Sharp LC-70LE650U Blinks 1 short and 3 Long
  • djluis
    • 12
    Re: Sharp LC-70LE650U Blinks 1 short and 3 Long
    Problem solved removing al COF's from right side .
    • Superbee_dad
      Sharp 80” long short flash backlight error - Help
      by Superbee_dad
      Hello Sharp TV experts
      Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
      > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
      > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
      01-24-2025, 11:51 PM
    • Noobwithamultimeter
      Sharp LC60C6400U - 2 long binks, 5 short blinks error code
      by Noobwithamultimeter
      Hi, long time browser - first time poster. I got my hands on a Sharp LC60C6400U and from what I could find on youtube similar models of this set have a 12V power regulator that fails called "KIA378R12PI". So I go ahead and order the part, install it and badda-bing my set worked right away. Only a problem - it failed after about 3 hours. So I re-attempted my solder joints and it was back in business, for a couple of days. Failed again with the same error code. I think to myself no worries I have 4 spares since I bought a 5 pack in case anything went wrong. But now after roasting the solder...
      04-06-2021, 01:31 PM
    • cm0002
      Sharp LC-55N7000U 1 long 5 short blinking, no display
      by cm0002
      I've got a Sharp LC-55N7000U. It has a standbuy LED when plugged in, but powering it on causes it to blink 1 LONG and 5 FAST. Theres no display and no backlight.
      Nothing I checked has that blink pattern for Sharp TVs and there's only one multi-button on the TV itself so that service menu trick involving the input button doesn't work either. Its a post-Hisense buyout TV so that probably makes sense lol
      I've tried disconnecting the panel sides from the TCON alternating sides, but no change in behaviour even when the whole TCON is disconnected,...
      06-19-2023, 06:21 PM
    • Charrlie
      Sharp Lc-70le734u blinking 2 long 5 short
      by Charrlie
      Just picked up this sharp tv not too long ago and it started not wanting to start the other day, giving me the notorious 2 long-5 short blink pattern indicating a power issue. I was able to force start it a handful of times (once the tv has fired up it has no issue running for 5+ hours). But now as of yesterday, no matter what I try to do button combination wise, I just receive the same blinking code.
      So I busted into it and have done the following:
      -Removed the power board and inspected for any bad caps, burn spots etc. Do not see any instances of such ...
      07-07-2022, 02:02 PM
    • Tom_x
      HP Omen 15-dc0001nh capslock blinks 5 long and 3 short
      by Tom_x
      I have HP Omen 15-dc0001nh (DA0G3DMBCE0 rev: E) with blinking capslock 5 long and 3 short. Fans spin constans speed.
      HP worked for 2 months after i repaired (before damaged by thunder via rj45 port) I removed LAN ic and powered on
      Now with blinking capslock:
      All voltage present on big coils, except +VCCGT (i don't know this need for booting)
      I tried re-flash bios with known firmware- same result (now i don't have spare bios chip to test spi flash failure)
      DDR4 ram is ok, tested on other laptop
      WLAN and SSD removed,...
      07-20-2023, 10:10 PM
