                            • Dec 2015
                            • 1077
                            • Usa
                            I've got a TNPA5349 that was sent out twice to a company called finasonic on eBay.
                            They said they fixed twice but I'm still getting 7 blinks on my p42st30.
                            If you are interested let me know.
                            Just realized you are in the Netherlands. Probably not cost effective.
                            • Moreno83
                              • Jun 2014
                              • 2008
                              • The Netherlands
                              Thanks Malachi but i'll try to repair it myself.
                              • ReeceyBurger123
                                Never Give Up !
                                • May 2014
                                • 7325
                                • Britain
                                Ahh yeah, 14 blinks is just the cpu going "dam it somethings wrong, better turn off" and shutting down the set not specific though 14 blinks isnt
                                • Moreno83
                                  • Jun 2014
                                  • 2008
                                  • The Netherlands
                                  What do you think of the pics Reecey? Bad mainboard or buffers/ss board
                                  • Moreno83
                                    • Jun 2014
                                    • 2008
                                    • The Netherlands
                                    So i took the SC and SS boards out and measured all IGBTS and Diodes. They are all ok and almost all measure the same value.
                                    The resistors are all measuring the same value.
                                    I rechecked the buffer boards for shorts but they are fine also.
                                    I measured P2 connector and it measures 207v when i turn it on and then changes to 215v and shuts down with a 7 blink.
                                    So im lost here and need some help. It's either a bad SC board or the mainboard is detecting something thats not there. As i dont have a mainboard i want to recheck the SC board.
                                    I have a spare repare kit for the VT30/50 , the same small transistor on the sc board is identical so i might replace it.
                                    This all happened after i rechecked the SC20 cable and reseated the ribbon cables.
                                    I need some help with this tv
                                    • Moreno83
                                      • Jun 2014
                                      • 2008
                                      • The Netherlands
                                      The small transistor is IC502 and Q531. Not sure if they are the culprit...
                                      • Moreno83
                                        • Jun 2014
                                        • 2008
                                        • The Netherlands
                                        I removed these 3 cables and turned the tv on and it stays on?? Is that normal?
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                          by sam_sam_sam
                                          After all of...
                                          07-13-2024, 08:14 PM
                                        • canadaboy25
                                          Panasonic TC-P54VT25 No image. A or D board?
                                          by canadaboy25
                                          I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
                                          The panel is primed as there is a slight glow from the entire panel. This means the problem should be logic related. The service manual also confirms this and recommends replacing the A or the D board.
                                          I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
                                          01-17-2021, 01:06 AM
                                        • Yanleb
                                          Panasonic TC-P50S1 shorted TXNSC1EDUU (TNPA4782AB) SC Board
                                          by Yanleb
                                          Hi every one. I just want to share the successful repair of my shorted Panasonic TNPA4782AB SC board.
                                          I don't usually do it but so many parts were shorted that I decided to buy the ShopJimmy repair kit instead of sourcing each components individually. Here is the list of components the kit contained, with a remark indicating if I needed that part or not :
                                          D608, good
                                          D618 RF101L4S, good (See warning 1 below)
                                          D619 RF101L4S, good (See warning 1 below)
                                          D865 RF101L4S, shorted (See warning 1 below)
                                          IC464 Inverter HA MC74HC1G14, shorted...
                                          03-09-2020, 12:00 AM
