Anyone know what could be wrong with this Plasma TV?
  • ajsterr4
    • Jun 2016
    • 115
    I'm thinking of buying it for repair but would like someone's opinion. Its a 51" Samsung 3D TV
    All I know of are these lines, other than that he says it functions great and a while back had it *calibrated*
    Any ideas are much appreciated!
  • ozzy214
    • Nov 2013
    • 319
    • usa
    Re: Anyone know what could be wrong with this Plasma TV?
    Looks like a buffer failure to mean. Ceck out the buffer ics for pitting, burn spots, or holes.!1
    • tw2005
      • Oct 2011
      • 6458
      probably would want to get the model and search for common faults. Looks like buufers but I think there were some late models where the panel ribbons chafed and wore through on the chassis in which case not repairable.
      • chrismurphy
        • May 2014
        • 251
        • australia
        buffer connections or tabs
        Would not pay more that $20 for it
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Panel failure, I would say its not fixable. The ribbon connections from the buffers break off at the glass. Dont spend a penny on it imo.
          • rccrasher65
            • Mar 2014
            • 618
            Definately a bad Panel, stay away!
            • mmartell
              • Oct 2013
              • 3189
              How can you guys be sure without knowing the model number ? Is this particular fault spread across all 51" models ?
              • chrismurphy
                • May 2014
                • 251
                • australia
                You asked the question and got replies you dont like
                3 people say dont touch it ,bad panel , the advice you got was from experienced and informed people
                If you dont like the responses buy it , and take the risk
                • dick_barton
                  • Aug 2015
                  • 6642
                  • Wales
                  I think wires are crossed here. I believe mmartel may be asking how you reached that conclusion for his own benefit so that he then knows what to watch out for in diagnosing a bad panel.
                  • mmartell
                    • Oct 2013
                    • 3189
                    Exactly. Just looking for the reasoning behind the conclusion that's all.
                    • ReeceyBurger123
                      Never Give Up !
                      • May 2014
                      • 7325
                      • Britain
                      Yes common issue on all Samsung Plasmas..... Ydrive ribbons break off at the panel right near the glass guess its just a fatigue thing from them being cheaply bonded.
                      • ArMaaN376
                        Samsung PS51E550 Plasma TV
                        by ArMaaN376
                        I am having Samsung PS51E550 Plasma TV. While the TV was working, a crackling sound heard & video went off with audio still ON. After switching it off & ON, the red LED on TV blinks six times & then off.
                        Opened TV cover & observed foll
                        a) Green LED on the small PCB blinks at @5-6sec ON & off for 3-4 secs. Red LED on logic board ON
                        b)Vs & Va on power supply board raises momentarily to 209v & 58v resp & then drops.
                        c) Cold test on Y-main board shows all 3 pins of FGPF4536 IGBT short to Grnd.
                        How to confirm Y -Buffer board...
                        06-19-2024, 04:05 AM
                      • jm1234
                        Panasonic plasma TX-P42ST50 - 6 blinks
                        by jm1234
                        anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                        It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                        I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                        I checked that board for any obvious faults...
                        05-22-2024, 06:59 AM
                      • KYBOSH
                        Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
                        by KYBOSH
                        Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
                        No picture but you hear the TV static (white noise) playing loud and clear.
                        The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
                        But it seems they didn't get too far and just left it.
                        When I first took a look I was amazed at how pristine the inside looked.
                        Its as if the TV had been in a time capsule.
                        Caps looked like they were just pulled off the self.
                        Copper coils had no sign of corrosion on...
                        02-01-2023, 11:10 PM
                      • Jeff'sTech
                        Dell Latitude 7420 BIOS Unlock Gone Wrong
                        by Jeff'sTech
                        Hello everyone.
                        I have come here with a rather specific question. I was given a Dell Latitude 7420 laptop with a busted screen, and wanted to see if I could refurbish it into my daily driver. I wanted to experiment and see if a 2-in-1 display would work as the chassis of the laptop and 2-in-1 7420 looked identical. I threw in the display and my hypothesis was correct, however, I was greeted with a locked BIOS and since I didn't know the password, I figured I'd try to unlock it somehow. I bought one of those POGO pin probe things for my CH341A programmer so I could read and make...
                        11-08-2023, 03:30 PM
                      • porfyriadhs
                        Samsung Plasma PS51D6900DS Bootloop
                        by porfyriadhs
                        Hello . I have a problem with a samsung plasma tv stuck in bootloop . The TV is Samsung PS51D6900DS plasma smart tv .Need help if anyone have any suggestions
                        Thanks a lot !!
                        10-19-2023, 11:31 AM
