Problem with Sony KDL-37S5500
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Problem with Sony KDL-37S5500
    This is like dumb and dumber here, I would help but trying to make sense of it all :L
      Originally posted by dr-mr
      I made one more problem now.
      I tached the 15v and sgnd.
      Now when i turn the tv on it turns on the back light and the green led (like before my mistake) but after 5 10 seconds one relay clicks and the tv goes off.
      the red led starts blinking 8 times.
      turning the tv on ore off from the buton is not posible now.
      15V to what? you sure are making it worst.
      • dr-mr
        • Oct 2014
        • 11
        • Macedonia
        I schortet 15v and sgnd. Now is good, the tv is back to the old problem.
        When i turn on the tv with the t-con connected and without the t-con connected, the tv is the same only backlight and the green led are on.
        I noticed that the tv is turning off after som time ( the backlight and the green led turn off, red led turns on.
        • m1ch43lzm
          by m1ch43lzm
          05-12-2025, 08:37 PM
        • huj3r
          Sony KDL-40Z4500 LCD with stripes and 9 blinks (possible BGC board or harness problem
          by huj3r
          Hi there!
          I have a Sony Bravia KDL-40Z4500 which shows a colored vertical stripes pattern when turning on, with a central black shadow that slowly dissipates within the first 10 seconds.
          Photo of the situation after the black shadow dissipates:
          After this behavior the red LED will blink 9 times, then pause for a bit, and blink again 9 times, in a loop.
          I checked the manual (available here) and this corresponds to "HFR error", quoting from the manual:
          > This indicates HFR Communication error. [ HFR Communication...
          08-15-2023, 10:55 AM
        • jb_Bak
          by jb_Bak
          CN6401
          Pin 01 NC
          Pin 02 NC
          Pin 03 "BL_ON": 0V
          Pin 04 "N/C"
          Pin 05 "STBY 3.3V": 3.5V
          Pin 06 "GND": N/C
          Pin 07 "AC_OFF"...
          09-27-2021, 04:52 PM
        • delpiero3
          Sony Vaio SVS MBX-261 board failure
          by delpiero3
          Hi everyone, newcomer in this forum, i watched tons of video from Sorin, i like the way i calmly explain things, i did quite some console repair, i am not that bad at micro-soldering, but troubleshooting where the issue is, is definitely where i still have progress to make. Usually i was able to fix the console because the failure was obvious, or because i was able to find someone with similar measures on the board and was pinpointing what to replace that way.
          Nevertheless, let's say, i don't come as a total beginner.
          I have this old laptop, which suit perfectly my needs, with the...
          10-29-2024, 06:16 AM
        • PNI E.
          Dyson v15 problem with the dust detector board
          by PNI E.
          Hi guys, I have a Dyson v15 that didn’t work. The battery blink 10 times. If i disconnect the cable of the dust detector board, the Dyson turn on but after some seconds stop because didn’t feel the flow of the air because I disconnected the bird sensor, if I connect the Dyson is death. I notice the big mosfet I think with 3 pins. If I check the mosfet I have a short circuit from the center pin ne the left pins…so I think that s the problem or I wrong? The problem I can’t understand what type of mosfet is….someone can help it s hard to find. New board...
          10-02-2025, 10:18 AM
