Philips 50PFP5332D/37 TOUGH DOG as they use to say
  • Truncatedhose
    • Oct 2014
    • 343
    I've been trying to figure out this 50" plasma for a couple of weeks. This one is stumping me because I've not seen this symptom and this TV doesn't have puffed caps like I usually see with this model.
    Upon plug in, it attempts to power up, relay clicks a couple times, seems to go into shutdown, the led on the front doesn't light up. There is an LED on the power supply board (location: LED8001) that blinks green 10 times. According to the chart printed above that, it says: PROT. UVP: 8V6 VSND_POS, VSND_NEG. I don't know what this means. I've downloaded the chassis EJ3.0U PA service manual from Elektrotanya, but can't find reference to this LED or error code. Maybe someone else can? I tried to get a training manual linked in another thread on badcapsforum, but it wasn't available any longer.
    Things I've tried/things I know:
    ---I found a thread talking about running test patterns off the logic by placing jumpers on it to see if the logic or main is causing a problem, but the result was it still shutdown with 10 blinks on the power supply board. I tried replacing the logic anyway and same symptom. I put the original logic back in.
    ---It has 5 volts standby
    ---I don't think it tries to develop VS or VA, but I can retest if anyone wants an exact report on what it does, but it didn't seem to even nudge my Fluke during it's power up attempt.
    ---I think I had tried unplugging the Y-SUS and Z-SUS to see if it would come out of shutdown, but I don't remember if that changed anything; I don't think it did.
    ---I can't find any bad fuses on the power supply, Y-SUS or Z-SUS
    Any ideas out there? I usually am able to figure these out, but I'm stuck on this one.
    Thanks so much!
    I will post 8 pics of the TV and boards.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Philips 50PFP5332D/37 TOUGH DOG as they use to say
    Had same psu shorted Vs Pfc fets, will link video.
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Check this out:
      https://m.youtube.com/watch?v=ESRx3UVlfCI
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Also I strongly suggest after the Psu repair you do some mods to the chaiss, Y, X main and the buffers strongly advise you heatsink them ! Also tighten all the screws on the power devices on the heatsinks on the Y and Xmain. Check this out:
        https://m.youtube.com/watch?v=57aDWsiLIxE
        • Truncatedhose
          • Oct 2014
          • 343
          Originally posted by ReeceyBurger123
          Thank you so much, ReeceyBurger123! I watched your excellent video. Glad you were able to solve that one. I'm going to pull this PS again and check those FETS. Do you think that I may find the same issue, even with a 10 blink code, not a 7 blink code as you had? I will check and let you know what I find.
          • Truncatedhose
            • Oct 2014
            • 343
            Reecey?
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Yes sorry check the main power devices over on the Psu see if any are blown
              • Truncatedhose
                • Oct 2014
                • 343
                Thanks. I checked all the fets/transistors and none are blown and no signs of shorting through their insulators. Any other ideas? Wish this one was as evident as yours.
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  Maybe check the fuses ? Vs is totally dead right ?
                  • Truncatedhose
                    • Oct 2014
                    • 343
                    None of the fuses were bad. I don't think VS even tried to come up because the TV goes into shutdown instantly and throws the 10 blink error code on the power supply board. I could put the board back in and test again, but I remember it not developing voltages, as makes sense with the way it shuts down and has an error code.
                    • jiroy
                      • Jun 2016
                      • 2416
                      • Lebanon
                      The meaning of : "PROT. UVP: 8V6 VSND_POS, VSND_NEG" is :
                      8v6 Under voltage protection , from the VSND_POS, VSND_NEG in the SSB to the Display supply protection .
                      Usually , such protection circuit is built around an LM324 ..and remain to say that "VSND_POS, VSND_NEG" means the problem come from the Audio system .
                      Hope this will help here .
                      • Truncatedhose
                        • Oct 2014
                        • 343
                        Interesting! Thank you! What do you mean by LM324? And do you have any suggestions for my next steps in troubleshooting? If I can just verify this, I wouldn't be opposed to just replacing a board, rather than doing component level at this point.
