LED Backlight replacement question
  • CraigR
    • Dec 2013
    • 973
    I'm starting to see more and more Vizio and LG's coming in with LED back lights burned out and I have not found anyplace to purchase a new strip just a hit or miss with used stuff on eBay. I have butchered a few in from doner backlight strips but I see after removing the lens it might not be too bad a job just to super glue a new LED bulb on top the old one and solder to the old connections then install the lens again. Has any one done this or has any ideas on what to do replacing these other than what I am doing right now??
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: LED Backlight replacement question
    You can get them off replacement/spare strips, if you want I can link my repair video of this. If not just order some pure white SMT 0.5w-1w Leds.
    • CraigR
      • Dec 2013
      • 973
      Sounds like what I have been doing but sure I will have a look at your video.
      • chrismurphy
        • May 2014
        • 251
        • australia
        dont bother with removing the lens ,you wont get them back on well enough so not to give a hot spot on the screen
        Best bet is to replace led strips with strips from donor sets or remove the led faulty led and place a cut section of a good led from faulty strips on top and connect with wires
        Plenty of YouTube clips showing this
        how to test https://www.youtube.com/watch?v=eEJoPCa7Kt0
        stacking https://www.youtube.com/watch?v=RxwdC7V5Ue0
        • CraigR
          • Dec 2013
          • 973
          This is what I have been doing all along. Was hoping there was some new way to do it out there.
          • SLK001
            • May 2014
            • 264
            Don't remove the lenses? What is so hard about it? I use a hair dryer to softer the glue, then just pop them off. This is the time to remove all the remaining glue, while it is still warm. Once the LED is exposed, replace it with a good one. Mix up some 5 minute epoxy and using a toothpick, place a small amount in the holes in the strip, then carefully place the lens into the epoxy. Once cured, no bad colors and no hot spots.
            • jbfr_54
              • Dec 2012
              • 52
              • France
              I personnally replaced a lot of bad LED's on strips, just removing the lens with a precision cutter applied on the base of three pads, then using a heat gun to remove the failing LED and resolder a new one in place either from its edge with a conventionnal solder iron or with a heat gun blowing from the backside of the strip's PCB. In that cas I use self adhesive aluminium (used by plumbers) to maintain the LED in place and prepare both the LED and the PCB pads with a little solder and flux. Watch the polarity and test one by one the replaced LEDs. I use 3528 LEDs from this source : http://fr.aliexpress.com/item/100PCS...OrigTitle=true. Then refix the lens using a little drop of instant glue on each pad while maintaining the LED low glow by appliying small amount of current in order to correctly center the CAP above the lighted surface of the LED. Light diffusion is not perfect but acceptable and each LED replaced is à 5 cent fixing, a lot less than buying a new stripe. Good luck !
              • nicke74
                Samsung UE55JU6875 issue after backlight replacement
                by nicke74
                Got problem with a samsung UE55JU6875 after replacemant of backlight
                I have done similar replacement several times before without any issues but now I got video problems after the replacement and do not understand why
                Attached picture of the problem
                Is it a bad panel or any issues with the T-con card or ribbon cables or bad connections?.
                I have tried to replace both ribbon cables from T-con to panel without any difference.
                Any ideas?
                The only misstake I might have done was forgot to remove the ribbon cables from the T-con card before...
                04-02-2023, 11:03 AM
              • RetroComputingGrotto
                LG 42LN540V LED Backlight Flickering After Replacement When Connecting The Screen
                by RetroComputingGrotto
                This TV has been on the wall in our reception area for around 10 years and the other day the backlight failed. You could see a feint picture so we knew the screen was OK. I took the TV apart to get to the failed backlight and inject voltage in to each half of the LED strips to identify which ones had failed and 4 needed replacing. I ordered a set off of Amazon and they arrived the next day.
                On fitting the new LED strips I plugged in the TV was blinded by the light!!
                It was only when I partially put it all back together (including the screen) that...
                10-23-2024, 04:17 AM
              • DanPoka
                by DanPoka
                02-15-2025, 05:05 AM
              • Comp_Pro
                No Backlight Macbook A1990 820-01041
                by Comp_Pro
                Hello all,
                Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                Tests performed:
                There is no backlight even with a good screen.
                Backlight IC is receiving the correct support voltages.
                Fuse F8400 ok
                Current sense resistor R8400 ok
                Backlight IC is receiving 3.3V on enable pin.
                Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                Backlight IC receiving 5V from PP5V_G3S
                Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                05-06-2024, 10:23 PM
              • alltvrepairs
                LG55UH615T Tripping after backlight replacement. Uses LGP55LIU-16CH2 power supply
                by alltvrepairs
                This TV uses 2 bottom edge LED strips. 1 was faulty but replaced both. However I have still noticed that the RHS of the TV switches on and then TV starts to recycle power getting to the LG logo and start over. If I disconnect the RHS LED strip will work with half screen lit. I have swapped LEDs and same problem.
                The power supply uses MAP3516 chip. Have replaced it twice, Checked all components as greatly suggested in this post https://www.badcaps.net/forum/troubl.../101580-lg55uh...
                01-08-2024, 03:21 AM
