Philips 49pfl4609f7 won't turn on
  • crdz66
    • Nov 2012
    • 242
    Hello.
    I have a philips tv won't turn on.
    I replace twice the power supply board and won't come on.
    The fuse is good.
    The weird thing is the metal lines around the board show voltages to half.
    Means the p. On show need to be 24v and i get 12v
    and the another ones show low voltages.
    Like i said, i replace two times the power supply and still same problem.
  • CapLeaker
    Leaking Member
    • 8146
    Re: Philips 49pfl4609f7 won't turn on
    do the backlights come on?
    • crdz66
      • Nov 2012
      • 242
      no
        The AMP13V and ON21V will be at about 605 of the rating at standby, when the P-ON_H2 signal is present then then those Voltage will be at normal level as printed on the board.
        BTW, your board is similar as in this post:
        https://www.badcaps.net/forum/showth...hlight=P-ON-H2
        Read how we test the board by itself.
        • crdz66
          • Nov 2012
          • 242
          ok. thanks budm
          I checked all 3.3v and are present.
          3.3v is stand by on led tvs?
          Anyway, after read the post that you talked about
          I going to order the digital board
          See what happend.
          • Andrew F. Ali
            • Jan 2014
            • 2450
            • Trinidad & Tobago
            I can't follow...did I miss something???...Why are you going to get a Digital Board??....Did you try forcing the Power Board ON and the Backlight ON as well, with the 1k resistors??
            • crdz66
              • Nov 2012
              • 242
              nop
              • crdz66
                • Nov 2012
                • 242
                Well I check p-on_h2 short with 3.3v and now I get 21.11v
                on led connector I get
                3.7v
                47v
                3.7v
                47v
                but backlight doesn't come on the tv.
                Means????
                • Andrew F. Ali
                  • Jan 2014
                  • 2450
                  • Trinidad & Tobago
                  Follow the Thread budm suggests in Post #4.
                  • crdz66
                    • Nov 2012
                    • 242
                    Well I follow the thread like you suggest and I find backlight is no turn on.
                    Short with 1k resistors p-on/3.3v and 3.3v/backlight sw
                    Protection pins show voltage <1 volts.
                    So???
                    • CapLeaker
                      Leaking Member
                      • 8146
                      Did you check the backlight LED's in order to see if you have a open string?
                      • crdz66
                        • Nov 2012
                        • 242
                        Now I have another problem. damn
                        I pull out the power supply yesterday.
                        Today, I put it back for keep checking in and now I have a god damn low voltages.
                        I can't even generate the 3.3v standby voltage.
                        Why I did it wrong??
                        Bad ground?
                        I have 2 power supply and both show super low voltages.
                        • crdz66
                          • Nov 2012
                          • 242
                          any ideas?
                          • CapLeaker
                            Leaking Member
                            • 8146
                            The STBY power supply is seperate and is always on. So if you have nothing there either you got no voltage in the primary feeding it, there is something wrong with the STBY circuit in the primary, or ther is something shorted in the secondary of the STBY circuit, or it gets loaded down hard.
                            • crdz66
                              • Nov 2012
                              • 242
                              Well. Good news
                              I don't how, but, after replace main board the tv is working again.
                              Thanks to everybody.
                              • ktmmotocross
                                Thinkbook 15 G2 ITL no ALW voltages after replace burned USB-C contoller
                                by ktmmotocross
                                Hello.
                                Have this Thinkbook 15 G2 ITL that have burned USB-C controller U24. After replace i have main VIN voltage, but no ALW voltage. PU301 have VIN but no LDO and other voltages. i relace ic but still the same.
                                ic is SY8386. LDO should be working right after vin ?
                                board code is LA-K052P
                                any hint?
                                12-26-2024, 01:53 AM
                              • redbomb65
                                msi mpg z390m gaming edge ac missing voltages and wont turn on when pressing the power button
                                by redbomb65
                                hi i have a msi mpg z390m gaming edge ac mb. that wont turn on when i short the 2 pins on the front connectror.
                                im new in electrionic repair. and i hope that someone will share a bit knowledge, thoughts or ideas with me and others, to repair that damm thing ;D
                                1. thought psu problem. nope psu is good. i even bought a psu tester to be save.
                                2. thought a short somewhere that the psu goes in short save mode. nope... no short to measure with my multimeter to ground. psu and mainboard starts with all cabels plugget in, when i bridge green and black on the 24 pin.
                                cpu isnt...
                                01-24-2024, 08:36 PM
                              • pajdek
                                Lenovo Y700-17ISK turn on and off
                                by pajdek
                                Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                                09-20-2023, 02:49 AM
                              • ovrax
                                Philips 55PUS6804/12 turn on & off (probably backlight issue)
                                by ovrax
                                First of all, please excuse me as I'm quite new to this field.
                                I have a Philips 55PUS6804/12 TV. It turns on and off instantly (backlight flash). I personally think it's a backlight issue (faulty LEDs). Could you help me confirm my diagnosis?
                                I've checked and the T-CON seems to be fine. I disconnected one ribbon cable at a time at the bottom, but the problem persists.
                                The Ambilight works perfectly and stays on.
                                No sounds.
                                Thanks in advance.
                                08-25-2024, 04:33 AM