                        • jiroy
                          • Jun 2016
                          • 2416
                          • Lebanon
                          Don't worry about the protection thingy , it's just protection and eventually the protection is what preventing further damage to the unit , so it;s working , The problem is in the Audio circuit , but i don't have a schema for this model . Maybe someone can help us with it . In the mean time you can do some visual checks on Audio parts , wherever they are located .
                          • Truncatedhose
                            • Oct 2014
                            • 343
                            Okay, I don't really see an obvious audio amp or something, can someone look at the board pics and point it out to me? I'd like to just replace the audio board if you are sure that is what the error is indicating. I have a great supplier of inexpensive boards.
                            • Truncatedhose
                              • Oct 2014
                              • 343
                              Or is the audio circuit on the main board?
                              • Th3_uN1Qu3
                                Believe in
                                • Jul 2010
                                • 6031
                                • Romania
                                Audio amplifier should be on the main board. Look for it in the service manual, should have board diagrams.
                                A working TV? How boring!
                                • Truncatedhose
                                  • Oct 2014
                                  • 343
                                  Can you confirm that a main board would fix this problem? Where does it day this error code is an audio problem? I just want to be sure before ordering that board...
                                  • Truncatedhose
                                    • Oct 2014
                                    • 343
                                    Anyone?
                                    • ReeceyBurger123
                                      Never Give Up !
                                      • May 2014
                                      • 7325
                                      • Britain
                                      Wait there a second, why not try running the test patterns for the Pdp ? This will rule out failed mb.
                                      • Truncatedhose
                                        • Oct 2014
                                        • 343
                                        How do I do that? I did hook it up to run the test pattern off the logic as I described in my initial post, but you're talking about something else?
                                        • ohren
                                          by ohren
                                          09-08-2023, 05:24 PM
                                        • G33RT
                                          Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                                          by G33RT
                                          Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                                          It does power up when pressing the power button.
                                          I already try the power button while plugin the plug with no result.
                                          Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                                          Could this be an PSU or eMMC issue ?
                                          07-19-2025, 03:43 AM
                                        • korben_dallas
                                          Will I have a bricked logic board after reflow of the GPU v-core U8900 chip on my Mid-2012 15" Retina Macbook pro?
                                          by korben_dallas
                                          Hi everyone! I'm trying to fix my black screen / failed U8900 GPU v-core on my Mid-2012 Macbook Pro 15" Retinaby doing a rework/reflow of the chip (once I determine that's the real issue; but it likely is).
                                          I've been disabling the GPU in NVRAM for a few years... but it's just time for a better solution.
                                          I'm new to soldering but the only feasible way to fix this issue is to do something myself.
                                          MY QUESTION:
                                          I've been seeing some people (on this forum mostly) run into issues with the logic board needing a serial number or it being deactivated (?)...
                                          02-14-2024, 12:23 AM
                                        • cruiser_
                                          A1466 820-00165 intermittent shutdown
                                          by cruiser_
                                          hi there,
                                          Got this macbook after liquid damage. Nothing major, cleaned and reflowed what was suspect. Now, the laptop turns on and boots up but shuts off intermittently - sometimes after a few minutes, sometimes after a few hours.
                                          Can be immediately started from keyboard right after. Plug stays orange during this time. No battery.
                                          Gives shutdown cause -128.
                                          Seem to work fine in SMC bypass.
                                          Same shutdown happens with disconnected TP/KB/KBLED/CAM.
                                          Observations:
                                          - SMC_RESET_L - when pulled down - plug goes orange/green and...
                                          10-11-2022, 12:06 PM
                                        • Yanleb
                                          LG 60PK550 Logic Control Board EBR63450301
                                          by Yanleb
                                          Hi all, I just want to share the repair of my 60PK550-UA TV set.
                                          The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
                                          But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
                                          All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
                                          C57: 3.30V
                                          C61:...
                                          07-20-2023, 12:38 AM
