TX-P50G20B with 8 blinks
+ More Options
Posts
  • Motsey
    • Jun 2016
    • 6
    • United Kingdom
    HI, have a TX-P50G20B with 8 blinks.
    I thought my issue was the SS board but once replaced it still blinks 8 times. However when i remove the SS33 cable of the SS board the Tv blinks 6 times.
    A service guide i was kindly provided then shows the next board with an issue may be the A board, but i have since purchased a replacement and this has not cured the issue.
    I am guessing the next board would be the SC board but this is not listed as being as issue for 8 blinks?
    Is there a way to test the panel to see if it lights up and will work prior to replacing more boards.
    I will have a go at checking the voltage on the weekend on the SC board, I have already removed all the connectors and given them a clean and replaced.
    Any help would be greatly appreciated.
    Thank you
  • tw2005
    • Oct 2011
    • 6458
    Re: TX-P50G20B with 8 blinks
    Well if the sc has failed Q661 is usually shorted. So probe that and let us know if it is
    • tw2005
      • Oct 2011
      • 6458
      Well, I'll put these quotes here so we can see the story from start.
      Originally posted by Motsey
      HI, have a TX-P50G20B with 8 blinks and was wondering if you could guide me to the service manual you were looking at please?
      I thought my issue was the SS board but once replaced it still blinks 8 times. However when i remove the SS33 cable of the SS board the Tv blinks 6 times. I think the issue may be the A board and am about to purchase one but would to have a read of the manual to investigate further.
      I really hope it is not a filed Panel, out of interest is there a way to text to see if the panel is good before spending money on boards?
      Thank you
      Originally posted by tw2005
      Sure and since you've just joined, if you need to do more on this when your account is activated, start a separate thread for Panasonic TX-P50G20B - 8 blinks.
      have you used search yet to see if there is any history?
      Don't get many 8 blinks, can't remember if I've read more than one on this series.
      There should be some results tables for results expected with different boards and cables removed in that guide
      It does say disconnect ss33 if it still shuts downs check ss, c2 board and A-board connections if good , A-board,
      Have a good look at those white ribbons just in case there is corrosion, I had a HD 2010 model give me 8 blinks due to corroded ribbons.
      You can disconnect sc2, ss11, p35, and the 3 white ribbons to turn the TV on and see if it errors. It should turn on . If you do this, don't reconnect sc2,ss11 and important not P35 for a good 5-10 mins due to voltage still stored, or get a meter and check those first . Spike p35 and can fry the panel ribbon ICs.
      Hi tw2005, thank you for you response.
      When i removed all the above cables the tv did turn on, well the green light came on but the screen was black.
      Do you think this now excludes the A board as being the problem? I have replaced the SS board to one i believe is good, so based on the guides you attached most likely failed is 1 SS board, 2 A board and 3 panel! I hope it is not the panel!
      Once this has discharged i will have a good look at the cables before plugging them back in.
      • Motsey
        • Jun 2016
        • 6
        • United Kingdom
        I have just tested this use a multi meter and the results are a follows;
        Using the 2000k Ω setting
        Pin 1(+) & 3(-) = 002 Ω
        Pin 1(-) & 3(+) = 002 Ω
        Pin 1(-) & 2(+) = 128 Ω
        Pin 1(+) & 2(-) =145 Ω
        Pin 2(-) + 3(+) = 136 Ω
        pin 2(+) + 3(-) = 145 Ω
        I am presuming the pin outs as;
        1. Gate
        2. Collector
        3.Emmiter
        either way I think this is not working as its giving me reads from every pin option!
        Am i correct?, if so are these parts easy to source or would it be easier to buy a new board?
        • tw2005
          • Oct 2011
          • 6458
          1. Gate
          2. Collector
          3.Emmiter
          definitely easier to get a board. GTV Watford sells genuine kits if you wanted to have a go. It does involve SMD work so unless you're reasonably experienced at soldering some of those tracks tear easy.
          Going on what you put up Q661 is shorted, you will most likely find most of these shorted.
          give you an idea what you're replacing.
          Can always sell the dead board for someone to repair or treat it as a project
          DG402RP x 2, DG502LW x 2, 30F125 x 2, 45G128 x1, RFN25TM4SW, D451 RF071L4S, Ic521 M81737P driver ic, Q701 ,Q702, IC773, IC771
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            +1 theres also alot more that fails on them boards too I had one with a crap tonne blown out. Best to get the board IMO.
            • Motsey
              • Jun 2016
              • 6
              • United Kingdom
              OK thank you guys, I think I am pretty good at soldering as i used to do it for a living (manufacture) but if there are multiple components that may fail i will buy a new one.
              1 issue may arise, one of the screws connected to the buffer board was stuck and I didn't risk remove it as it felt I was about to round the head!
              • tw2005
                • Oct 2011
                • 6458
                That's unusual. Never had a stuck one. Is the screwdriver the correct size?
                That guide has the resistance checks for the SD/Su, check those if you have not already.
                • Motsey
                  • Jun 2016
                  • 6
                  • United Kingdom
                  I believe it is the correct sized screwdriver, it removed the other 3 screws with no problem. I have since tried a few other screwdrivers, I guess i will use some pliers to give it its first turn.
                  OK I will have a look at the guide now.
                  • Dizzwold
                    • Oct 2018
                    • 5
                    Hi All,
                    I'm a recently new member and would like to say hello to you all, and that I'm thankful to have found this forum with a wealth of help and information.
                    The than my introduction to the forum;
                    I have some issues with my Panasonic TX-P50G20B. Firstly can someone point me in the direction for the service manual for this model. I've found a service manual for the TX-P50G20E and the TX-P50S20B. Would these be accurate for my TX-P50G20B in the UK.
                    From reading the 2 service manuals listed above, to get the Power LED to blink with a code, do I have to be in the service mode?
                    If someone would be kind enough to reply, I will then be able to elaborate on the issues I'm suffering with this unit.
                    Thank you in advance for any help.
                    Regards.
                    Dizzwold.
                    • Dizzwold
                      • Oct 2018
                      • 5
                      *The than my introduction to the forum;
                      Other than my introduction to the forum;
                      Sorry typo.
                      • foxyUK
                        • 35
                        • United Kingdom
                        The error code flashes of the red standby led should occur as soon as you switch the TV on (after a brief green led).
                        Here's a link to the troubleshooting guide:-
                        https://1drv.ms/b/s!AhyAtuUSxECNmxEeAu7684zjsybQ
                        • Soulzink
                          Samsug washing machine. Power supply DC41-00189a board issue
                          by Soulzink
                          I am trying to fix a samsung washinmachine power supply main board.
                          I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
                          Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
                          The power supply board reference is the following: DC41-00189a
                          I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
                          04-19-2025, 06:26 AM
                        • Asraf Atb
                          by Asraf Atb
                          01-27-2025, 05:02 PM
                        • notallbad
                          TCL 55RP620K power board issue
                          by notallbad
                          Originally the tv arrived with dimmed backlights (not failed leds) but everything else worked ok. Adjusting backlight in menu did nothing but voltage changed on dimming control pins,
                          0% p_dim at 1.65v and a_dim at 1v
                          50% p_dim at 3.3v and a_dim at 1.65v
                          100% p_dim at 3.3v and a_dim at 2.88v
                          Changed backlight leds anyway as always like to have complete peace of mind they wont fail shortly after selling the tv. No change as expected!
                          Leds are 2 rows of 15 6v leds.
                          On inspection of the power board found diode MBR3200 shorted so replaced with...
                          07-12-2025, 05:45 AM
                        • eclectric
                          Sony Bravia KDL-70W850B T-CON board / software update issue
                          by eclectric
                          Hi, I'm hoping someone can help me with this issue before I give up on this TV.
                          In short, I replaced the T-CON board due to an error code indicating that was the problem, after which it flashed a green and orange LED meaning software update required. I cannot get the tv to do the required update via USB, so I am stuck.
                          Here is a rundown of the symptoms and the steps I have taken to troubleshoot:
                          I inherited the TV with the symptom that it would turn on, then turn off after 5-10 seconds and a red LED flashed 4 or 5 times. Sometimes it would be 4, sometimes...
                          05-23-2022, 01:25 AM
